I want to replace a Honeywell Q674L with a Honeywell RTH6580WF for my heat pump. Which wire is the common or C wire?
Old thermostat is a Honeywell Q674L 1207 and the heat pump is an older Trane.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
The old mercury Q674's didn't require a common terminal, so if there's not an extra wire in the bundle you'll have to fish one up... Inside the old Trane, there should be either a terminal strip with the appropriate terminal designations or possibly a bundle of color coded wires. If they are wires, originally they may have had individual tags on them, but if there are none, you're going to have to refer to the wiring diagram for the correct color for transformer common. Or... find the secondary of the transformer to determine the correct one, then extend it up to the new digital stat.
Posted on Apr 17, 2015
I have a Honeywell RTH6580WF Wi-Fi Thermostat that has "Cool On" or "Heat On" flashing in an endless loop. Could there be a major issue?
Pull the power red wire off the thermostat and batteries out if it has battery backup, then reinstall...much like a computer restart. If this doesn't work, then replace your thermostat.
Jan 21, 2016 | Honeywell RTH6580WF Wi-Fi Thermostat
I have a honeywell T87K round thermostat (2-wires R and W). I just purchased a honeywell WIF 7-day programmable thermostat RTH6580WF. How do I install the new thermostat? Is it even possible?
Programmable is in unit nothing to do wire fto urnace two wires cut furnace on and off you should have instructions to use two wires with your instructions
Aug 18, 2015 | Honeywell T87K1007 Mechanical Thermostat...
How do I replace an old White Rodgers thermostat with new honeywell TH5220
The Orange wire for the reversing valve and used with a Heat Pump
If you have a heat pump, then yes. If you have a gas furnace then no. If you have a HP and the reversing valve is not connected, then you might just be using the emergency electric heat strips. :-o
Jul 21, 2014 | Honeywell Th5220d1003 Non-programmable...
Honeywell how to install
Did you try E too aux and x1 to c?
Jul 20, 2014 | Honeywell RTH6580WF Wi-Fi Thermostat
RTH3100C thermostat for an older Lennox heat pump
well the wire on x will go to e thr r is the red wire goes to r the wire on f willgo to g the y will go to y now the rest you'll have to verfy at air handler o will go to reversing valve common wire will go to c the electric heat will go to aux
Feb 06, 2014 | Honeywell RTH3100C - Digital Heat Pump...
B3bm 048k b
You need to program with installation instructions. Press fan & up button @ the same time for a few seconds & go through the installer menu that comes with the thermostat to set it up for heat pump.
Dec 07, 2013 | Frigidaire Heating & Cooling
Honeywell thermostat RTH6580WF heat is ok but a/c doesnt cool
Same problem here. Gas, hot air furnace with A/C. Fan works with heat, but not A/C. Furnace is old, and I had to move the G wire to C at the furnace, plus install a jumper from Y to G.
Apr 10, 2013 | Honeywell Programmable Thermostat Heater
Wc wiring on thermostat
sounds like you have a heat pump the w2 on old thermostat is for a second stage heat. If you can give me a little more information on type of system you have (forced air furnace with heat/cool, Heat pump or boiler)? How many wires are on old thermostat? Is it a no programmable or programmable? How old is the furnace?
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
Honeywell RTH3100C
You need to go into the installer setting to change it from heatpump to single stage gas heat.Go to www.honeywell.com if youve lost them.
Dec 13, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
308 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
