Question about Music
How do i get reverb to vocals? phonic powerpod 1860 delux
    Master:
  • 369 Answers
Use use an echo or reverb chamber for live recording through a desk.
A recorded vocal can be processed using a digital recording program like Audacity which is free. In it you will find a re-verb plug in which will allow you to add this effect.
Audacity Free Audio Editor and Recorder
Posted on Apr 17, 2015
Phonic powerpod 820 schematic diagram
This site might help you out ?
http://elektrotanya.com/phonic_max860_1500_2500_right_side_poweramp_sch.pdf/download.html
Feb 27, 2015 | Phonic Music
Occassional noise when adjusting high med bass values
Typically anytime you can move a pot,fader,switch etc. And It makes any kind of noise such as static it's likely that it is justa dirty component. Deoxit is the most used cleaner. Most pots have some kind of opening on base that you can spray into if not then just directly down at the collar is where to spray. Spray all dirty controls and excursive by twisting pot.
Aug 25, 2011 | Phonic Powerpod 1860 Plus Powered Mixer
Phonic Powerpod 1860 - One channel xlr input stopped working. What could cause that?
Several things could cause this... connecting it to a piecee of equipment powered from a different wall receptacle cound result in ground bounce on the building power that could destroy the input circuits. Another thing is if a static discharge hit it... There are bypass capcitors at the inout that could have shorted. Of course the fader could have failed...
Aug 12, 2011 | Phonic Powerpod 1860 Plus Powered Mixer
Need a manual
http://www.bgaudio.eu/products/prod00000051/um_Powerpod1860Plus_PowerpodK12Plus_PowerpodK16Plus_en_es_cn.pdf
Jul 28, 2011 | Phonic Powerpod 1860 Plus Powered Mixer
Why do i have echo when i play music on my phonic powerpod 820 mixer
Visit this link to download the manual if you don't have it already. https://phonic.box.net/shared/crqxhlhmmz
This mixer has a multi-effects processor onboard, but the key is understanding the audio signal chain. There is a chance that you have your input audio going through an undesired effect, but without knowing your setup (input source, connections, mixer settings), it would be difficult to pinpoint the problem.
Apr 04, 2011 | Phonic Powerpod 820 Mixer
I have the Phonic powerpod 820. I ordered a Kuston powered floor monitor to add too the system. I know not to hook it up too the speaker outputs on the back of the mixer. So where do I hook up the powered...
You will plug an UNBALANCED 1/4 inplug cable into the MONI jack on the front of the unit. The other end will probably need to be an XLR plug to connect to the Kustom POWERED monitor. Please note that the UNBALANCED output of the Phonic is NOT good engineering practice. The Phonic stuff is normally low-end and they don't do everything correctely, although for a small system it should work. IF you get excessive hum from using a long cable to the Kustom with a "Kludged" unbalanced to balanced cable, you MAY need to use a DI box at the Phonic end to convert the unbalanced Phonic MONI output to a balanced line (XLR to XLR) for a longer run to the Kustom monitor. You might get a 1/4 inch TS to XLR balanced plug that has a transformer in it and use an XLR to XLR cable to the Kustom. Please note that having this plug in the Phonic hangs out and is easily bent over so I would recommend using a right angle connector at the Phonic and plug the 1/4 inch TS to XLR adaoter into that so the yanking of the XLR cable won't break the 1/4 inch adapter off in the Phonic.
Feb 23, 2011 | Phonic Powerpod 820 / S712 PA Package
What is the ideal speaker specification to match the 8 channel Phonic Powerpod 820. is it possible to play live gig using this set up ? what is the maximum possible set-up ?
to get the best from this mixer output wise, you need to use 4ohm speakers rated at 150watts each. The 200 wat rating is at 4ohms. You can use 8 ohm speakers, but they recomend speakers at 70watts.
Gig wise, you could do a small location that will cater for about 40 people, but that would be pushing your system to the max.
Maximum possible set up? well there is a way to work most scenarios you are given, but it is not best practice.
Ideally, you know what instruments and vocals you want to go through the system, a rough idea of the size of venues you wil play and then ask questions on a system to suit.
Jan 12, 2011 | Phonic Powerpod 820 / S712 PA Package
Music Logo
83 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
