Question about Ovens
The number buttons on the key pad are not working, they seem to be stuck. This is not allowing me to put the temperature setting for the oven.
  • Anonymous Apr 20, 2015
    Key pad numbers are stuck. So it's not allowing me to set the temperature for the oven.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 169 Answers
Try resetting the circuit breaker switch on the panel for power also call the manufacture ask for tech support they can help
Posted on Apr 20, 2015
SOURCE: Preheating
hummmm this sounds similar to what is happening to me. I am praying someone will have a solution, I don't want to have to explain to my daughter who is going to be 4 tomorrow, why I can't bake her cake.
Posted on May 13, 2008
SOURCE: whirlpool oven accubake system
I have a whirlpool accubake wall oven. Half-way through baking a pie ,unknown to me, the oven went to the self-clean mode , the door locked and the pie started to burn. I tried to turn the oven off but it would not cut off. I immediately ran to the house's main power and turned off the oven breaker. I waited for a short time to let the oven cool enough to open the door and get the burned pie out, then went back to turn my breaker back on and the oven (even though in the off mode) started heating again with the bottom unit turning red again. I had to then go back and pull the power. We tried this several times trying to push the off button but the oven will not go off until we throw the breaker. Help please!
Posted on Nov 11, 2008
barkencoa
  • 3463 Answers
SOURCE: creda concept solar plus oven timer
Hold down the 2 left buttons together, and press the + or - button at the same time..
This should reset the timer.
Please leave a fixya rating for my solution.
Thanks.
Posted on Feb 12, 2009
  • 14 Answers
SOURCE: fagor oven will not work after power cut
TIMER
Posted on Feb 15, 2009
  • 163 Answers
SOURCE: Maytag gas oven touch-pad control panel does not work proplerly.
you can replace touch pad and not very hard to do,you may want to replace control board also.
Posted on Mar 12, 2009
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Tip
    Fault Codes for Admiral Range/Stove/Oven
    There are many fault codes for different ranges, ovens and stoves. These also are different for each manufacturer or brand. To see what the fault codes are and what they mean for the Admiral brand you can check this chart. It also will give you a short explanation and repair for each code.
    Some of the repairs are simple and some of them are much more difficult.
    Most parts are easily bought online. Check the link below to another tip I wrote about how to buy parts online.
    Fault code What is wrong What to check or repair
    F1 Defective touch pad or Replace touch pad or clock assembly
    Membrane this also can be called the ERC
    F1 Watchdog on board Replace the touch pad or ERC
    F2 Oven too hot Replace the relay board or oven temp
    sensor
    F3 or 4 Open or shorted oven Replace oven temperature sensor
    Temperature sensor
    F5 Hardware and watchdog Replace clock assembly or ERC
    circuits disagree
    F6 Missing AC signal Check for proper voltage
    F7 Function key shorted or Un-stick button or replace touch pad
    stuck button /ERC
    F8 Analog/digital trouble Replace clock assembly/ERC
    F9 Door latch trouble Check door lock circuit or ERC
    F0 Function key stuck Replace touch pad or ERC
    http://www.fixya.com/support/r3907570-buy_appliance_parts_online
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
    on Feb 18, 2010 | Ovens
    Key pad stuck
    SHUT THE BREAKER OFF TO THE OVEN FOR AN HOUR, THAT WILL RESET THE OVEN CONTROLS
    Nov 11, 2009 | Ovens
    Error message F7 on my oven
    F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the (ERC)= Oven control board
    Sep 14, 2009 | Ovens
    The number pad is not working.
    did you try shut off brakers one more time? wait for a min or 2 and put it back on..see what is happend....but most likely you need new touch pad
    Aug 25, 2009 | Jenn-Air Ovens
    What does an F1 fault indicate
    MAYTAG
    Range/Stove/Oven Fault Codes Failure
    Code
    Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC) * Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1:
    - Disconnect power to the range.
    - Gain access to the back of the ERC (electronic range control, or "clock").
    - Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide.
    - Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC.
    - Turn the power back on to the range.
    - Watch for the F-1 and listen for the beep.
    - If you get the F-1 and beep, replace the ERC.
    - If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control.
    Warning: If you do not feel comfortable doing this test or making this repair please contact a qualified appliance repair technician.
