Question about Dehumidifiers
Where can i get instruction details - Dehumidifiers
  • 3,960 Answers
Google search your manufacturer make, model and the word manual. If one is available, it will show up in the search results and you can download it from there.
Posted on Apr 17, 2015
Just bought new dehumidifier but by mistake carried it on its side for 30 mins.can it now be damaged ?
I would be surprised if the query is not dealt with in the instruction book or there isn't a helpline number or other contact details.
My dehumidifier works like a low-powered refrigerator and contains a compressor/motor unit, a fair amount of pipework, a condenser and an evaporator and a fairly substantial fan.
Just like a fridge or freezer best practice is to transport these things in an upright position. This is something lots of people know but few know why this is desirable.
The motor/compressor unit contains oil and it relies on gravity to keep it where it will do most good. Transporting in any position other than vertical allows the oil to run out into the pipework depriving the hard-working unit of much-needed lubrication should it be switched on too soon after being moved. There are probably other problems caused too.
Allowing it to stand vertically for 6 or 8 hours before switching on after transportation should be sufficient to allow the majority of the lubricating oil to find its way back to where it is supposed to be.
Oct 17, 2015 | Frigidaire FAD504DWD 50-pint Dehumidifier
Shows change filter where is it located?
Hello Ann, this is JK. I understand that you are looking for the location of the filter in a dehumidifier. Generally, you will need to remove the bucket to be able to reach under to remove the filter. Please refer to your owner's manual for more detailed care and cleaning instructions. Hope this helps!
Apr 07, 2014 | Frigidaire Dehumidifiers
The dehumidifier keeps leaking water out the bottom of the unit. I checked the bucket and it does not have a crack/leak. It appears the water is seeping out into the back of the unit and only half the...
First of all, here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%201317161.pdf
If that is not your model then just specify which one is yours from the following Canadian Tire link:
http://www.canadiantire.ca/AST/browse/3/HouseHome/1/HeatingAirConditioning/Dehumidifiers.jsp
To view the Owner's Manual with Operating Instructions or the catalog page just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
Check to make sure your drain hose connector plug is properly fitted. If this is loose or missing, then some of the condensate will drain out onto the floor. See page 6 of the manual for detailed instructions and illustrations about the drain hose connector and the plug.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
May 30, 2011 | Whirlpool Dehumidifiers
If I put this in my basement because of all the rain we've had, what should I set the knobs on? I don't have a manual
Here is a direct link to a user's manual for that model:
http://www.appliancefactoryparts.com/content/pdfs/114658.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You can just run the unit at the stock settings initially and then after a day or two of operating, you can adjust the desired humidity level up or down if required. If you find that your coils are freezing up with ice, then the unit is running a little too much for the ambient conditions. You can always try adding a little heat to the room if necessary since a dehumidifier will not work well if the room is too cold.
Joe.
May 26, 2011 | Maytag M7DH45B2A Dehumidifier
Water draining onto floor not collecting in bucket. What could cause this?
First of all, here is the main ONLINE SUPPORT page for your model:
http://www.ajmadison.com/cgi-bin/ajmadison/AD35USS.html
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.ajmadison.com/ajmadison/itemdocs/1188927.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
Well, the first obvious thing to check is whether your collection bucket has a hole or a crack in it which is allowing the condensate to leak out onto the floor.
The other possibility is that you are missing your DRAIN CONNECTOR COVER which blocks up the drain hose connection on the side of the unit. This hose connection is used when you want to run the unit continuously with a drain hose attached and don't want to have to empty the bucket all the time. There shoud be a small screw in plug to cover this drain connector when not in use. See page 7 of the manual for detailed instructions and illustrations.
If your collection bucket is just overfilling and spilling onto the floor and the unit just keeps on running anyway, then you have a problem with the float level shut off switch which needs adjusting or replacement.
Joe.
May 24, 2011 | Whirlpool AD35USS Dehumidifier
Lost instructions
Here's the FAQ for Danby dehumidifiers =>
http://www.danby.com/products/faqs.php?cat=12&q=53
There were no instructions manuals to download.
Their customer support page =>
http://www.danby.com/contact_us
Business Hours:
Monday – Thursday 8:30 – 5:00 EST
Friday 8:30 – 4:00 EST
Consumer help line 800-263-2629
Jan 03, 2009 | Danby DDR583R Dehumidifier
Bucket full
Allergy Buyers Club gave me a replacement item.
May 25, 2008 | Comfort-Aire BHD-501 Dehumidifier
Dehumidifiers Logo
164 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
