Question about HP Computers & Internet
My hp laptop cannot turned on , removed the battery and check with power supply it doesn't turn on.I checked the ram, its good.when turning on the power connector led turns off
    Top Expert:
  • HP Master
  • 22,127 Answers
Try a new charger.
Posted on Apr 17, 2015
    Top Expert:
  • HP Master
  • 12,962 Answers
Either the mo bo is defective or there is not enough power reaching the computer.
Hope that the power supply has gone bad - they are relatively inexpensive for about 15 dollars on ebay.
  • Anonymous Apr 17, 2015
    power supply(charger) works well . And lap turns on for half a second and turns off.
    I observed that when turning on the lap connect with charger , the charger connector led turns off
  • richie46 Apr 18, 2015
    Well, if you are sure that the power supply is good then the bad news is that something is either wrong with your motherboard or one of the peripherals attached to it. Prognosis not good.
SOURCE: My HP Pavilion dv6000 won't turn on
I've had the same problem.
Remove the battery & power cord.
hold down the power button for 10 sec to release any residual power.
plug in the power cord but leave out the battery
it should boot right up
Posted on Oct 13, 2008
  • 50 Answers
SOURCE: Laptop HP Pavillion zd7000 (model zd7058cl) does not turn on
go on www.hp.com and contact them
Posted on Dec 23, 2008
  • 50 Answers
Hi sounds like your dc connector in laptop is loose or bad connection.Try moving the power cord going into the laptop gently and watch the lights to see if they flicker off .If they do you need to take the laptop in for repair.
Posted on Jan 20, 2009
anandsharad
  • 137 Answers
SOURCE: Dell D600 when powering, leds blinking
Its a motherboard problem. check all the flashing codes here.
CLICK HERE
it will give you all the information about the codes.
Posted on Sep 26, 2009
Testimonial: "It's works"
SOURCE: Acer extensa 5630ez won?t turn on.
Can you give a location of R138?
Is it on the easy side? E.q. the side of the motherboard wich is accessible by removing the bottom plate? I see Q24, located close to CPU. If possible, post a picture of R138, with some components visible.
Posted on May 11, 2010
I have had my hp latop for about two years now. Within the last eight months, it has been having issues. As of now, when I turn on the computer, the screen remains black. I have no idea how to get this...
I had the same problem with my HP DV6599. On power on the screen would stay black, no POST, nothing at all on the display. The HDD would spin up but the HDD indicator would not come on and would not boot. The DVD drive would spin up and attempt to read a disc if one was in the tray but still would not boot.
I found an answer on another forum.
Try this:
  • Unplug the power,
  • Remove the battery and then hold the power button for 30 to 60 seconds.
  • Then reattach the power and attempt a boot.
  • Just shutdown, put the battery back in you're good to go.
Jun 15, 2010 | HP Pavilion dv2000t Notebook
HP Pavilion ze2000 Laptop won't turn on
Have you tried removing the battery and seeing if the laptop will then run?
Jan 18, 2010 | HP Pavilion ze2000 Notebook
My laptop will not turn on
Do you have a light on the power supply when you plug it in the computer?Remove the battery the power plus the memory .Press and hold the power button for twenty seconds.This will reset the computer and hopfully turn it on when you replace the parts you remove.
good luck
Sep 15, 2009 | Computers & Internet
Power light shuts off after only 3 seconds
Disconnect the AC adaptor from the laptop and remove the Battery pack from the Battery bay. Then, remove the RAM module and reinstall it after cleaning the RAM slot. Next, connect the AC adaptor to the laptop then try turning it ON. Please make sure that the AC adaptor is connected to a functional wall outlet. If the laptop still doesn't turn ON then you may try cleaning the Battery bay and the metal contacts in the battery compartment then insert the battery and try turning ON the laptop. If the laptop still doesn't turn ON then the issue is with the power supply unit.
Sep 04, 2009 | Dell Latitude D600 Notebook
Will not turn on
Unplug the power,Take out the battery,Plug the power back in with the battery still out and it should start as long as the power supply is working.
May 09, 2009 | Computers & Internet
Hp pavillion dv7 won't power on
Same issue - solved by disconencting everything (main battery, CMOS battery, RAM, hard disk and wireless card). Held in power button for 20 seconds (HP say this removes any electostatic charge on the main board). Reconnected everything and machine booted to Windows. Ran HP's onboard diagnostics and everything checked out OK.
Mar 30, 2009 | Computers & Internet
HP Pavillion zd 7000 (model zd7058cl) does not turn on now
Don't try again and again,,, if not running well protection circuit will turn off. therefore test for short circuit, need to remove unwanted parts and try, also need to test the circuit for short circuit with multi meter.
specially mosfets need to check.
Apr 03, 2017 | HP Pavilion zd7000 zx5000 zv5000 presario...
Compaq - will not turn on - plugged in?
Disconnect the AC adaptor, Take the battery out and press and hold the power button about 5 seconds. After that connect the AC adaptor and insert the battery turn it on. If issue persist please inform for further troubleshooting.
Good Luck
Mar 01, 2008 | HP Compaq nc6320 Notebook
Computers & Internet Logo
55 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
