The writing on machine is foreign please could you tell me what dial numbers for hot wash for whites and 30 degrees wash for colours
  • Washing Mach... Master
  • 3,960 Answers
You need to either provide a picture of the dials, or find a copy of the user manual in English. You can Google search the manufacturer make, model and the word manual. If an English manual is available, it will show up in the search results for download
Posted on Apr 17, 2015
  • 249 Answers
SOURCE: DIal is misaligned!
It could be a faulty water heater stat ,or the hot and cold fill pipes are the wrong way round. close Ireland bye bye
Posted on Nov 24, 2007
SOURCE: washing machine problem
I have a performa 1100. No 4 is the 40 degree is the normal cottons cycle which is the one I use. Tip- only fill the drum 3/4 full otherwise it struggles to drain and spin- I know!
Posted on Jan 25, 2008
appldoctom
  • 311 Answers
SOURCE: Maytag Washing Machine Cycles Out of Sync with Dial
ive fixed lots off washers over the years[15,000 service calls] and was careful while taking parts off if i wasn't fulmilure with that model,but most timers and knobs have a key way so the knob can only go on one way.if thats not true for you, try this.turn the timer shaft till the washer is at the end of the wash cycle.[finished the load,it would be the final spin ,maybe five minutes long.when thats done the timer advances to off]now knowing that thats an off position set on your knob and then manuly turn it to the off position of the next cycle if it wont run you did it. if not you will have to go to the end of that cycle and remove knob and set to next notch in the knob,until you find the sweet spot.hope this helps God bless,tom
Posted on Feb 27, 2009
gary1121
  • 332 Answers
SOURCE: washing machine boils my clothes when I select a 30 degree wash
your mixing valve needs to be replaced iis what brings the cold water in to cool the hot water off, depending on the unit you will have to ask the company but it might be the heat sensor beings alot of newer machines have computer boards
Posted on Jun 09, 2009
SOURCE: indesit 1200 washing machine boils everything and
make sure you have connected the cold water feed and not a hot water supply, these machines need a cold water feed only
Posted on Jul 27, 2010
I have just moved into an Apartment with a Gorenje wi 62112 Washing machine, I have no manual Can anyone tell me what the numbers on the Dial mean What should I choose for a general wash.
Gorenje has some documentation for their washers here: http://www.gorenje.com/simplicity/en/washing_machines/simple_manual_for_washing . The numbers indicate the water temperature (in Celsius) for a given cycle. The common choices are a cottons load in hot water (60 degrees). This is great for towels and other whites. The mixed load is for permanent press that can be in warm water (40 degrees). Then there is a cold water cycle for delicates (30 degrees). However, you should check the fabric care label before choosing the cycle.
I hope this helps.
Apr 20, 2016 | General Washing Machines
How do i prevent colour bleed from fabrics?
You can't. Best option is not to mix colors with white when doing hot wash. Generally colors on own go well with cold wash with the right detergent. When you get new colored clothes like pyjamas rinse separately overnight to get non fast colors out and then put in the general laundry. But always keep whites on separate wash.
Sep 01, 2014 | Washing Machines
Please help I've put my grey quinny buzz seat
Good Afternoon
As long as you wash it maximum temp 30 degrees on handwash or delicate cycle it should be fine.
To be safe wash it by hand with mild detergent rather than putting in the machine.
Jul 14, 2011 | Quinny Baby Gear
Clothes are grey not white at 95 degrees
never do a 95 degrees white wash after a dark wash!!
The discolouration comes from the fact that water is never completely drained from the machine, and as such if there is any dye from a previous 'dark wash' you will be unintentionally washing dye into your whites.
Use colour catching or whitening products to reduce/ eleminate this
Dec 19, 2009 | Whirlpool AWM5125/1 Front Load Washer
I wash my shirt with hot water it's colour was white unless a little part but when i ge it out a strang colour has been add?
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 07, 2009 | Kenmore HE2 Plus Front Load Washer
My Candy aqaviva 1000es has no instructions. I followed the pictographs on the front of the machine and put it on a ''40 degree synthetics wash'', but have twice had problems with colour bleed from...
There is no way a machine can detect if the colour can run or not. Fabrics you suspect can bleed (first time wash) should be soaked in water separately overnite. Then handwash the thing, dry out. Two washes like this will generally stop the bleed. Another tip: seperate whites from coloreds if your washing is more than one load.
For a manual you can surf this site by clicking on one of the tags above, or search my solutions.
Mar 23, 2009 | Washing Machines
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Washing machine problem
Jan 21, 2008 | Hoover PE235 Front Load Washer
DIal is misaligned!
Sep 01, 2006 | Tricity Bendix WDR1040W Front Load Washer...
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
