Door has rust
Fix or replace?
    Top Expert:
  • Washing Mach... Master
  • 6,702 Answers
If it is on the inside, it could damage the things you just try to clean. But still when there is rust on the door, there could be a lot of rust on other parts you can't see inside. I would go for a fix and start saving for a new machine, because there can be coming up more trouble with this one.
Posted on Apr 17, 2015
How to fix rusted hinges on a whirlpool cabrio washer mod.#wtw8800yco
if they are stiff use an oil such as WD-40, if they are almost completely rusted out replace them you can go on-line to the manufacturer and order a new door or hinges or go to Amazon and order from there.
Nov 10, 2016 | Whirlpool Washing Machines
Our white refrigerator has some rust on the outside. There is also rust behind our kitchen faucet. How do we fix this?
need to wipe the moisture off so it doesn't sit on fixtures 2 ways of taking care of rust clean it than wipe down with a rust inhibitor sand smooth to metal spray primer than respray with white appliance paint or if to much rust/damage order new door front--- on faucet clean and polish should clean up unit if not and flaking alot possible may need to replace faucet
Aug 12, 2016 | Plumbing
Under the door is rusting out how to fix
Rust is like cancer - there really is no fix. You can cut out all of the affected area and try welding another piece in there but it will come back and is a temp fix. Best way to repair is to replace entire panel with a new, primed, painted one.
Sep 04, 2015 | 2004 Chevrolet Silverado 1500 Crew Cab
Cherokee liftgate rout out repairs
If you are a panel beater or good welder it will be an easy fix. Cut out the rust and replace it with a piece of panel metal ( from an old door -any old car door)
Apr 08, 2013 | 1998 Jeep Cherokee
THe door hinge on my GE front load clothes washing machine model # wssh300G1WW has rusted and bent and the screws are rusted. I would like to replace the hinges and screws but I don't think the...
I have the same washer & its 3 years old today. Rusted hinges & door & screws too.
Door is really hard to shut so I called GE to complain & they are overnighting me a new door, hinges, & screws. You should call!!
Oct 11, 2010 | General Electric WSSH300G Front Load...
I have a rust spot on the rocker panel between the door and bed on passenger side, do they make replacement panels and how are they applied
There are panels available from several manufacturers, no matter who makes it, it will require welding to install. Ford will definately make the part you need but it will be relatively expensive, if you want an aftermarket part just google "rust repair panels"
When we fix small rust spots we usually fabricate replacement parts out of 22 ga steel.
Nov 11, 2009 | 1996 Ford Ranger SuperCab
There some wrong with my central locking the driver door which controls all the other doors isnt functioning properly when i press the button to lock the car all the other doors lock except for the...
I live in Montreal ( harsh winters ), I've seen a few CRV'S with rusted latches, so rusted that the dor doesn't open at all, even manually.
Take a look at the latch for major rust.
Pierre
Apr 15, 2009 | 1997 Honda CR-V
Rust on Jenn Air Refrigerator Door at Water Dispenser
You may end up respraying the door, but here goes.-
First mechanically remove as much of the rust as you can with an old screwdriver or similar scraper. Then use coarse emery cloth - 80 -120 grit untill all you're left with is shiny metal with rust pits.
You may need to go out further than you think - about 1" all round.
Then use a paint- on de-rusting fluid from vehicle products supplier. When all rust is black or dissapeared, use a zinc primer on all the bare metal. (this will stop it reacuring)
Then either spray the area with an "appliance white" aerosol or squirt it into the cap, and use a paintbrush.
If you are spraying it, open all house windows and doors, cut a mask from newspaper- then tape it to the fridge. Use blankets , plastic dustsheet or old sheets to protect things, and spray it from 12" in several very light coats.
When done, "polish" with T cut - which should remove the rust stain too.
Seal the area of the original leak with a white or clear silicone - and sort the original leak out.
If you polish the plastic with a silicone spray, water will tend to stay put rather than seep.
Jun 11, 2008 | Jenn-Air JCD2389G Side by Side...
Ice dispenser door flap does not stay shut
IS IT A GE? GE HAVE A PROBLEM WITH DOOR SOLENOID IN CUP CHUTE RUSTING,GET A FLASHLIGHT AND LOOK UP THERE,IF IT IS RUSTED YOU WILL HAVE TO REMOVE FRONT PANEL AND REPLACE IT,THANKS-MIKE
May 30, 2008 | Refrigerators
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
