Question about Brother MFC9320CW All-In-One Printer
What can be done to improve print quality?
My printer isn't printing very well and we've replaced the ink and the toner.
  • 108 Answers
SOURCE: Brother HL 1440 Printer Density Adjustment
Go to Printer and Faxes and select the properties button, then select the maximum dpi in the Advanced tab. You will get the best quality Print
Posted on Feb 08, 2008
alphacheese
  • 68 Answers
SOURCE: BROTHER MFC-210 PRINTING IN BLACK INK POOR QUALITY
Try cleaning the black printer heads several times in a row, at least 5 times then print a black document with best quality setting.
Press the ink button, then down to select select cleaning and then press menu/set and menu/set again to select black.
Posted on Jan 08, 2010
komguy
  • 2306 Answers
SOURCE: Fulll ink cartridges but paper blank after printing
I've tried many kinds of cleaning and nothing helps save the old printhead. The only repair is to replace the printhead which costs around $100.00 for the part alone. It's not easy and should be done by a shop but a new machine would be less than the repair and you start again with a one year warranty.
Posted on Jan 29, 2010
Testimonial: "Thanks for the tip - I shall have another go with the cartridge first, otherwise I might take your advice and just buy another printer. Just my luck! "
SOURCE: Brother 5240 laser printer changed toner still wont work.
This works on several different Brother Printers to get rid of toner/drum empty errors:
1. Open the front cover and leave open while completing the following steps.
2. Turn the printer off.
3. Hold the 'go' button while turning the printer on. All panel lights should be on.
4. Release the 'go' button.
5. Press the 'go' button 2 times.
6. Pause.
7. Press the 'go' button 5 times.
8. The toner light should be off.
9. The paper light should be on or flashing [doesn't happen on all].
10. Close cover. The ready light should be the only light on.
Posted on Feb 05, 2010
  • 22 Answers
SOURCE: The printer quit printing and the toner light came
Is the printer still asking for a new toner..?
If it is the there is a gear that can be reset on the toner cartridge to tell the machine its a new toner cartridge. This is normally done by an engineer, but is quite easy to do if you know how. And I do :0
Posted on Mar 07, 2010
Yellow ink faded on one side of copy
Ink News - How To Correct Faded Prints From Toner ...
www.inkpal.com/ink.../tips-to-correct-faded-prints-from-toner-cartridges...
Rating: 3 - ‎12 votes
Mar 30, 2012 - You should particularly suspect this if the prints are faded on only one side and if the printer is not telling you to replace the toner cartridge.Missing: yellow
HP Officejet 6500 Printers - Fixing Print Quality Problems ...
support.hp.com/us-en/document/c01641184
Jan 16, 2016 | Office Equipment & Supplies
Brother DCP-350C magenta ink won't clean and print quality check shows multiple visible gaps
You have a blockage in the print head and/or feed line from the ink cartridge to the print head. One possible fix would be to make a pad of paper kitchen towel wet it and sit the print head on it overnight. With luck the pad will soak the blockage and draw ink through the head. Give the machine two self cleans and try a print quality test to see if you have made ANY improvement. If no improvement - forget it as the blockage has been there too long.
Oct 30, 2017 | Brother DCP-350C InkJet Printer
S605 ink printing patchy
A firmware update for your model addresses print quality issues. Please visit the Lexmark website to download and install the Lexmark S400 Series Firmware Update. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct.
Try to print again to verify that the print quality has improved.
Should the problem continue, it could be that the printhead itself is the problem. Please contact Lexmark Technical Support Center for assistance.
Feb 04, 2012 | Lexmark Interact S605 All-in-One Color...
Not printing magenta
Print quality issues could be due to dirty or clogged print cartridge nozzles. Please follow the steps below to improve the print quality:
On the printer operator panel:
  1. Press Copy.
  2. Press Options until Maintenance appears on the display.
  3. Press the right arrow until Clean Cartridges appears on the display.
  4. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  5. Print your document again to verify that your print quality has improved.
Using the Lexmark Solution Center:
  1. Click Start > Programs > Lexmark X6100 Series > Lexmark X6100 Series All-In-One Center.
  2. From the Maintenance tab, click Clean to fix horizontal streaks.
  3. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  4. Print your document again to verify that your print quality has improved.
