Question about Tview T920PL-TN - 9.2" TFT LCD Monitor Car Headrest with 2 Video Inp
Have 2 Tview T920pl screens but wire harness has been cut. what wires go to what? i have the yellow video jack and a red and blk wire that has been cut. is there suppose to be 3 female rca cable
Need replacement wires ??????????????????
It's a 95 ford explorer and we bought a wiring harness for the new radio, the old radio worked fine and everything. We hooked up the new radio to the wiring harness and it powered on and everything, b
try hooking the radio power wires to the battery! To '' TEST'' twist red and yellow put on the poss. blk. on neg. ! take a speaker and test speaker wire out put! if don't work output is blown out! but will still work with rca jacks hook to small amp ! this to pull sound out of your radio for sure!!
Dec 27, 2012 | Cars & Trucks
1992 dodge dynasty radio diagram
Assuming the radio connects to the RS amplifier, the harness is as follows:
From fuse 13: PNK or BLK -> PNK/LT BLU -> PNK or BLK -> PNK/LT BLU -> radio (!)
From fuse 20: RED/WHT -> radio
From fuse 10: VIO -> amp
From radio: ORG and BLK/YEL to interior lights
From radio to amp: DK BLU/RED, BRN/RED, DK BLU/ORG, BRN/ LT BLU, VIO, DK GRN or DK GRN/WHT, DK BLU/WHT, BRN/YEL
From radio to pwr ant: DK RED/GRN
From RS amp to:
R. door: LT BLU/VIO and LT BLU/DK GRN
R. front: ORG/BLK and ORG/RED
R. rear: TAN/BLK, TAN/RED, TAN/DK GRN, and TAN/VIO
L. rear: WHT/DK GRN, WHT/VIO, WHT/BLK, WHT/RED
L. front: YEL/BLK and YEL/RED
L. door: LT GRN/DK GRN and LT GRN/VIO
Mar 17, 2017 | 1992 Dodge Dynasty
Screen wont work on my tview d74ts in-dash touch screen
Is it wired correctly? Red wire to switched ignition accesory, such as the factory radio was? Yellow to battery? Are their fuses intact?
How about the ground wire? Or did you just secure that to the dash? If so, that metal piece may not have a ground connection to the body shell, or the engine.
Jun 01, 2012 | Car Audio & Video
02 altima wiring for all three harnesses
12V'green '+ 'ignition harness '
' STARTER'black/red '+ 'ignition harness '
' SECOND STARTER'black/yellow '+ 'ignition harness '
' IGNITION'black/red '+ 'ignition harness '
' ACCESSORY'red '+ 'ignition harness '
' SECOND ACCESSORY'white/blue '+ 'ignition harness '
' POWER LOCK'pink *7 '- 'pin 37 @ BCM by fuse box '
' POWER UNLOCK'brown *7 '- 'pin 44 @ BCM by fuse box '
' LOCK MOTOR'yellow/red ' 'pin 30 @ BCM by fuse box '
' UNLOCK MOTOR'green/white ' 'pin 23 @ BCM by fuse box '
' DISARM DEFEAT'green/red ' 'pin 31 @ BCM by fuse box '
' PARKING LIGHTS +'red/blue ' 'driver kick panel '
' HEADLIGHTS'blu (L), red/yel (R)'+ 'IPDM E/R *1 '
' DOOR TRIGGER'*2 '- 'BCM to right of fuse box '
' DOME SUPERVISION'comes on with unlock' ' '
' TRUNK/HATCH PIN'purple/white '- 'pin 18 @ BCM by fuse box '
' HOOD PIN'yellow/black '- 'hood pin switch '
'TRNK/HTCH RELEASE'red/blk or blu/red '- 'pin 76 @ BCM by fuse box '
' FCTRY ALARM ARM'pink/blue *3 '- 'driver switch in door '
'FCTRY ALRM DISARM'white/blue *3 '- 'driver switch in door '
' TACHOMETER'white/green ' 'ECM behind glove box *4 '
' SPEED SENSE'blue/yellow *5 '8 'pin 9 @ instrument cluster '
' BRAKE WIRE'red/green '+ 'brake pedal switch '
' HORN TRIGGER'green/white '- 'steering column '
' WIPERS'blu (L), blu/blk (H)'- 'wiper motor '
' LF WINDOW UP/DN'blu/red - blu/wht 'A 'driver window switch '
' RF WINDOW UP/DN'green - yellow *6 'A 'driver kick panel '
' LR WINDOW UP/DN'purple - blue 'A 'driver kick panel '
' RR WINDOW UP/DN'red/yel - yel/blk 'A 'driver kick panel '
' SUN RF OPN/CLOSE'not recommended ' ' '
' RADIO 12V'yellow/green '+ 'radio '
' RADIO GROUND' ' ' '
' RADIO SWITCH'purple '+ 'radio '
' RADIO ILLUMINATE'red/blue '+ 'radio '
' POWER ANTENNA'green '+ 'radio '
