Question about Kicker Car Audio & Video
How can I wire a 2 ohm and 4 ohm kicker dual voice coil speakers to a JL 500 1 channel amp
    New Friend:
  • 25 Answers
With that amp it doesn't matter how you wire it... as long as its above 1.5 ohms so at 4 ohms that amp still puts out 500 rms no matter what. 12volts or 18 volts it is 500 rms clean just don't go under the 1.5ohm. keep it at 4 ohms for a cleaner linear subwoofer with optimal performance and less stress to your equipment unless you like buying new sh** and wasting money. also most people don't realize after 3-6 months ALL AMPS should be turned down and ran in shorter durations... heat sink compound does not last and causes overheating if your not able to apply heat sink comp under you mosfet chips regularly like changing a car's oil!!
I have a few of these amps. most people bash JL audio but the 500 watts is better than cea compliant amp that are 1k watts rms with much more power and is clean. take care of you amps and gl
Posted on Apr 28, 2015
    Master:
  • 369 Answers
Ok, so you have a single 2 ohm speaker and a 4 ohm speaker with dual voice coils? The JBL Is a 2 Ohm load I believe.
I ran through the maths...
Series parallel with the 4 Ohms in series in parallel with the 2 Ohm gives you 1.6 Ohms
2 x 4 ohms in parallel with a 2 ohm in series gives you 4 Ohms which is no good.
All three in series give you 10 ohms which is no good.
All three parallel gives 1 ohm.
So with this set up you cannot create a perfect match. So you will always run the risk of bad audio or the amp blowing at high output.
Posted on Apr 17, 2015
SOURCE: speaker wiring
hi mat
you should have four terminals two plain and two with dots
to get the best power cut two inches off good speker wire
tear apart now place one wire from
plan black to red with white dot then
plain red to black with white dot
this is how set then up with my directed 1100d mono amp .. very loud at half gain
well hope this helps.............. ..benjaminsarmy..
Posted on Mar 23, 2009
  • 231 Answers
SOURCE: amp 4 a Kicker S17L7
just make sure your kenwood amp can at least handle a 2ohm stereo load.Most amps now are able to .Your amps manual should list this or go online and check for that model .You basically have 2 subs in one allowing you to use one sub box in stereo mode.And just hook it up like two speakers left and right ..make sure amp has a crossover so that you only get bass at your woofer
Posted on Jul 30, 2009
SOURCE: Need help.. I have two 12 inch dual voice coil
To do this they MUST be wired in parallel, IE: Plus to Plus, Negative to Negative. 2 4 OHMS in parallel is about 2 OHMS in series it would be 8 OHMS... series is positive to negative. Are you using a crossover network?
Posted on Mar 05, 2010
SOURCE: Volfenhag ZX4725 i am buying this subwoofer and
No the LOWER the resistance the MORE Output or Draw, If say it is 100 Watts into 4 Ohms, if you used a 2 ohm speaker it would draw 200 watts.(only if capable of delivering that amount of power) The LOWER the Resistance, the HIGHER the Current Draw. WATTS = AMPS x VOLTS. (This is not strictly true with amplifiers output though, as it is an AC Current, and a "Reactive" load, it has, Inductance, Capacitance and Resistance, all in one.and is worked out via a Formula) see below. http://en.wikipedia.org/wiki/Audio_power
http://www.hometheaterhifi.com/volume_1_1/v1n1spk.html
Now with Dual Voice Coils, Essentially, you can think of these speakers as TWO speakers in ONE enclosure. As such, They are basically TWO Speakers. Please see the website below it explains everything for you. http://www.diyaudioandvideo.com/FAQ/Wiring/
Everything is a function of Resistance and Ohms law.
Current (I) = Voltage (E) divided by Resistance(R).
Voltage = Current Multiplied by Resistance.
Resistance = Voltage divides by Current.
Posted on Apr 17, 2010
judd0081
  • 334 Answers
SOURCE: i just needed some help
Well i tried looking up that amp, but Fosgate sight is down. So assuming that the best power out of your amp is 2ohms off the bridged hookup, and the subs are 4 ohms per coil, the best way is to only use one side of each speaker and hook it straight the the bridge. Only using one hook up wont hurt anything, its just for giving you wiring options. And when adding up ohms of speakers, it goes like this. If you had two 4 ohm subs, that'll give you a 2 ohm load. If you hooked up all your hookups, it would be like having four 4 ohm subs, and would give you a 1 ohm load.
Posted on Jan 19, 2011
A kicker 600.1 wired to a jl w7 10" sub? Will that work?
The kicker 600.1 provides 600 watts at 2 ohms and 300 watts at 4 ohms the 10" JL W7 has 2 1.5 ohm voice coils so you will have to wire them in series. Take about 1.5 feet of 14 gauge wire and connect the positive of one voice coil to the negative of the other then the positive and negative that are left go to the amp. Your impedance should be 3 ohms and that amp should work just fine.
