Question about Philips Televison & Video
How can I locate the HDMI channel on my TV without using a remote?
I can use the channel up and down buttons but the only options are channels 1-99 and Ext 1 and Ext 2.
  • Joe LeBlond
    Joe LeBlond Apr 17, 2015
    Hi Ryan Cuthbert, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Is their actually an HDMI connector on your TV. HDMI is an input not a channel. On a Philips TV generally referred to as AV input.
  • 74 Answers
There should be a button on the t.v. itself for input.
Make sure you push on the input button til the desired HDMI input
Posted on Apr 17, 2015
How do I get to my HDMI channel?
It isn't a 'channel' it is a connection port. Once a cable box or DVD / blue Ray player is plugged into it, you choose the port using the Input button on your remote and scroll through them.
That set has 2 HDMI connectors on the back panel, right side, more or less by themselves, to the lower left of the antenna jack.
See the link. In the cluster of 3 photos, click the center one, then zoom it. Source(s): http://www.crutchfield.com/S-QWOJIeQP36Y... kg7or · 4 years ago
All the info on the television including manuals and inputs can be found here,
ftp://ftp.panasonic.com/television/howto/combo_connections_howto.html
58 Class 58 0 Diagonal 1080p Plasma HDTV with Anti Reflection
Jan 01, 2016 | Panasonic Televison & Video
Reprogram channels on my Westinghouse tv model sk26h520s for a new location
Make sure that the source is set to TV. If you use the original remote, press the top button between the volume up/down and channel up/down buttons. If you use the buttons on the side of the TV, the Source button is next to the Channel Down button.
Next press Menu. (On the TV, it's the top button. On the remote, it's the top left button next to the arrow keys.) Now navigate down to Channels (use the Channel down on the TV) and press Enter on the remote (or Menu on the TV). Navigate down to Scan Channels and press Enter or Menu (as needed). Choose Antenna or Cable, depending on your source and press Enter again. (Note: the volume buttons on the TV are your left and right arrows in the OSD.) If you get a confirmation notice, select Yes and press Enter.
I hope this helps.
Dec 31, 2014 | Westinghouse Televison & Video
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
How do i connect xfinity to my plasma display
If you're referring to your xfinity tv receiver (the cable box) there's a few different ways. Please keep in mind without much information, it's difficult to give a 100% direct answer.
There are four ways to connect it. We'll start with what will give you the best video quality, going to the worst.
HDMI cable: A single cable with a flat end. Your TV and receiver will have port labeled "HDMI". You plug it in, and then use your tv remote to set it to the HDMI channel. You may have source or input button on the remote. Press that, and a list of options will appear on your tv. Select HDMI. If there is more than one HDMI (as in HDMI1, HDMI2) try each one until you get a picture.
Component cable: A cable with 5 ends. They're color coded, so match up the colors. Then try that input our source button to select the COMPONENT option on your tv.
RCA cable: A cable with three ends. Color coded. Follow the same directions as above in regards to the correct "channel" to put it on.
Coax: A single cable, an end that screws in. Its connector will look like something can be screwed on it, with a hole in the middle for the pin to go into. Connect it, then tune your tv to channel 3 or 4.
Mar 30, 2013 | Comcast XFINITY
I have removed all cable boxes from my home. I cannot get the tv remote to change channels. I was told by the cable tech that I needed to do a channel search. How do I do that?
Which specific model do you have? The menus may depend on your model. Are you using the original TV remote or a different remote? If you do not have the TV remote, try the buttons on the TV. Use the channel up/down buttons to navigate through the menu items and the volume up button to enter a sub-menu.
Try Menu and locate the Channel sub-menu. Then make sure that the antenna Air/Cable item is set correctly. Then the Channel Search option is on the next line. This is the method for the LCD2050. For the TTM2901L, you need the same Channel sub-menu but the channel search is called "Auto Program".
A number of other manuals for Polaroid TVs are available here: http://www.polaroid-tv.com/polaroid-lcd-tv/manual/ .
I hope this helps. If you add a comment with your model number, I'll be glad to provide additional help. (Note: without the model, I can't be sure which tuners (NTSC - analog OTA or cable, ATSC - digital OTA, or QAM - digital cable) are in your TV. This may change whether you can receive any stations without the cable boxes.)
Jan 25, 2012 | Polaroid Televison & Video
No channels in Master List message on Vizio xvt3d554sv with Dish Network Satellite...what to do?
I had this same problem. My TV had sound and the lights were on but no picture. The screen said "No Channels in Master List."Here is how I fixed it:1) I made sure that my Dish Remote was on the TV mode (when pressing down buttons, the TV button would light up).2) Once that was confirmed, I pressed 03 to ensure I was on Channel 3.3) (this was the hardest part!) I found the remote that came with the TV. I never use it so it was hard to find...4) I pressed the Input button and selected the correct Satellite option. On my TV, that option is: "HDMI-1 Satellite"5) The picture was restored!
Aug 19, 2011 | Vizio L37 Television
I am looking for a remote code for a curtis 26' lcd tv so i can control it with my directv remote.
your direct tv remote has an optional code search that is useful by using the channel up and channel down buttons try to program as usual and after pressing the tv button use the channel buttons until the channel changes, when it changes hold down the mute button for a couple of seconds
Feb 18, 2011 | Televison & Video
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
Jan 24, 2010 | Televison & Video
How do i get the tv on av without using the remote?
push channel down button through the channels, then it will go into av mode(video) by just keeping to press channel down. it will be channel below channel 02. just keep pushing channel down button
Nov 21, 2009 | Beko 324250WN 28" TV
Televison & Video Logo
60 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