    Jun 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    F2,F5,F7 message
    MAYTAG
    Code
    Feb 07, 2009 | Maytag MEW5527B Electric Single Oven
    Oven temperature only gets to within 20-25 degrees of temp. set
    next to last page in your manual
    Adjusting Oven Temperature
    Oven temperature has been factory calibrated and tested. If
    oven consistently over or under cooks food, adjust thermostat.
    Oven temperature can be increased or decreased 35°F. To
    avoid over adjusting oven, move temperature 5°F each time.
    1. Push BAKE pad.
    2. Press + pad until an oven temperature greater than 500°F
    shows in display.
    3. Immediately push and hold, approximately 5 seconds,
    BAKE button until “00” appears.
    4. Press + or - arrow pad to adjust oven temperature.
    • To increase oven temperature (for a hotter oven), Press
    pad until a positive number appears in display.
    • To decrease oven temperature (for a cooler oven),
    Press pad until a negative number appears in display.
    5. Press OVEN CANCEL pad to save adjustment.
    • Setting is saved if power fails or is disconnected.
    heres a link to the entire manual if needed
    http://shop.amana.com/assets/pdfs/literature/32103601.PDF
    Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
    Oven not working
    15
    problem
    8. door will not open.
    9. oven will not heat after Self cleaning.
    possible Cause
    oven is in Self-clean mode.
    time of day is not set due to power failure.
    oven settings are not correct.
    remedy
    if oven is hot, door latch will release
    automatically when oven temperature
    falls below 390˚F at end of cycle.
    if Self-clean was just selected
    and the oven is still cool, press
    “caNceL•SecuRe” to turn off Selfclean.
    the door will open in about 30
    seconds.
    Press “cLock” touch pad, then press
    “tiMe•teMP” pad to set correct time of
    day.
    follow mode selection and clock settings
    as specified in the oveN oPeRatioN
    section.
    oven will turn on automatically
    at preset time. if desired, press
    “caNceL•SecuRe” touch pad to cancel
    out of delay timed mode.
    Troubleshooting Guide (Continued)
    Important:
    If a Failure Code is displayed, the oven will beep continuously until the user presses the “CanCel•seCure” button. the oven will not heat
    after a failure. Call a qualified appliance technician to repair the oven.
    Oven Failure Codes
    Clock Display Cause
    f0. touch pad is stuck in depressed position.
    f1. Relay circuit failure.
    f . oven temperature exceeded the clean runaway temperature (Self-clean mode
    only) or the cooking runaway temperature (cooking modes only).
    f3. Short circuit in the oven temperature sensor.
    f4. open circuit in the oven temperature sensor.
    f6. failure in the eePRoM check comparison. (only time of day and timer will
    operate.)
    f7 failure of the Self-clean automatic door latch circuit.
    f8. failure of the door latch motor. occurs when the motor runs for two minutes
    without the door locking in Self-clean mode.
    befOre yOU Call fOr servICe
    No maintenance, other than the Care anD CleanInG
    InstruCtIons identified in this use & Care manual, should
    be attempted by the owner/operator. all other maintenance and
    service must be performed by a qualified appliance technician.
    first, review the recommended checks listed in the preceding
    troubleshooting Guide. then, be certain that the appliance has
    been installed properly and is being operated correctly. familiarize
    yourself with the warranty terms and conditions listed in the
    proDuCt WarrantY section.
    if the above checks have been completed and the problem has
    not yet been remedied, call your local authorized dacoR®
    service representative. your dealer can normally provide the name
    and telephone number of the nearest service company.
    prOdUCT maInTenanCe
    If yOU need servICe...
    dacoR® works diligently to ensure your satisfaction when
    service is necessary. However, if you are not completely satisfied
    with the service provided, contact the company that performed the
    service and express why you are not pleased. Normally, they will
    be willing and able to resolve the problem.
    if the service agency is not able to respond effectively, call or
    write the dacoR® customer Service department. the phone
    number and address of this department are listed on the inside
    front cover of this manual. Please include your telephone number
    if you choose to write. we will then do our utmost to assure your
    happiness and satisfaction.
    Here is a snipet from www.dacor.com
    You can view the manual there by enter ing your oven model number.
    Feb 22, 2008 | Dacor ECD230 Epicure Electric Double Oven
    Jenn-Air WW30430W double oven flashing F7 and beeping
    It seems you have a stuck button. Here is a list of fault codes:
    JENN AIR
    Failure
    Code
    Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
    Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
    Ovens Logo
    56 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
