How does it work? I need to connect it yo my tv to bring up channels
    Habit-Forming:
  • 146 Answers
Your question is too generic to answer, please provide more information as to what you are trying to do. Get channels using a tuner? Are you using a cable box or satellite receiver? Please indicate Make and Model of television. Perhaps I could be more helpful with additional info.
Posted on Apr 18, 2015
I am trying to get a picture on my tv. Since it was hooked up to a satilite receiver prier, I think the problem is the tv is still on Digatal instead of air/antenna. But I do not know how to bring up...
You will need the remote that comes with the tv if there is no menu button on the tv itself to bring the menu up. Hit the menu button and will want to go to the channel option and change it from digital to analog or even just scan for new channels. But honestly, when working with a satilite box you will usually not use your cable or antenna jack in the back of the tv so you might just need to change the input of the tv to get your channels up.
Sep 08, 2011 | iLO Televison & Video
Tip
Digitial channel tune in and set up
if you have a problem getting digital channels (uk) find local channel number digital uk can help enter tuning menu go to manuial tune on tv or digi box. it will ask for channel number start with highest number pess ok or search repeat for each channel number normal 4or 5 depends on aera if still not getting all channels put aerial lead which come for aerial into tv bypassing any equipment such as vcr/dvd recorder then start again if still not all channels may need aerial upgrade .if yo get all channels connect vcr/dvd if some channnels disappear need to reset RF out on vcr/dvd remove aerial .connect vcr/dvd via scart reset RF out on vcr/dvd this can be found in vcr/dvd set up menu reconnect all leads should now work ok
Note do not set RF out to any digi channel numer
on Aug 17, 2010 | Televison & Video
I have a parasound 5250 5 channel amp. Channel one is not working. Is there a fuse?
hi, there is no fuse on amplifier output only power supply, the problem is some parts of electronic that drives into audio output of the amplifier maybe are shorted like transistors, diode or amplifier Ic's. bring it to a nearest service center to check it. or if you have a knowledge in technical yo can used multi tester to check it. Note: unplugged it first before you open the cover to check it. thanks
Mar 28, 2011 | Parasound 5250 5-Channel Amplifier
I have cable but only can get up 26 channels .i don't a remote control so can yo tell me how t program my channels
You have cable, but are you using a cable box? Sounds like you are running coax direct to the TV. Is this correct? If so, you will need to get into the menu of the TV. Locate "Connections" or "Cable Source" and select "Cable" not "Air" and then let it auto format. Will take several minutes. It will only make available the channels that come in through that line. Let me know if this worked.
Jul 01, 2010 | Durabrand BH1304D 13" TV
Although the Freeview box is correctly installed with my TV,when the men button is pressed the only message to appear on the TV screen is No Signal,HELP!!
Ok, if you have "No Signal" that can only mean you must be selecting the wrong INPUT, when it is hooked up yo the TV, essentially the TV, is just a Display Monitor, and it doesn't use "Channels" anymore, it uses the AV, or EXTERNAL Inputs, any channel changing is done on the Freeview box. Make sure you are connected color to color, cables are connected. The antenna, goes into the freeview, the AV cables go to TV, taking the Video 7 Audio, from the Freeview box, to the "Screen" TV, set to the External input, that the "Box" has been connected too. Check your manual out.
May 08, 2010 | Televison & Video
Akai TV volume control stuck on 100%
try leaving the set unplugged for several hours, this will reset it to factory settings. If this does not work you need service.
Jan 10, 2009 | Akai PT5492S 54" Rear Projection...
No signals found when searching for channels at setup
you need to press the channel up button 3 times if yo get message as please connect av sources. then do the manual channel search for 2 times. it should solve the problem.
Oct 13, 2008 | Sanyo DP32746 32 in. LCD Television
Frozen on a menu screen
Just fixed ours with the same problem. You need to hit the volume buttons on the remote during the time the screen goes black but BEFORE it gives you the "Connect cables" message.It should trick the TV into giving you a blank channel.
Sanyo TVs are made notoriously cheap, and have little glitches like this. Best of luck, space cowboy.
Oct 13, 2007 | Sanyo HT27546 TV
Tv only has select channels
If you have a good cable signal connected to the TV and it receives channel 50 nice and clear but all lower channels have nothing but snow, then the tuner is defective and needs to be replaced. This is quite an easy thing to correct. Sometimes resoldering all connections inside the tuner will bring it back to life, but in either case the set should be serviced by a qualified tech.
Aug 23, 2007 | Toshiba 36AF43 36" TV
The universal remote does not bring up the menu so I can program all the cable channels in it. I don't know what to do. It is only receiving non cable channels. Help me so I don't have to keep watching...
alot of universal remotes dont let you program your tv with them due to how much more mem they would need. you have to use your actual tv remote or do it manually with the tv. sorry
Jul 29, 2007 | Sharp 13VT-R100 13 in. TV/VCR Combo
Televison & Video Logo
Top Televison & Video Experts
