Question about Garden
Should these granules disappear into the ground after watering? mine have not
  • 3,957 Answers
The granules will dissolve slowly over time, broken down by water and the elements. Larger granules will take longer to break down. This process provides slow application of chemicals over a longer time.
Posted on Apr 17, 2015
Is Aveeno Colloidal Oatmeal Treatment safe for this American Standard Installed Whirlpool Bathtub?
Hi Virginia,
I've done some research on tubs with jets, and from what I've read I wouldn't put anything granular in the water.
The granules may damage your pump and also when the water stops some granules will be left in the pipes, where they will decompose and turn into.... well, I don't think it'll be nice.
Nov 24, 2015 | Whirlpool Home
Water want come out
Clean sand granules out of the motor! the problem appears to be sand granules from the sand filter jamming the "pulse motor", unplug take the water cart off, unscrew the back cover, the one with the label (6 crosspoint screws) beware the 2 long ones holding the end! inside the cover there is a small bulge, next the pipe,, unscrew 3 screws these it reveals the motor squeeze the pipe clip slide back pull forward, to release motor blow through,the tiny hole backwards, until clear, you may have to use a blunt toothpick! to release, the stuck granules...Blow, blow, then reassemble
Jan 01, 2014 | Hoover SteamVac F5914-900 SpinScrub...
WATER LEVEL FLOAT DEVICE PREVENTS UNIT FROM TURNING ON,EVEN THOUGH WATER TANK IS FULL. REMOVED SOME FILTER MATERIAL WITH NO EFFECT. FLOAT IS FREE WITH NO RESTRICTION.
These hints are from the air o swiss webpage.
Q: No mist / unit is not working / empty indicator keeps flashing
A: Fill up the water tank. Check if water is flowing through the demineralization cartridge (attached to the water tank cap). If the water tank is full but there is only little water in the base it indicates that the water is now flowing through the demineralization cartridge.
  • Wait for 15 minutes to allow the mist to come out of the unit.
  • If the unit is not working and the empty light is not flashing you might have set the desired humidity too low and the current humidity level in the room is higher. That is why the unit switches off automatically.
  • If the empty indicator continues flashing and the tank is full, water is not flowing through the cartridge. Exchange the cartridge or the granules in the cartridge after 2-3 months, in areas with hard water exchange the cartridge after 1 -2 months. However, the demineralization cartridge and or the granules must be exchanged at the latest after 6 months or the unit does not reach its full performance.
If the granules are new, see the following instructions:
  • Make sure the cartridge and/or granules were soaked for 24 hours, water takes longer to filter through dry granules in cartridge and into the base. Next, remove 2 tablespoons of granules from the cartridge, and throw them away. Too many granules in the cartridge it does not allow water to flow from the tank to the base.
If your issue is with the float and not the mister, then you have to make sure the float is tripping the micro switch that turns the machine on. Some units the filter will not allow the float to hit the switch if the filter is not installed correctly. If everything is in correctly and the float is tripping the switch, then the micro switch must be faulty.
Apr 04, 2011 | Swiss AIR-O-SWISS Ultrasonic Humidifier -...
No more steam. Want advice on disassembly.
There is info on the FAQs from Air-o-Swiss:
http://www.airoswiss.net/service/faq.aspx#35
Q: Unit is running intermittently.
A: How long has it been since the contents of the cartridge were replaced? If 2-3 months have passed, it is time to replace the contents of the cartridge. However the demineralization cartridge and or the granules must be exchanged at the latest after 6 months or the unit ceases operating at its full performance. If the contents of the cartridge were just replaced there are probably too many granules in the cartridge. Remove 2 tablespoons of granules from the cartridge.
Feb 20, 2010 | Air-O-Swiss U7142 Humidifier
Hi, My Miele G527 dishwasher is tripping the circuit breaker
unlikely
I would suggest that you get in an electrician to test the washing machine for shorts and insulation problems as it could be shorting out in the motor or ground leakage from failing insulation
Apr 25, 2017 | Dishwashers
I have water in the discard container and wet grounds. They used to be dry brickets.
Hi
There are a couple of things that make wet grounds. One is a very coarse coffee. It should be like granulated sugar.
The second is your thumb screw is stripped, and needs to be replaced. Thumb screw holds the filter screen in in the brew head.
Dec 04, 2009 | Saeco Magic De Luxe Espresso Machine
Weak coffee saeco vienna "not digital "
Hi
Has the size of you ground coffee changed? If it is not the size of granulated sugar then its your grinder. Check ebay completed listings. Saw one there couple weeks ago.
Nov 24, 2009 | Saeco Vienna Digital Coffee Maker,...
Constant ventilate message
mine says the same thing, run hot water from the hot water/steam nozzle until the message disappears. do this a few times, mine is working fine after doing that. hope this helps
May 09, 2009 | Saeco Royal Professional Espresso Machine
Garden Logo
593 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
