Question about Garden
As these granules dissolve slowly, how long are they harmful to pets or wildlife?
I spread these granules as directed. If I still see them are they hurtful to any animals and still poisonus as they dissolve?
5 Suggested Answers
ghappliances
  • 126 Answers
SOURCE: soap problems
PLEASE TELL ME WHAT TYPE OF SOAP YOU ARE USING AS WELL AS RINSE AID.NEED MORE DETAIL TO ASSIST YOU.
MOHAMED
Posted on Sep 19, 2008
  • 60 Answers
SOURCE: automatic dishwashing detergent granules do not dissolve
Did you switch brands of detergent?
You mentioned that the diswasher is old can you check the nozels of the wands to see any of them are plugged near the ends this will affect wheather the water is reaching the door.
Hope this helps
Al
Posted on Sep 11, 2009
motor1258
  • 6674 Answers
SOURCE: I have a Rheem's Model # 81V-80D Water Heater. The
Not uncommon for calcium etc to build up in water heater, from water pipes, and water itself. (hard water) Simply removing aerator and screen etc and cleaning it will usually take care of it, but if too dirty, soaking in C.L.R. will help, or for a few bucks just replace it from hardware store. Just make sure you take old one with you to match it up, as there are many that look the same but aren't. You may also help the situation by shutting off power to water heater, allow it to cool, and drain it out, which should remove some of the calcium laying in bottom of water heater. I've had some with such a build up over the years, that I removed the element to look inside and it was right up to the element. Used a shop vac, with piece of 1/2" plastic line taped to it and sucked out as much as I could. Took about 1/2 hr, but got most of it out of there.
Posted on Jan 11, 2011
tpfann
SOURCE: the detergent dispenser opens but the cascade
I place the finish 2 in one tabs in the pre soak tray and that solved the problem. The red sphere is the pre soak, which gave me the idea. Not sure if it will work with cascade
Posted on Jul 03, 2015
What setting to spread 16-16-16 on lawn
Whatever gives you an average spacing of 2 inches (5 cm) between granules. Adjust more or less for personal preference for how much you like mowing.
Jun 15, 2017 | Garden
Tip
Drain runs slowly
Often a drain runs slowly or hardly at all taking a long time to empty out. My tip is to wait for the drain finish emptying and then pour in about three cups of household bleach, and let sit for at least 6 hours. The bleach will sit on the obstruction and beak up and dissolve most objects such as soap residue combined with hair etc. without harming your pipes.
The other plus is that in cases where the blockage becomes worse and it is necessary to snake or open the line you will not be exposed to caustic chemicals.
This is especially helpful when you have old cast pipes and fittings in which the turns did not sweep as newer pipes made now do.
on Apr 03, 2015 | Plumbing
Tip
How to get ride of Fire Ants?
Most people don't want to harm other animals when they are trying to get ride of fire ants? The best way to treat your yard and home for fire ants that is safe for your children and pets. Go to the grocery store and by a 10 pound bag of breakfast grits and spread them throughout your yard the same as you would any other lawn care product.Pay special attention to where they have barrow the main entrance to the nest and pour at least one cup of grits directly into the barrow. Take note of the weather you don't want to do this on a rainy day? Depending on how bad your ant problem is you may have to repeat this process in about a week. <br /> <br />
on Jun 11, 2011 | Garden
Should these granules disappear into the ground after watering? mine have not
The granules will dissolve slowly over time, broken down by water and the elements. Larger granules will take longer to break down. This process provides slow application of chemicals over a longer time.
Apr 17, 2015 | Garden
Small worms in dogs
Dogs should not have worms. Take him to the vet ASAP.
Dec 03, 2014 | Dogs
Can i move a hibernating hedgehog
Is there a need to move the hedgehog, if there is then call your local wildlife service. They may come move it for you.
Aug 17, 2014 | Pets - Others
White vinegar can be used on the outside of a water bed mattress to clean it, can it also be used inside the mattress to keep it bacteria free?
I watched a magic school bus cartoon once where they shrank down and went into a pickle jar. The show mentioned that the friendly bacteria was fighting off the harmful bacteria. Hence it is never bacteria free. I don't see any harm of vinegar being inside except that it is an acid and acids slowly dissolve anything.
Nov 09, 2013 | Plumbing
Alarm system starts every day at the same time
change the sensitivity. or if it happens at the same time every day i would get up earlier to see if it is a pet or wildlife setting it off.
Jun 11, 2012 | Hyundai Accent Cars & Trucks
Automatic dishwashing detergent granules do not dissolve
Hope this helps
Al
Sep 11, 2009 | KitchenAid Dishwashers
Soap problems
MOHAMED
Sep 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Garden Logo
180 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