If the problem continues, try to insert a different known working cartridge or better yet replace it with a new genuine Lexmark cartridge.
Should the problem continue, please contact Lexmark Technical Support Center for additional assistance.
Oct 11, 2011 | Lexmark X6170 All-In-One InkJet Printer
Lexmark x6170 not printing magenta
  1. Press Copy.
If the problem continues, try to insert a different known working cartrdidge or better yet replace it with a new genuine Lexmark cartridge.
Hp7280 AiO, firmware VlxxFN0724AR, Photosmart Driver 4.3, Productnr. CC567 with 10.3 AiO software running on an iMac 10.6.8, latest updates done- does not print magenta, new cartridge inserted (no...
Hi Collin, These HP's are known to be somewhat of a pain, not a great printing system, but to be honest I not a fan of inkjets of any discripition, such a messy and costly way of acheiving a colour print. Give me a Oki or Kyocera Laserprinter/toner based print system anyday but that for you to think of for the future....
I also find many issues with ink quality of refills (toner and ink refill quality causes 9 out of 10 print quality service calls, great for business;)
But if you have found a constant reliable medium then that shouldn't be the issue, but if a cartridge wasn't performing correctly then you insert one that does you will have to prime the good ink threw the system before you will see any result, and is seems to me that the real issue is some but not all of required quanity of magenta ink isn't flowing threw to you prints hence faint and streaky, have you tried fitting a known good ink and priming a few times? Heres the instructions from the web, let me know how you go, theres not many options really but I always start with known unquestionable good ink, just because 9.5 out of 10 times it is the issue and to fix or to write off stuff with any certainy you got to start from a solid starting block.
Please follow this procedure and tell me if it improves you mag image at all
Try doing the priming session about 3 times in a row without testing & then do a self test print-out. I have seen about a 25% success rate. Hold down the (OK & HELP) buttons & keep them held while plugging in the power cord & if it doesn't automatically power on then also hit the power button. Keep the OK & Help buttons held down till the printer turns itself off all by itself or goes right into the priming session. If it turns off then let go of the 2 buttons & just hit the power button once & it will go right into the priming session for about 4 minutes .
Cheers
Steve
Oct 06, 2011 | HP Photosmart C7280 Printer
The printer has been working great - now it is printing really poor quality prints. I have had it self clean with no improvement. A piece of paper could be stuck in it but I do not know. How do I open...
if it is printing really poor quality it will be the toner.
You will need to by a maintaince kit for it.
The drum will need to be cleaned and the toner replaced.
This is something that you may want to get done by a profesional as it is very messy.
Mar 02, 2011 | HP Color LaserJet 2600n Printer
MY LEXMARK 4505 LEAVES 3-4 BLACK BLOTCHES ON THE EDGE OF EACH PAPER IT PRINTS, TRIED CLEANING THE ROLLERS TO NO AVAIL, ANY SUGESTIONS
ADJUST THE COLOR AND PRINT SPEED You may need to adjust the color and print speed. CHECK THE LEVEL OF INK IN THE PRINT CARTRIDGES 1 From the Finder desktop, double-click the Lexmark X5400 Series folder. 2 Double-click the Lexmark X5400 Series Utility icon. 3 From the Maintenance tab, check the ink levels of the cartridges. If an exclamation point (!) appears on a cartridge, the ink level is low. Install a new cartridge. Improving print quality These are possible solutions. Try one or more of the following: CHECK PAPER • Use the appropriate paper for the document. If you are printing photos or other high-quality images, for best results use Lexmark Photo Paper or Lexmark PerfectFinish Photo Paper. Do not use Lexmark Premium Photo Paper. Your print cartridges are not compatible with this type of paper. • Use a paper that is a heavier weight or bright white. CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" on and "Installing print cartridges" . If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts". If print quality is still not satisfactory, replace the print cartridges. For more information, see "Ordering print cartridges". CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page 124. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" and "Installing print cartridges" If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts"
Nov 10, 2010 | Lexmark X5495 All-in-One &USB...
Poor quality since changing ink.
If you didn't have this problem with the last toner than more then likely the new one is deffective. It seems to be having a ghosting issues which happens when the dr blade inside the toner does not clean properly. You need to try another toner cartridge.
Jan 07, 2009 | HP LaserJet 1022 Printer
Brother MFC9320CW All-In-One Printer Logo
67 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
