Question about Dryers
I HAVE A EURODESIGN DRYER BOUGHT IN '03 I now have error 68 message and dryer stops - anybody know what this means - cant find it in the manual. thanks
  • 74 Answers
It means it has a stuck button.
I'm taking it that it's a Fridgidaire.
on the door you should have a model number that looks like this
AEQ6700FS .
http://www.searspartsdirect.com/dryer-repair/error-codes/frigidaire-dryer-error-codes.html
Once you find this and you need a manual goto
Browse Products
Posted on Apr 17, 2015
What do i do when my frigidaire dryer shows error code 68
Good Morning Friend,
I understand that your Frigidaire dryer, model# LEQ2152ES0, is showing a 68 error code. The E68 error code means that there is a possible button that is stuck. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power is restored start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Electrolux Dryers
My dryer SHOWS ERROR 68 ON PANEL and shuts off?
Error 68 can mean that your start button is stuck; check to make sure the button is not stuck in the pressed position behind the controls cover.
Apr 25, 2010 | Frigidaire Electric Dryer
My electric dryer tell me ERROR 68 on the screen ¡¡ Plus every 5 minuts stop for she self ¡
The data sheet says "One of the buttons is stuck closed". If you can't solve this by inspecting & jiggling the buttons, open the lower front panel of the machine, & look behind it for the "Tech Data Sheet*. Follow the instructions for error 68.
Nov 27, 2009 | Frigidaire FEQ1442ES Electric Dryer
Fridgidaire Error 68 (model No. LE02152EEO) and constant beeping!
this fault code means there is a stuck key on the control board.you need to disassemble the display panel and free up the stuck key if this does not work then the display panel and or control board need to be replaced
Sep 02, 2009 | Frigidaire AEQ6000ES Electric Dryer
Error e 68 pops up and dryer turns off. Doe sthis
Hi
Thanks for using FixYa. E 68 error means that there is a leakage of current to the ground on heater or fuse opened. Also check the resistance of the NTC which should be around 50K ohms. If not then you need to replace the water inlet valve assembly.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 30, 2009 | Frigidaire Dryers
Error code e-68 won't clear the message. Dryer stops working
hi..
E68 error refers to "Current leakage to ground on heater or fuse opened".Problem with the fuse.Try getting it replaced.This can be done by any local repairman.Need not be a technician from Frigidaire,as they charge a lot for servicing. Good luck with the machine.
thank u
rate me!!
Jul 15, 2009 | Frigidaire Dryers
ERROR MESSAGE E 68
E68 error refers to "Current leakage to ground on heater or fuse opened".Problem with the fuse.Try getting it replaced.This can be done by any local repairman.Need not be a technician from Frigidaire,as they charge a lot for servicing. Good luck with the machine.Please do post results and comments.
Apr 05, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Error message & dyer stops
If it's new take your receipt and go to where you bought it and ask them to look into the problem.
Feb 25, 2018 | Dryers
Dryers Logo
94 people viewed this question
Top Dryers Experts
