Question about Bosch 1999-2003 Dodge Ram 1500 Van Water Pump 99-03 Dodge Water Pump 2002 2000
When I start my truck the engine reves up between 3-4000 rpm It stays reved up when putting it in gear
It seems like the throttle is stuck but when checked the throttle was working.
Why when i just installed a new T104 timer yet seems wont turn on with pins
Are you sure that you put the pins on right? They have little projections on the bottom that turn the timer on/off as the cam moves through its 24 hour rotation. The little gear in the back is connected to the motor and because it is spinning that tells you that the motor is definitely good.
Sep 11, 2015 | Intermatic 220v T104p Swimming Pool Pump...
I need help. My water heater all of a sudden stopped heating after an extension cord had shorted in the next room over. So could the problem be the breaker or the reset button which is stuck?
Check the breaker first and confirm that power is being delivered to unit. Then if power is confirmed, try the reset and make sure that power is now getting to the heating coils. If necessary, you can always jump the reset switch if it stays stuck.
Aug 26, 2015 | Water Water Heaters
Shifting problem in 1999 dodge 1500 it sometimes shifts ok, but getting bad. seems likewhen it warms up it wont shift into 2nd or 3rd. then stop and go in store and come out and it runs fine. what could it...
Check valve is stuck,you will need have it changed or removed. if you remove it it will take about 30 seconds when you start it up after sitting for several hours to go in gear. Because it has to get back up to pressure. It was a bad desighn by dodge because the check valve collects debris behind it and it restricts the fluid flow.
Jan 06, 2013 | Bosch 1999 Dodge Ram 1500 Van Water Pump
Whirlpool 6th sense stops at 1 min and doesn't finish wash cycle
We had same problem, and the only thing that we could do is call the repair man. He put in a new door lock and the problem was solved.
May 21, 2012 | Whirlpool AQUASTEAM 9559 WASHER FOR 220...
Have an Atwood LP water heater. When I light the pilot light and hold it for 30 seconds or more it stays lit but the burner tube will not light except for at the air/fuel mixture slits at the thermostat...
Yes, a good place to start would be to run a burner brush through entire tube to make sure all spider webs are out, then blow through again. If that doesn't cure it, double check your position of burner tube in chamber. Sometimes if it's moved into chamber too far, it will tend to back-up flame in to tube. I've had some that I re-installed and was sure I put it back exactly where it was before, but had to pull burner tube back approx 1/8"-3/16" to get a proper flame. Make sure it's centered in chamber as well.
Dec 06, 2010 | RTO Atwood Water Heater - 6 Gal LP
Pilot light starts, but gas does not ignite.
IF no gas comes and the piolet is lit then the gas valve is stuck. You can purchase a seperate gas valve and replace it. If it is cost justified ,you will have to determine. As far as I know, one  cannot disassemble and repair the gas valve as you cannot purchase the parts for it.
Apr 04, 2009 | Water Heaters
No hot water because the water heater won'tr stay lit.
The thermocouple is probably bad. Since a thermocouple is real inexpensive, I would suggest replacing it first. If you are still having issues, it's the gas valve and it needs to be replaced. The valve is expensive and usually costs about $90 to $150.
Mar 21, 2009 | Water Heaters
Water doesn't stay hot PowerStar AE3.4
Are you using a single lever faucet? The install guide does indicate that you may need to reduce the input from the cold water side to ensure that water stays at a consistent temperature (see page 7 of the installation and service manual). Also, remember, this is a SMALL hot water heater. So if you're running for any length of time at full output, it may not keep up with you (see page 8 of the service an installation manual). I found the manual online at http://www.airwater.biz/images_templ/bosch-water-heaters-ae3.4-manual.pdf.
Jan 24, 2009 | Bosch PowerStar AE3.4 AE3.4 Point-of-Use...
Bosch 1999-2003 Dodge Ram 1500 Van Water Pump 99-03 Dodge Water Pump 2002 2000 Logo
55 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
