Wont drain..door locked..what do l do?
My washer wont drain and the door wont open because its full of water, how do l drain it? Theres a burning smell too..does that mean lve stuffed the motor?
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Put drain hose below water level when empty should spin
Posted on Apr 17, 2015
Door wont open
you cant,they are on a timer. make sure theres no water in the washer ( put it on a spin cycle ) drain all water out and try then. if that dosent work unplug the washer from the mains and leave it for a few moments then try then
May 08, 2015 | Washing Machines
Whirlpool washing machine wont stop all lights
Check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out.
While the machine is on press "end of cycle" for 3 seconds, then wait for 2 minutes to try the door. Try this again if it does not open, this is the child lock program - to lock and unlock; it is the same procedure.
How abt a nice rating for the free help? Thnks
Jan 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door wont open on my washing machine hoover select 1500
I just had the same problem and came here looking for a solution...I went back one last time and tried to unplug. That didn't work. Then I put it on drain/spin and after a minute interrupted by hitting the pause/cancel button - and it released! I am so happy!
Sep 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag neptune front load washer says control lock and wont start and buttons wont work
unplug the washer for 15 minutes then:plug it back in and, restart a few times in a different cycle canceling each time until the door opens. Do this only if the tub is not full of water if it is let me know and, i'll show you how to drain the washer first before we try to open the door.
Jun 09, 2009 | Maytag Neptune MAH6700A Front Load Washer
Door will not unlock need to get clothes out
whooaaa put down the ha\mmer, it wont open if theres too much water in unit. there is a manual release, but you have to remove the lower service panel to reach it.after removing the panel youll need to stick your hand up along side the front panel right hand side. the lowest ponit of the door latch/lock assy has a quarter sized handle that youll need to pull to relesae the door mechinism., WARNING if there is water visble through the door and you open it you will get wet...before trying the manual release option turn off the water supply and set the machine for drain/spin cycle and see if the drain pump turns on to release enough water to opne the door on its own,if the drain pumps only humms and doenst drain, then theres the issue you have something stuck in the drain pump. in which casse youll need to remove the lower panel and free the clog anyway.
Oct 12, 2008 | Kenmore Elite 45986 Front Load Washer
Cant drain and cant open the door
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Jun 26, 2008 | Creda W100FW Front Load Washer
Door wont open
did you try running a drain and spin cylce? there might be water in machine still and thats why door not unlocking..Assuming theres no water in machine( youcant see any waterline though glass) you can remove the bottom cover (3 torx 15 screws) UNPLUG UNIT. reach your hand up approx six in. on right inside face of unityoull find a manual release for the door lock assy, round tab mounted to bottom of latch assy approx size of a quarter, give it a pull and door will open,might be a fluke that it lock but i would check for operation before filling with close again
Feb 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint aquarius washer door wont open
I've got the same problem, the locked symbol is showing
Feb 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Door locked,wont spin or drain.
humming noise suggests a foreign object in the pump. crack open filter and drain water into a shallow tray. repeat till empty. remove filter completely and clean it. check if something stuck in pump impellor. this should be visible by looking into the filter hole
Jun 22, 2007 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
