Question about Dremel Tools & Hardware - Others
Dremel Trio 6800 doesn't react. I have my Trio for maybe 1.5 month. Used 3-4 times. Each no longer then 2-3 min per use on laminate..tool has electr.checked it with tester.why it doesn't work?
  • 4090 Answers
SOURCE: Dremel motor dead.
absolutely astounding! Had my Dremmel for 10 years and abuse it and use it it has been wet and its out in the shed. Never had a days trouble.
Now when it was in the case was the case shut? My thoughts are mice piddle which if it gets inside will corrode everything. I say this because a bigger drill of mine got damaged in that way. No external signs of damage but when opened the damage was there and it could also be then smelled.
My only other thoughts on this is to get you to check the plug to see a wire has not pulled off, after that I would suspect the dremmel switch has a fault.
all shots in the dark! but have to start somewhere when you are riding blind.
Thanks for using FIXYA
Posted on Oct 11, 2009
Testimonial: "Great suggestions for a range of starters on troubleshooting this (would never have come up w\mouse turds!). Thank you!!"
apenning
SOURCE: My Dremel tool motor still works but shaft won't turn?
Here's the email from I got from Dremel (in my case the flex coupling broke):
Inside the tool is a flex coupling and spline driver.
The flex coupling is # 2615294309 and the price is $ 1.25.
This is the hollow plastic sleeve about 1" long with grooves on the
inside, that goes between the motor shaft and the output shaft.
The spline driver is # 2615294308 at $ 1.00.
Spline driver sits on the direct end of the motor shaft. The flex
coupling sits over the spline driver. Spline driver is about 1/4",
hard plastic with grooves on the outside.
Total shipping for orders under $ 5.00 is $ 2.50. Orders over $
5.00 is $ 4.00.
I have provided ordering instructions below.
To order by phone: 1-800-437-3635, Monday-Friday from 7 am to 6 pm
central time. VISA, MasterCard or Discover is accepted.
To order by mail:
Dremel
4915 21st Street
Racine WI 53406
Posted on Apr 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: My dremel 10.8 lithium ion
The battery has been overcharged.
You will need a new one.
Thanks!!!!
Posted on Aug 18, 2010
agent91
  • 2100 Answers
SOURCE: The collet on my Dremel
Walmart sells dremels, and they have chucks hanging on the wall. Check it out.
Posted on Oct 30, 2010
  • 157 Answers
SOURCE: Dremel 10.8V cordless model 800 (8000) The speed
You are right,it will need a slider switch replacement,But first-is it still under warranty?If it is call the costumer support on their 1-800 ...number.If not you could DIY it.Opening the drill is not that hard and as long as you observe the proper orientation and where every wire is connected to,you will be able to disassemble the unit.Inside you could see where the slider switch is connected and how it is positioned.Usually the surface of the switch is burned out and this you have to replace.The next problem is locate the part number it is usually found printed under the slider part.And the next big thing is to order the part and where to order it.Consult the user manual that came with Dremel unit and the ordering address is there.
Posted on Nov 06, 2010
I have an old Dremel scroll saw model 550 and need blades. However, the blade holder is missing a clamp that secures the blade. Is there a universal kit I can purchase to solve problem?
Try going to a store that sells scroll saws and look at the new models to see how they hold the blade. Take your Dremel with you. Maybe you can find one that is similar enough that could work if you can get the part. Then go to the tool company's web site and search for the manual for the comparable tool you found - they all have on-line manuals nowadays. You should be able to order the part you need. Good luck!
Jan 30, 2013 | Dremel 5 3" Saw Blades 8033 For 550...
Dremel 10.8V cordless model 800 (8000) The speed is stuck on the high setting (variable doesn't work now) and battery lights no longer work. I'm assuming its the switch and now needs expensive repair. Only...
Nov 06, 2010 | Dremel 8000 01 Cordless Rotary Tool Kit...
Dremel Stylus model 1100
Change the capacitor 220uF and it will most certainly work again. I got the idea from FixYa and it solved my problem!
Easy to change just 2 soldering points and a component costing around 0,2 Euros. If you do not know how to operate a soldering tool ask someone for a quick assistance. The switch takes around 2 min (1,5 min to open the charger and 0,5 min to change the component!).
/Johan
May 05, 2010 | Dremel & Stylus Lithium Ion Cordless...
Replace the docking station-charger of dremel stylus
ebay.com or www.craigslist.com
Try to find a used one maybe?
Sep 13, 2009 | Dremel Stylus Rotary Tool
Dremel 398 is dead as a Dodo.
I would contact Dremel direct at 1-800-437-3635 or Dremel.com and talk with one of their techs about this tool. Let me know if this doesn't work
May 15, 2009 | Dremel 3981 - 01 Electric Rotary Tools
Using the flex shaft attachement.
I dont think it should get that hot. Dremel has a program for the 225 Flex Shaft and for 17.90 they will exchange it for you. Send it to DREMEL 4631 E. Sunny Dunes Rd. Palm Springs, CA 92264. Their phone number is 1-800-275-2052. Hope this helps. Dave
Nov 02, 2008 | Dremel Variable - Speed Multipro Rotary...
Laminate Trimmers question
Router-neck cavities, pickup cavities; Laminate trimmer- saddle slots, smaller cavities, expanding existing pickup cavities on a finished instrument; Dremel- inlay inlay inlay.
Aug 27, 2008 | Freud FT750T Laminate Trimmer
Dremel 395 Type 2
REFERENCE M/N: 395 - Type 3 - Dremel does not have the parts listing on their site for some reason. I actually have the original I saved from 1988!
The part number for the Nylon Coupler is:
Illustration Code Number: 5
Description: Flex Coupling
Part Number: 529430970
This is all from Drawing (Form) Number:5296074 10-88
Jun 15, 2008 | Dremel Variable - Speed Multipro Rotary...
Tools & Hardware - Others Logo
Top Dremel Tools & Hardware - Others Experts
Mike
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