Jan 14, 2016 | Kicker Car Audio & Video
I have 4 wires what do they do I no to of thim will go to my Kicier ame I Ddont no were the other to go
OK, I am assuming that you have 4 wires coming from the subwoofer itself. Your subwoofer has dual voice coils, this means there are two positives and two negatives. Look closely at the posts on the subwoofer and you can tell. These wires will go to your amp, all four of them. Here's the tricky part. You need to know if your amp is a monoblock (single channel) or two channel amp. Also, what ohms is it stable at (4, 2, or 1). If you have a monoblock stable at one ohm, take both positives from the sub and put to the positive of speaker output on the amp. Then put both negatives from the sub to the negative speaker output of the amp. If your sub is dual 4 ohm voice coils, this will give you a 2 ohm load. If you have a dual 2 ohm voice coil sub, this will give you a 1 ohm load. If you amp is 2 channel, just hook one set of positive and negative to one channel and the other set to the other channel. Hope this helps
Aug 28, 2011 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How do you hook up the speaker wire to the ab sub out and what is the best way to hook them up at what ohm
Not sure what you mean by AB but being that this is a monoblock or 1 channel amplifier you can only hook it up 1 way. Verify the polarity from your speaker box. + to + and - to -. As far as your impedance is concerned this amp is stable to 1.5 ohms but for this case we will assume you have two 4 ohm subwoofers. When you parallel these together you will have a total effective load of 2 ohms on the amplifier. This is a stable operating impedance for the amp.
Other impedance options are:
two 8 ohm speakers = 4 ohm load
three 8 ohm speakers = 2.66 ohms
If you have dual voice coil subwoofers then parallel the coils on each sub + to + and - to -. Depending on the impedance of each sub you may then have to wire the individual subwoofers in series. Here is an example.
2 dual voice coils with 4 ohm taps
Each subwoofer with the coils in parallel would be a 2 ohm load if you were to then parallel the two subwoofers together you would have 1 ohm total load on your amp. This is BAD for your amp. Your option is to run the subwoofers in series.
To run the speakers in series is simple. The + from one speaker and the - from the other will be connected to the amp. The other + and - from the speakers will be connected together.
Here is a wiring diagram from kicker.
http://www.kicker.com/dvc_wiring
Jun 11, 2011 | Jl Audio Slash 500/1 Car Audio Amplifier
Need help.. I have two 12 inch dual voice coil kicker comp vrs.. they are 4 ohm subs..how do i wire them to get a final ohm load between 1.5 to 4ohms in a dual enclosed box...Im hooking them up to a jl 500...
Mar 05, 2010 | Kicker CVR12 Car Subwoofer
I have an Audiobahn A8000T amp and 2 12" Kicker CVR (DVC) Dual voice Coil. The Subwoofers are 2OHM a peice. What is the best way to hook this all up to run a 2 OHM load to my subs?
This is a link to Kicker for your CVR12 Subs...if you have the 2 ohm version (2 ohms per voice coil) and you have 2 speakers ....you will need to wire EACH speakers voice coils in series to get 4 ohms from each speaker and then wire the 2 speakers in parallel.....as in....2 ohms in series with 2 ohms = 4 ohms....both speakers wired same way, then in Parallel with each other = 2 ohm load. Page 2 of this link gives examples of both series and parallel wiring of your speaker.
http://www.kicker.com/sites/default/files/2006CompVX.pdf
If you are still not sure as to my description of ' How To',
PLEASE respond and I will attempt to explain it EXACTLY via wiring directions.
Nov 18, 2009 | Kicker CVR12 Car Subwoofer
How do i wire my solo-baric L7 12"
how should i wire my s12 L7 2 ohm dual voice coil to my JL 500/1 amp
Sep 15, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Logic soundlab cpx1400 need to wire to a kicker cvr 15
Hello discrete01,
The Kicker model number 07CVR122 has dual 2 ohm voice coils, and can be wired for either 1 ohm or 4 ohms. Model number 07CVR124 has dual 4 ohm voice coils and can be wired for either 2 ohms or 8 ohms.
Kicker's wiring page is here: http://www.kicker.com/dvc_wiring
If you have the version with 2 ohm voice coils, you want to use the 2nd diagram for a final load of 4 ohms to the amp. The 1 ohm load is too low for the amp and will cause it to overheat and possibly fail. If you have the 4 ohm version, use the wiring shown in the 3rd diagram which is a perfect match for the amp.
Hope this helps.
Aug 11, 2009 | Kicker CVR12 Car Subwoofer
How do i wire 10' kicker cvr
dual 2 or dual 4
dual 2 wire vc's in series for a 4 ohm load each. Hook each speaker seperate channels on the amp.
dual 4 wire vc in series for an 8 ohm load each. Hook both + to the right + on the amp and both - to the left - on the amp. or
dual 4 wire vc in parallel for a 2 ohm load each and hook each speaker to seperate channels on the amp.
Dec 18, 2008 | Kicker CVR12 Car Subwoofer
How should I wire my 3 subs to the 500/1 amp???????
First of all how many ohm's are each subwoofer rated at . Are the subwoofers dual voice coil or single voice coil. Once I know that I can help you. I think the JL amp is not recommended below a 2ohm load.
Mar 16, 2008 | Jl Audio 500/1 Car Audio Amplifier
Speaker connections
This is a single channel amp that puts out about the same power at 4 Ohms or 2 Ohms. If you have two 4 Ohm single voice coil subs, then wire them parallel (both pos and both neg) to achieve 2 ohms. If you have two dual 4 Ohm voive coils, you want to do a series - parallel config to get to 4 Ohms (voice coils in series, then parallel the subs). Same with DVC 2 Ohm subs, series parallel = 2 Ohms. Do NOT go below two Ohms. You will blow the amp (actually, it'll do 1.5 Ohms). If you happen to have 2 Ohm single voice coil subs (not as likely) run them in series. Most amps will put out about twice as much power at 2 Ohms vs. 4, but this amp is designed to put out about the same. Hope this helps!
Feb 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
Car Audio & Video Logo
182 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
