Question about Vacuums
How do I get access to the wire connections? - Vacuums
    Top Expert:
  • Vacuums Master
  • 10,875 Answers
Without any info,,i;e,,make,model,year,
problem,,WHAT KIND OF ANSWER
DO YOU EXPECT???
Posted on Apr 17, 2015
  • Vacuums Master
  • 932 Answers
Melville,
We need more information from you as to the brand and model of the vacuum that you are referring to so that we can better help you.
How can I access the wiring behind the plastic that connects to the motorized head?
If your model is a DC07 as stated there is not a separate motor that runs the brushroll. The brushroll spins from a belt that comes from the main motor or goes through a clutch assembly with two belts. If it is a ball model and the wires have severed you will need to replace the wire or wires with the proper replacement parts for it to work properly. I would need your model number to determine the proper wat to fix it.
Mar 25, 2016 | Dyson DC07 Animal Bagless Upright Cyclonic...
Pro12commercial won't turn on
Probably a short in the wiring, a bad switch, or you could have a wire that has come loose from it's connection. If you have access to a multimeter, I would use that to work your way through the vacuum to see where the fault is located. Good luck!
Oct 22, 2014 | Oreck PRO12 Commercial Upright Vacuum,...
When vaccum is tilted back suction does not engage.
This can happen if two tiny wires that are connected to the circuit board and lead to the beater bar are broken. These wires brake where they go through a black rubber grommet. You need a torx screwdriver (No: 15) to remove two plastic covers to access these wires . When looking from the front of the vacuum, the circuit board is located under the gray covers on the right side of the vacuum. There is one big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
Once covers are removed check both yellow and blue wires carefully. Wires may look intact but the break may occur inside the black grommet. Slowly and carefully push grommet out and then carefully pull wires to the one side. If a wire is loose or broken you will immediately see the break. You can replace wires using replacement part given below or if you are OK with using soldering iron you may be able to repair broken wires without any expense.
Best solution is to replace broken wires with a new set of wires and connectors having fed the wires through the access hole making sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
  • UK: Dyson DC15 Loom BB Over Current, Part No: 907280-03, Approx. Pounds 4.45
  • US: Dyson DC15 PCB to Yoke Loom, Part No: 907280-02, Approx. $11.75
See more details and photos at: http://bajwa.net/content/dyson-dc15
Feb 20, 2013 | Dyson DC15 All Floors - The Ball Bagless...
Doesn't turn on
Gain access to the electrical connection with voltmeter set to 110 v ac check for voltage on both sides of switch. If voltage is present on outlet side follow output wire to start relay ck for power on out put side of relay. if power follow output wire to motor if voltage is present replace motor ! Be careful where you touch when probing contacts !
Dec 29, 2012 | Kenmore whispertone 100 model 116
Panasonic MC-E450 vacuum cleaner wiring connection access
Disconnect from power first!!
Undo the three screws.
Tap the base of the handle assembly from the front and it will slide back so it can be removed
With the handle removed, pivot up the bottom of the electrical box cover and it will unclip at the top edge.
Mar 01, 2010 | Panasonic Vacuums
While operating machine, brush does not rotate. Button is pushed in, all hair cleaned off brush. Is there a reset button? Where is it located?
Likely the wires are broken under the left hand cover not a difficult fix. Unplug the machine and remove the 4 torx screws and an access panel at the side of the ball. replace wires with new or re-connect with a splice. ensure wires are long enough to allow movement and you don't trap the wires when you replace the covers. about a 20 min job with the right tools
Sep 26, 2009 | Dyson DC15 All Floors - The Ball Bagless...
How to rewire a panasonic vacuum cleaner
Once you have taken the handle off and the front plastic cover below the handle at the front and above the bag/bucket holder, you gain access into the power cable and switch connections.
One wire will disconnect easily, the other won't, so instead of trying take this wire out of its connection where many others are from the switch and the motor, cut it on the mains lead before it enters the connection and reconnect the new mains lead wire with a **** or block connector, the other should connect normally with a spade connecter,making sure its will take the amperage of the v/cleaner
Hope this makes sense!
Sep 18, 2009 | Vacuums
Beater brushes don't work, what to do? They only work when the canister is in about an 85 degree up position.
This appears to be a loose connection. The below post was answered by highntools a while ago. It probably is related to you problem.
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
There have been several people who reported loose or burnt wires to be the culprit for the brush bar not working. The DC15 does not use a belt, but a motor that is control by the circuit board. And I really believe that in your instance, the problem is a loose wire between the circuit board and the brush motor.
Jul 12, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Access to panasonic mc e450 electrical supply panel
Disconnect powe
Remove three screws
Tap base of handle from front - it will then slide back
remove handle
Pivot bottom of cover over electrical box up and it will unclip from the top edge.
Sep 06, 2008 | Hoover Vacuums
Vacuums Logo
53 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
