Question about 2001 Toyota Tacoma Idle Speed Regulator 01 Toy
What when coming to a full stop and applying the clutch and the break sometimes causes a thumping sound or stuttering sound. At times when releasing the break and the clutch th
  • 71 Answers
You should only put the car in neutral then apply the brake.
If you continue to drive with the brake and the clutch it's going to burn out the clutch.
Just when you are coming up to a light take the shifter out of gear and then put it in neutral then apply the brakes.
You will notice the car will drive better
Hope this helps.
The stuttering and jerking motion means usually that you are starting at a to high of a gear or to low. The brake will cause the situation you are having. if you are applying it any time during shifting
Posted on Apr 17, 2015
  • sicnarf
    sicnarf Apr 17, 2015
    You,ve misunderstood what's happening. The thumping occurs when I apply the brakes.
  • Ron
    Ron Apr 17, 2015
    could be a cracked brake pad or the caliper sticking. Which means the hydrolic fluid is not able to release and it willl keep the brake on partially and make it vibrate. That would be my first guess.
Why does engine stutters when car is stopped
If you are talking about a missfire, you should have a check engine light and trouble codes stored in the engine computer.
Nov 03, 2015 | 2001 Hyundai XG300
Maytag top load washing machine 2 years old
This could be partly the clutch/break assy. You need to be able to run this with the lid open in the spin position. Activte the lid switch with a pencil or something. Reach in and hold the spin basket and then turn the washer on in spin. Hold this basket for 1-2 minutes then release it and let it reach full speed then stop the washer by turning the timer off or releasing the lid switch. See if the hard breaking/noise is better. Keep doing this untill it comes to a smooth stop and the noise is gone at the stop. Not sure this will cure the noise in the spin starting up problem or not, but start here. the clutch gets rust on the pads and this burnishes the break pads, removing this rust that makes it grab.
Goodluck..
Apr 05, 2008 | Washing Machines
There is a thumping sound coming from the rear end of my '06 Grand Prix. It isn't a constant thump and sometimes it happens when I apply the brakes
The thumping Would likely be warped rotors causing the pads to rock in the carrier, (Assuming the anti rattle clips were installed at the time brakes were replaced?) Turn or replace rear rotors
Jun 27, 2012 | 2006 Pontiac Grand Prix
What is the cause of continual thumping (appears to be coming from back of car) and violently shaking?
Many times, rear tires that are out of round or severely cupped or feathered, or that are out of balance can create this type of issue. My first recommendation would be to have them and the wheels on the rear of the car inspected. There may not seem like there is much wrong visibly if you look at just the tread of the tires, but a good tire tech can spin them up and give you some solutions, and the inspection itself is inexpensive. Hope this helps.
Jun 19, 2012 | 1997 Nissan 200SX
Ringing noise when the ac is off
This sounds like clutch interference. Sometimes the clutch breaks and causes a drag, but it all becomes "one" when the A/C in engaged. I suggest a close inspection of the clutch area. There is a release spec, for clearance, but this adjustment should not change, over time. All that matters is total release, without anything dragging.... Bet you have something in that area.
Nov 24, 2011 | 2001 Pontiac Grand Am SE
When stopping quick or rolling slow down hill to a stop you can feel a thump when you release the brakes
Have you got any other information about this problem. Have you inspected the brakes? Sometimes, if an axle seal is leaking, the drum will get saturated with axle grease and can cause the shoes to stick and bind until rolling breaks them free. Do you see any signs of leaking on the brake plates?
Oct 15, 2010 | 1998 Chevrolet K2500
2005 honda accord noise when breaking (transaxle)
You say you hear the noise when you "slow down". Does this mean you hear the thumping noise when you let off the gas and let the car coast to a stop or only when you are applying the brakes to decellerate?
If you only hear the noise while applying the brakes then I would assume it has something to do with your brakes. The first thing that comes to mind would be rotors that aren't true or warped which could make a thumping sound.
Do you feel any vibrations in your foot when it is applying pressure to the brake pedal? If you do feel a sort of pulsating feeling then it could very well be your brakes making the noise.
I hope I was of some assistance,
AadoubleA
Apr 04, 2009 | 2000 Honda Accord
2001 Toyota Tacoma Idle Speed Regulator 01 Toy Logo
98 people viewed this question
Top Standard Motor Products Vehicle Parts & Accessories Experts
Ron
Ron
Robert Rankin
Jeff Youtsey
Jeff Youtsey
Are you a Standard Motor Products Vehicle Part and Accessory Expert? Answer questions, earn points and help others
