Question about Powermatic 2 Electric Cigarette Injector Machine
How do you replace rubber pads on tube holder?
    New Friend:
  • 25 Answers
You need a rubber bumper
call them google it
Posted on Apr 02, 2016
  • Frank Hunter
    Frank Hunter Jun 02, 2016
    You stick a pin in it and pull it out while holding the plunger back
Need to know what moves the thing that holds the tubes on the machine
It is called the "cigarette holder" and has a replaceable "rubber bumper" on the end. Powermatic will send you a new one if you call when it does not hold the paper on as well as new.
http://powermaticinjector.com/c2instruct.asp
Jan 04, 2016 | Powermatic 2 Electric Cigarette Injector...
Tobacco only goes half way down thetube
inspect that the rubber piece that holds the tube.Chance's are that it is worn and needs to be replaced. it wont hold the tube all the way if it is worn. A quick fix is to cut a piece of eraser of a pencil and glue it to the holder.
Oct 10, 2014 | Powermatic 2 Electric Cigarette Injector...
Lose rubber from arm pad
Hi
This is a very common problem and unfortunately there are not universal pads that be easily put on for a quick fix. A cool trick I learned years ago is this..Go to your local hardware store and pick up some heat shrink tubing. Make sure the tubing is just larger than your ear piece. All you do is place the tubing over the area where the rubber is coming off and heat it up. This will secure the loose rubber to your frame.
Apr 18, 2014 | Blublocker Clothing Accessories
It-does-not-hold=the-wrap
Inspect that the rubber piece that holds the tube.Chance's are that it is worn and needs to be replaced. or it is missing.it wont hold the tube all the way if it is worn. A quick fix is to cut a piece of eraser of a pencil and glue it to the holder.
Feb 01, 2014 | Powermatic 2 Electric Cigarette Injector...
Absorber full
Cleaning the absorber pads is not too difficult. Switch the printer on with the cover open until the head moves to the left side then switch the power off. The print head should now be positioned away from the pads. Lift the two pads out of the rubber holders with a pair of tweezers or long nose pliers and then rinse in running water (no detergent necessary). They will soon become clean and white again. Do not twist to wring out the water, you may damage the pads. Gently compress to remove excess water and then use paper towel to blot the remainder. Let them air dry in a warm location like on top of a radiator. The wells in the rubber holder can be cleaned with cotton wool or paper towel before returning the two pads. Place the left pad in first, then the right pad and press down.
Dec 30, 2013 | Canon PIXMA iP3500 Printer
The water line that connects to the back top of the fridge busted loose. It looks like there is an adhesive pad that keeps it in place. How do I fix it? Scott
Hi Scott and welcome to FixYa, I am Kelly
The plastic line that connects to the ice maker rubber FILL tube is what came off. Check inside the freezer and squeeze the end of the rubber tube at the back of the ice maker. I would bet it is frozen with ice. (Hand held hiar dryer for quite a while to defrost the tube FYI and do NOT melt the plactic of the ice maker water funnel.) What causes the tube to freeze is the inlet water valve starts bypassing water when it is supposed to shut off. The result of this bypassed water is a frozen rubber tube and the plactic tube on the back of the refirgerator blows off or leaks. This inlet water valve is NOT repairable.
The Fix... Replace the inlet water valve and make sure the rubber ice maker fill tube is defrosted BEFORE re-inserting the plastic tube back into the rubber fill tube. It just pushes in and the adhesive pads for holding the plastic line in place are not critical even if they are lost. The rubber fill tube fitting will retain the plastic hose just fine as long as the ice maker end of the tube is not frozen from a leaking inlet water valve.
Thanks for choosing FixYa,
Kelly
Apr 14, 2011 | Refrigerators
How do you change the driver side low beam headlight
its easy open ur car bonit & c if there is battry there ,then lose ur battry clips & make some space for heand & then first pull ur light holder then rubber cover then there is lock on bulb open it & then finally with care pull up the bulb & replace it .
again same prossitur put the bulb or tube again then put lock on it then rubber cap then holder...ooh dont forget to tight battry clips again.....
its thats much simple.....tc
Mar 11, 2010 | 2001 Jeep Grand Cherokee
The uf585 takes in more than one sheet at a time
Open up the toner door
Hopefully the sep pad holder is still in the machine:
pull the operating panel up until it stops
remove the one inch wide blue tab by pulling it out
turn the rubber pad over.
reinstall blue tab..rubber part goes down
close operation panel
close toner door
Jan 23, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Installation of seperation rubber - Brother Intellifax 5750e
Pull open the document feeder.
Remove one screw on the chrome plate, pinch the legs of the pad holder to remove.
Sep 29, 2008 | Brother IntelliFAX 5750e Laser Fax
How to replace a tube holder or ballast
You can replace a ballast or tube holder if you're fairly familiar with wiring. 1) Turn off the power to the circuit. 2) Remove the tube and the cover plate that conceals the workings. 3) Disconnect or cut the wires to the tube holder or ballast and remove. 4) Strip 1/2" of insulation from the ends of the wires. 5) Mount the component and connect the wires with wire nuts. 6) Replace the cover and tube. 7) Turn the circuit back on. 8) Turn the switch on.
Jan 18, 2006 | StarTech.com CCTUBEGN 12.5''TUBE...
Powermatic 2 Electric Cigarette Injector Machine Logo
1,368 people viewed this question
Top Powermatic Cooking Experts
Frank Hunter
Frank Hunter
Level 1 Expert
Joe Huber
Level 1 Expert
ray gallant
Are you a Powermatic Cooking Expert? Answer questions, earn points and help others