' LF SPEAKER'blu/wht - blu/red ' 'radio or amp under rear deck'
' RF SPEAKER'wht/blk - blu/blk ' 'radio or amp under rear deck'
' LR SPEAKER'grn/yel - blk/yel ' 'radio or amp under rear deck'
' RR SPEAKER'blue - red ' 'radio or amp under rear deck'
here is a wire diagram for the altima .you should be able to just buy a radio harness to attach to the factory harness with diagram of wires on back and find out what color are what on your factory wires
623.10482.150x100.nn03b.jpg 02 harness for your car from scosche
http://www.tintingbyfredjohnson.com
Dec 31, 2010 | Car Audio & Video
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
DEH-1330R CAR CD PLAYER WHICH IS POWER WHICH IS SPEAKERS
Wiring is pretty much standard for all 4 channel radios. red is switched, yellow is your memory (constant power), black ground, purple/purple-blk, white/white-blk, grey/-grey-blk and green/green-blk all speakers the solids are positive and blk stripes are negatives. orange is illumination, blue maybe 2 are amp switched for power on/of and the other power anteanna. Its easiest to get a wiring harness for your car it will connect color to color and then plug directly into your factory harness with no splicing of the wires so when you trade in/sell your car the factory radio goes back in with ease.
Aug 06, 2009 | Pioneer Car Audio & Video
Need help with 2004 Hyundai Santa Fe Audio Wiring
Sounds like you need a light tester. I would guess that at least 8 of the wires are speaker + & - the others will be Main power and earth Possibly electric ariel, Memory store and a wire for the anti theft circuit. Assuming the stereo is factory. Any Audio shop can perform a test to clarify the purpose of the wires Wouldnt worry about the blank its probably a position for a newer or different model to yours. Steve in the UK
May 13, 2009 | 2004 Hyundai Santa Fe
Wiring diagram
First, you can buy a harness for whatever vehicle you're putting it into and the colors on THAT harness will match the harness on the radio.. With that said:
black---------ground
red------------12V Switched (ignition)
Yellow-------12V (constant)
blue-----------power antenna
blue/white--Amp turn on
orange-------dimmer
white--------Left front+
white/blk---Left Front -
Gray---------Rt Front+
Gray/blk----Rt front-
green--------left rear+
green/blk---left rear-
purple--------rt rear+
purple/blk---rt rear -
Aug 04, 2008 | Sony CDX-M610 CD Player
Splicing the wiring from a kenwood excelon kdc-x589 unit to a jeep harness
For the Kenwood KDC-X589:
yellow - always on B+12 such as battery + terminal
red - switched B+12 such as ACC of IGN switch
black - body/chassis ground (- battery)
orange/white - dimmer control wire (car light control switch)
gold - to my knowldege no gold
brown - mute control from mobile phone
pink/blk - external amplifier control/trigger wire
blue/white - power control wire similar in function as the orange/white
blue/blk - to my knowldege no blue/blk
blue - motorized/power antenna
For the vehicle, pls postback info on year and make/model.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 13, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
WIREING
Not familiar with that brand, but it should use the international standard colors: yellow- battery red- ignition black-ground white- left front + white/blk- left front - gray- rt front + gray/blk- rt front- purple- rt rear + purple/blk- rt rear- green- left rear+ grn/blk- left rear -
Sep 13, 2007 | T-View TView (DVD170TV) Motorized 7"...
Tview T920PL-TN - 9.2" TFT LCD Monitor Car Headrest with 2 Video Inp Logo
283 people viewed this question
Top Tview Car Audio & Video Experts
xxxxxx xxx
Are you a Tview Car Audio and Video Expert? Answer questions, earn points and help others
