Stuck at "wait system powering up" - Office Equipment & Supplies
  • debbie johnson
    debbie johnson Apr 17, 2015
    on the 9201 xerox colorqube
I have a blaupunkt woodstock dab 54 and its stuck saying wait 1h HELP!
by default you have 3 chances to enter your code, after then time is get much longer for you to wait. what you can do is still keep your radio power on and leave it for 1 hour, Do not power Off. the cycle of wait will reset. then you can try enter you code again. hope its help.
Aug 02, 2014 | Blaupunkt Woodstock DAB 52 CD Player
"tray 1 cannnot be use currently " bizhub c-353
Utility/counter, touch details, stop00 stop01, touch system one, trouble isolate, select draw #1. set to unset. Turn main power off. wait 10 seconds, power on, go back in same procedure this time set to set. Power off again wait 10 seconds power on. ENSURE THER IS NO PAPER STUCK BEHIND THE TRAY FIRST, if this does not work get a qualified tech to look the problem
Jun 17, 2014 | Konica Minolta Minolta Bizhub C353 Copier
Mini hifi sony MHC-GZR5D the disk port is not opening and USB not responding.. A message saying (please wait) always shown on the screen , what I must do?
Try unpluging the power then wait thirty seconds then plug it back in. I have a feeling there is a disk stuck in it.
Terry
Mar 29, 2014 | Sony MHC-GZR5D MINI HI-FI SYSTEM FOR...
Tmax 9 tablet stuck on boot screen
  1. Shut off tablet
  2. press the volume minus button and the power button @ start up
  3. tmax logo shows up and then a android menu
  4. factory reset
  5. Once complete, reboot
  6. wait 4-5minute... tablet works again
Dec 26, 2013 | Tablets & eReaders
Need to know how can I open the 123 Bose system when the cheap CD is stuck inside it says it's open but it's not thank you
    • Turn off the device.
    • Disconnect the Acoustimass module power cord from the electrical source. Wait 60 seconds. Plug the cord back into to its power supply.
    • Hold down the "Eject" button.
Feb 01, 2013 | Televison & Video
Update CD Disc is stuck in wave music player, it didn't update anything for the multi changer and it will not eject. Stuck in "Loading" cd mode
Have you tried unplugging the player, waiting several seconds and then plugging it back in?This may reset the euipment and cause it to eject the update disc. Be sure to wait when it says wait. Do not force anything. You may damage the unit.Is this an entirely new system? If it is, find your manual and paperwork and call the company support number immediately.
Dec 27, 2010 | Bose Wave Music System CD Shelf System
Imac will not wake from sleep
Though not too common, this does occur every once in a while on many Apple desktops/laptops. Usually an anomaly in the running processes gets stuck and prevents the system from awaking while sleeping.
To kill the processes, press and hold the power button for 7-10 seconds (or until the system powers off). Wait about 10 seconds and then power on the Mac.
I recommend performing a system update after logging onto the Mac and downloading any system & application updates available (and restart, if necessary, to complete).
Aug 11, 2010 | Apple 20" iMac Desktop
Philips HTS3410D home theatre system. DVD is stuck inside - won't play, won't open. any ideas?
Power off the system
Unplug the power cord
Wait 5 minutes
Plug back the power cord
Power up the system
Press the open/close button
Load a DVD and play
If the tray still will not open, the cover will have to be removed and manually operated. You may have to have a technician look at the unit.
Please rate this solution - Thanks
Dec 27, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
DVD/CD door stuck on Bose 3 2 1
On the 321 systems turn off the power and unplug the power cord from the bass module. Wait 5 minutes and plug it back in. Then, simply hit the "stop/eject" button on the media center itself (do not turn it on first)..this should release the tray unless there is a mechanical failure inside the tray mechanism itself.
Thanks to Matthew O;Neil for the the tip,...Italo
On a Lifestyle system with a tray that won't open, try this: Turn off the power to the system and unplug the power cord to the back of the media center itself. Wait 5 minutes and plug it back in. Then, simply hit the "open/close" button on the media center itself (do not turn it on first)..this should release the tray unless there is a mechanical failure inside the tray mechanism itself.
If this does not work, then call Bose when you are home with the system at 800-367-4008.
Nov 05, 2008 | Bose (321GS) System
Disc is stuck in machine
When the try is stuck:
  1. Turn off the power.
  2. Unplug the power cord.
  3. Wait at least 5 minutes.
  4. Plug the power cord back in.
  5. DO NOT TURN THE UNIT ON !
  6. Hit the Open/Close button.
This worked perfectly for me!
drgeri
Dec 24, 2007 | Bose Lifestyle 38 System
162 people viewed this question
k24674
jasbo
jasbo
