Question about Ricoh Aficio SP C420DN Laser Printer
My Ricoh Aficio SP C420DN Laser Printer shows color tone SC366 and some time SC365, any ideas?
Question about Ricoh Aficio SP C420DN Laser Printer SC366 and some time SC365
    New Friend:
  • 142 Answers
You just have a problem with colour PCU (SC 365 - magenta, SC366 - cyan). The main reason is that toner density is abnormal. Sometimes, when you replace toners, printer receive to much toner for a short time, and after that you have an abnormal toner density (higher). You can check in service mode (hold up and down arrows for 6-7 sec, release them and press ok button) following thing :
choose 2. engine
then with arrows choose 3. process
then choose Vt display,
for each color by default there should by somewhere arround 2.4V. If you see for some colors, for example 0.02V, then this is a problem(to much toner). In this case the only thing that you can do is to restart printer and try to print enough pages, filled with problem color. Usually you can print max 3 pages. Then restart printer and try another 3 pages. Print until the you will be able to print at least 4 pages continuously.
Good luck and remember that this is a technical problem and you should ask someone qualified for the job. I am sure that 80% of service engineers can't repair this issue. But I can.
Posted on Apr 17, 2015
Testimonial: "sory I printed blue paper, but the problem persists"
  • pifonski Apr 18, 2015
    i am doing technical support for Ricoh from 15 years. I have more than a 200 Spc420 printers hardly working in many diferent offices. Just check toner density for each color in service mode. LEAVE THE LASER ALONE.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
That code can indicate that the laser is no longer functioning and needs replacement.
Testimonial: "The Colour Blue ??? or waht"
  • Ted Baxter
    Ted Baxter Apr 18, 2015
    Laser either works or it doesn't on all colors. Take out the intermediate transfer unit which sits above the 3 color pcus and the one black pcu. Once removed, use a flashlight to look at each of the PCU's. Does one of the PCU's have a line of toner along the length while the other's are clean? If so, that pcu is not rotating. That would mean the gear that rotates the pcu is not engaged with the pcu. The gears can get stuck in a locked and disengaged position. Put some grease on the gears and pull the gear back and forth with needlenose pliers.
How to clear functions
Open left printer cover. Open PCU cover. Pull Magenta, Yellow and Cyan PCU units and check which one has blocked!!! Probably you will need to replace color PCU (type 145). Good luck
Sep 30, 2014 | Ricoh Aficio SP C420DN Laser Printer
What could be the problem on ricoh printer sp c420dn its given me error code sc 364
Probably you have just replace some of the toners (black). The toner density is too high. Restart printer and try to print full A4 black page.
Aug 30, 2014 | Ricoh Aficio SP C420DN Laser Printer
What the solve Ricoh Aficio c420dn error code sc304
Check your charge roller. . Try replacing the charge roller.
Jul 06, 2014 | Ricoh Aficio SP C410DN Laser Printer
Ricoh SC 490
In an SPC420 color printer the issue is that the PCU is not turning for one of the colors. The sprockets that drive each of the color PCU's should be checked. Sometimes they stick and need lubrication. With the printer off, remove all the PCU's and look at the black, plastic sprockets that turn the color PCUs. See if one is recessed and unable to slide forward like the others. Place some oil on the sprocket and use the needle nose pliers and push the sprocket in and out until it slides without catching on the rod it is mounted on. Like a dentist trying to pull a tooth.
Jun 13, 2012 | Ricoh Aficio SP C420DN Laser Printer
I have ricoh laser printer aficio sp c420dn showing error code SC270
sc270 is an error with the shutter on the laser unit. Turn the machine completely off and then back on -- if the error doesn't clear, the shutter sensor or motor will likely need to be replaced.
Feb 16, 2011 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio SP C420dn Printer. The printer at
sc491 is a high voltage output error. Combined with your jamming issue, it sounds like a possible electrical problem somewhere. A good first step is to turn the machine off and unplug it, then take off the covers and reset any connections or cables you can get to.
If the problem persists, you should have a service technician take a look at it because it might need a board replaced.
Apr 27, 2010 | Ricoh Aficio SP C410DN Laser Printer
Ricoh SP 8100DN will not load toner
The SP 8100 is a BW printer only, it doesn't take color toner.
Mar 23, 2010 | Ricoh SP 8100DN Aficio Laser Printer
Ricoh Aficio SP C420DN Laser Printer Logo
823 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
