Question about Ricoh Aficio Office Equipment & Supplies
Clear code SC542 - Aficio Ricoh Office Equipment & Supplies
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
Error 542 has to do with heat roller warm up. Ensure your thermistor is fine like wise your themostart. Also check if there is dirt on the surface of the thermopile, the check the continuity of the heating roller fuser lamp. Replace defective parts above.
Posted on Apr 19, 2015
  • odenigbo Ifeanyi Apr 19, 2015
    After the above checks and replacement do sc fuser reset in sp mode
How do I clear SC542 error?
That is a fuser fault code will need to repair fuser first. If you buy the fuser might come with instructions to reset code.
Oct 22, 2015 | Ricoh Aficio Sp 3510sf All-In-One Laser...
How do I clear error code sc542 on model 3510sf
go to maintenance mode. press clear/stop press 1 0 7 and start key(hold) until maintenance mode is displayed. look for fuser SC reset.
Sep 18, 2014 | Ricoh Aficio SP 3510SF
Error code sc545
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Aug 28, 2014 | Office Equipment & Supplies
CODE SC542
press clear mode key follow by 107 and hold the stop/clear key to enter sp mode power the copier off and on if the problem reoccur replace fuser unit and enter mode and off and on the copier
May 11, 2013 | Gestetner 3255 3265 3270 3355 3370 5502...
What is error code sc542
I found some information on this error at http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/
According to this website, the error code is due to a fuser temperature problem.
The Fix
In order to clear error SC542 follow these steps:
- Press and hold online + escape, then power on.
- Use up and down arrow keys to select SP2
- Press Enter
- Use up and down arror to locate SP5
- Press Enter
- Use up and down arrow keys to select 810
- Press Enter
- Confirm the selection
- Power off and on.
Kindly rate this solution, thanks!
Mar 08, 2011 | Ricoh Aficio 3025 All-In-One Laser Printer
Errore sc542
Error SC542 indicates a fuser temperature problem.
you must perform procedure 5810.
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
Good Luck!
May 07, 2010 | Ricoh Aficio 1085 Laser Printer
Error sc 547
Found this from:
http://slayo.com/ricoh-cl4000dn-error-code-sc542.html
Ricoh CL4000DN Error Code SC542
Turns out error SC542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won’t come ready until the prior error condition is cleared.
A few phone calls with our local Ricoh service rep, and he admitted that the printer might trip this error in a power brownout.
The printer was less than 30 days old and the error was caused by the brownout or the fuser failed. I kept calling the Ricoh rep, and they finally gave me the magic keystrokes over the phone.
I did the magic keystrokes, cleared the error code, and the printer worked fine. It’s been working great for a year now.
I hope someone else who has this problem finds this page and is able to fix the problem also. I didn’t find any help on the net when I searched.
The Fix In order to clear error SC542, you must perform procedure 5810.
  • Press Enter
  • Press Enter
  • Press Enter
  • Power off and on.
Hope this helps!
WizardRepair
Jul 17, 2009 | Ricoh CL4000DN Laser Printer
Error sc542
"clear modes", 1, 0 , 7, then (hold) "clear/stop" for a few seconds until "sp mode" comes up. turn main power off/on (red switch).
If code comes back there is trouble with the fuser that needs to be repaired to clear code permanently.
Apr 21, 2009 | Office Equipment & Supplies
SC542
sc 542 is when the machine cant warm up to temperature for whatever reason usually entering service mode via clear 107 clear stop and rebooting clears the code if that dosnt work then the next step is call a service engineer
Feb 19, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
60 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
