Question about Coffee Makers & Espresso Machines
Drawer missing message showing, ive cleaned both sets of contacts, what is the location of the drawer micro switch. Many thanks
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 26 Answers
If ther is two pens that's men's it's wired not a microswich
So look where the pens attached to the machine then Mack sure the wires are attached bouth from inside the machine
Posted on Apr 19, 2015
Drawer missing
Check that the pin on the drawer cover is not broken.This pin will activate the micro switch that tells drawer is in place.
May 12, 2014 | Franke Saphira Espresso & Coffee Maker
Lexmark T644 Drawer 2 Missing error message but drawer 2 is in place. Drawer 2 always has problems pulling form form drawer when printing from drawer 2.
If job prints from the wrong tray or on the wrong paper or specialty media, this is an indication that the operator panel menu settings do not match the media loaded in the tray.
Make sure the Paper Size and Paper Type specified in the printer driver match the paper size and type in the tray.
For further assistance, please contact Lexmark Technical Support
Feb 09, 2012 | Lexmark T644 Laser Printer
Dregdrawer full
Check the back of the drain tray make sure there are no grinds. Then we will have to test the micro switches, remove the drain tray and dregs drawer, insert tray without the drawer, to see if you get an error. A more complicated way is to have the door open place tray minus drawer in machine, then using a small stray or plastic knife, activate the microswitches.
Feb 21, 2010 | Gaggia Titanium Espresso Machine
The dregs drawer missing indicator on, unit won't work.
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. Inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
There is a micro switch whit an arm the hangs down in the slot on the side of the machine. Make sure that you have the arm for the micro switch.
Jan 11, 2010 | Saeco Magic De Luxe Espresso Machine
Error message: Dregdraw miss
which machine do you have. The drawer is not hitting the micro-switch try puttin a piece or 2 of tape on the tab on the side of the dredge drawer
Nov 20, 2009 | Saeco Coffee Makers & Espresso Machines
Canon 3035 missing drawer options
On your computer go to the start menu,select control panel,printers and faxes,right click on the ir 3035 driver,select properties from there go to device settings.In the paper source options inable the casette unit.
Then you will be able to print from the extra cassette unit.
Mar 13, 2009 | Canon imageRUNNER 3035 Black and White...
CASIO TE2200 Error E010 while drawer is closed
This type of problem is normally caused by a switch. When the drawer opens, the switch closes and the machine goes into 'drawer open' mode to prevent another transaction. The switch or the switch activator has probably failed.
Remove the entire drawer assembly, meaning everything that comes out when the drawer is opened. Use a flashlight and look at the inside rear of the drawer opening to see if you can see the switch. It may be a lever or a button and it may be in line withe the drawer or in may be off to one side. When it is located, try to press on the button or lever. If you can and the machine goes back to 'normal mode' the problem will be identified and you will know that the switch is good. Now you need to locate what actuates the switch to see why it is not making contact. Look on the part of the drawer that should come in contact with the switch. If a small, thin piece of plastic has broken off, tape a small piece of a hard substance in that area. Close the drawer to see if the 'open' message goes away. If id does not, try a thicker piece. Repeat until the 'open' message goes away. When that happens, glue the last piece in place.
If the 'open' message does not go away when the button or lever is press, it indicates that the switch is bad and needs to be replaced. Most of these switches make contact when the button or lever are not pressed. In the short term you could locate the switch and disconnect one wire. That would simulate the button being pressed. You would just need to remember to not start another transaction until the drawer is closed.
Good luck, and please let me know how it works out.
Feb 22, 2009 | Casio Parts Cash Register PC Desktop
Dregdrawer Full
There is no 'sensor' for this, an internal counter resets when you remove the drawer with the machine switched on and the "Dreg drawer Full" message displayed.
Make sure the machine displays this message "DREG DRAWER FULL" Do NOT turn off the machine, Pull out the drawer that the used grinds are dumped in(you have to remove the drip tray 1st) Check display - it should read "DREG DRAWER MISSING" If the display message is correct, wait 10 seconds then replace the drewer.
Message should be cleared.
If the "dreg drawer missing" does not display, you do have a bad sensor and machine needs to be serviced.
Nov 19, 2008 | Saeco Royal Digital Plus Coffee...
Gaggia syncrony compact digital - DREGDRAWER MISSING
the thing that dropped out was part of the micro switch for the dregs draw. Yes you can use the machine with the piece that you put in there, at some time you might consider just replacing the micro switch.
Sep 24, 2008 | Gaggia Titanium Espresso Machine
DregDrawer full message won't clear
When you need to empty the grounds draw remove the drip tray and pull out the dregs draw - don't open the side panel or turn off the machine, - It works for me!!
Feb 20, 2008 | Saeco Royal Professional Espresso Machine
Coffee Makers & Espresso Machines Logo
44 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
