Question about Electrosport Plug-In Regulator / Rectifier - Kawasaki ATV/UTVs
I have a 1979 Yamaha xs 650 special 2 need regulator rectifier ,with points will a #tmr1003bu 7/07 fit
1979 Yamaha XS 1100 special VIN number location
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.xs11.com/forum/showthread.php?t=26898
1979 Yamaha XS 1100 special VIN number location Google Search
http://www.ringler.us/xs1100/XS1100H-SH-LH_Service_Manual.pdf
OEM parts for Yamaha
Yamaha 1979 XS1100E Owner Manual
Sep 01, 2012 | 1974 Yamaha XS 650 A
1979 Yamaha 650 Special no spark
Hi, Fbigtank81 and the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, needs to be 12.5 volts or more and be able to pass a proper "LOAD" test, your battery may show 12.5 volts or more but has little or zero amps causing the battery to be faulty and must be replaced, AGM batteries fail in this category more so than lead acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
79 xs650 Special No Spark But 12v help
How to diagnose no spark situation on motorcycle
Yamaha XS650SE Shop Manual
http://mybikemanuals.com/yamaha/yamaha-xs-owners-manuals
Jun 30, 2011 | Yamaha XS 650 C Motorcycles
What is the correct battery for a 1979 yamaha 650 special
Your original battery was a YUASA YB14L-A2 . Use that battery or an aftermarket equivalent.
Oct 17, 2010 | 1979 Yamaha XS 650 SF
79 XS660SF Voltage Regulator
solid state is far more efficient than your original regulater do yourself a favour fit it up & enjoy the ride
Apr 24, 2010 | 1979 Yamaha XS 650 F
Can't find Model number.
I checked with a local Yamaha Dealership. They found it.
It's a SF model.
Aug 29, 2009 | 1979 Yamaha XS 650 F
80 xs 650 hesitation and exhaust "popping"
Most likely the carbs need cleaning and adjusting. You may want to richen the A/F ratio when you do it. They are set really lean from the factory. I would go 1/4-1/2 turn out on the A/F screw.
Jul 22, 2009 | 1979 Yamaha XS 650 SF
Two questions: Oil leak from top of engine; bike shut down ridin
the battery terminal being loose would cause that, since the rectifier would freak out. the leak you speak of is probably not eh head gasket ro you would have compression problem with amount of oil that can run down the bike. It sounds like a corner on the valve cover gasket or something I think there is a cover for the valve adjust ment there so check it out the gasket may be worn. no biggie get a new one.
help this helps
Jun 28, 2009 | 1979 Yamaha XS 650 SF
Where is location of fuse box? in the 1979 yamaha xs 650 sf??
should be behind one of your sidecovers, good luck to you friend...tim
Jun 05, 2009 | 1979 Yamaha XS 650 SF
Electrosport Plug-In Regulator / Rectifier - Kawasaki ATV/UTVs Logo
513 people viewed this question
Top Electrosport Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you an Electrosport Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
