Question about Dewalt 12v Max - 20v Max Li-ion Battery Charger Dcb101
Make it run at 220-230 wat let me know what you thik I find this...
Just modified charger bought from US to work on EU 230V plug. Only thing you need to change is one condensator 200v /220uF to 400V 100uF or similar then change EU plug thats it. I done it couple days ago and now DCB101 works like DCB105 .
My metabo khe2444 stopped working while i was drilling, what could be the common cause?
If it's fairly new, the electronic switch/speed control is the most likely thing to go out. Check and see if you can get full speed out of it. If so, then it's definitely the speed control.
If it's been used a lot, then it could be the brushes or bearings/bushings.
Here is one of the companies that sell parts for it. I'm including this so you can see a diagram. (I've never bought anything from this company, I'm not trying to promote them.)
http://www.mtmc.co.uk/Metabo-KHE-2444-/-06154000-/-EU-230V-Spare-Parts__p-103435.aspx
Nov 07, 2016 | Metabo Drills
What do I need to plug in my photive charger in Europe ?
In Europe we use 230V (normally called 220V). Just make sure that your charger can handle the difference in Hertz as well. If I don't recall wrong you use 50 hz in the US, and in EU we use 60 hz.
Sep 07, 2014 | Computers & Internet
When i plug it in to the charger it says invalid battery
ik this happened to me too well, wat i did was i kept trying to charge which the thing is that when it says invalid charger thing its becuz ur charger has some nasty things on it so wat i would do is go to ur phone company place and buy a new charger... :D
Dec 21, 2009 | Motorola Mobility RAZR V3
What do I need to use my Touchsmart tx2 in France. Do I need an adapter or transformer or both
You live in the US, right?
First check the voltage rating on your power supply / charger's primary voltage range. If it states around 110V only, then you need a transformer from 230V to 110V with an euopean plug. Make sure it's a real transformer (rather heavy, rated at ~100VA will be OK), and not a lightweight high-power adaptor, used for lamps, pressing irons, heaters and similar appliances.
If on your charger it states something like "90-240V", then it will cope with the standard european voltage of 230V, and the only thing you need is a travel adapter that will have an european plug on one side and an american socket on the other.
Oct 25, 2009 | HP TouchSmart tx2-1270us Tablet PC
Hello , i got and old MAXI MOUSE PORTABLE SPEAKER/AMP and i lost my CH-40 charger, do you know how i can get a new one or something similar. i live in Sweden
hello, if you also have 230V in sweden then look at your electronic supplier for a: Input AC 230V/50Hz/90mA/21VA Output: AC 22V/520mA/11,4VA
that's written on the charger.
Sep 23, 2009 | Audio Players & Recorders
Have lost charger or the 2 prong adapter. Not sure as we have a 16 volt charger with single prong that may be for our light. Need to know what voltage required for the light to be sure.
According to the instruction manual for these swimming pool lights, the charger specifications are the following:
USA and CANADA: 14 VAC,1.5A UL/CSA-approved wall plug
adapter and charger
AUSTRALIA and NEW ZEALAND: 240VAC 50Hz/14VAC 1.5A wall
plug adapter and charger
EU: 220-240VAC 50Hz/14VAC 1.5A CE-approved wall plug
adapter and charger
SOUTH AFRICA: 220-240VAC 50Hz/14VAC 1.5A wall plug
adapter and charger
UK: 240VAC 50Hz/14VAC 1.5A CE-approved wall plug adapter
and charger
Aug 13, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Spark plug
NGK plugs work well in the A4, and the OEM gap on a non-modified car is .032".
May 19, 2009 | 2001 Audi A4
My ds wont turn on all i do is plug in the charger then flick the switch really fast then the light turns on for half a second then stops wat do i do
Try a different charger if you can just to verify if yours is bad or not. If it works with a different charger then you know yours is bad.
If another charger doesn't work then you know that the DS is bad and you would need to get a new DS.
May 15, 2009 | Nintendo DS Console
Hitachi Charger convert to 230v from 110v how to
Hi mate,you need a step down/step up transformer,try e-bay they sell tons of them..50-100 AU$
Mar 03, 2009 | Makita 18V LXT Lithium - Ion Cordless...
Dewalt 12v Max - 20v Max Li-ion Battery Charger Dcb101 Logo
Top Dewalt Electrical Supplies Experts
JOHN LAPIER
Jay Plesset
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
