Question about HP Pavilion Computers & Internet
My screen will come on for a few seconds if i unplug an then replug the inverter ,my external monitor works and you can see the desktop very dim if you look close on the laptop,
I have changed the inverter board 3 times same problem any suggestions ?
  • 3 Answers
Its the display illumination inverter ckt responsible if u can see lcd shadow
Posted on Apr 18, 2015
    Top Expert:
  • HP Master
  • 4,740 Answers
I would off said inverter but if you have done it 3 times as long as its the right inverters its not that,not sure but i would check your onboard graphics,or a lose wire going to the inverter.
somthing does not sound right.
Posted on Apr 17, 2015
  • tommy lee
    tommy lee Apr 18, 2015
    How do you check the graphics card ? i have a new screen with the inverter and the cable already installed it lasted a little longer about a minute but then did the same thing. you can see the desktop very dim in the background if you look really close but you can't make out what it says just that it is there, thanks for your reply and may God bless you.
  • noel
    noel Apr 18, 2015
    you may have to open it up and its on the motherboard
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Dark screen
IT is the inverter. The backlights usually turn the screen orangish color before they fail.
Nov 25, 2013 | Posiflex Computers & Internet
My laptop comes on but the monitor is blank
Your backlight is probably burnt out or the inverter needs replaced. The backlight will be a pain in the rear to do so you might want to try a new / used (working) inverter in it first. Hook your laptop up to a external desktop monitor. If you computer boots up, and you can see everything on the external display, you've got an inverter or backlight issue. Shine a flashlight on the laptop screen. You'll see a very dim image of your desktop.
Sep 09, 2012 | HP Pavilion dv4000 Notebook
Acer netbook AO751h screen does not work, external monitor works fine.
Hello !
Since an external monitor works, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
Hope this helps.
Sep 20, 2010 | Computers & Internet
My monitor does not power up when I come out of sleep mode. The screen is either dim going to black or white. I keep having to unplug and replug to get the screen to work.
mishwilly. If monitor will do same thing with different KNOWN GOOD pc, then monitor will need it's "switch-mode-power-supply" fixed. Could also need CCFL inverter circuit checked! Do you have warranty service? Follow the links to other web sites that you find in my FIXYA profile to read about other options open to you. 12fixlouie Read, read, read.
Feb 04, 2010 | Samsung 204T 20" LCD Monitor
Compaq Presairo V2310US no display on the screen, external monitor works
If the external monitor works than that is good news in a way because that means your video chip is good. Take a good close look at the screen, try to see if the desktop is actually there but just very dim. If you can make out a shadow or any part of the desktop then maybe just the video inverter has failed. Even if the inverter did fail, some lcds are so black that the desktop can't be seen regardless. In a case like this I would recommend not only getting a new screen but also the inverter as well, or replace the inverter first, it is only 15-20 dollars. Then, if the screen still doesn't come up, then change out the screen. Also make sure the data cable that attaches the motherboard to the back of the lcd is firmly seated in the socket, this can also cause a dark screen.
Jan 24, 2010 | HP LCD Display for Compaq Presario R4000
My notebook screen 3000 n100 goes dark after few second
This could be a faulty CCFL lamp.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 15, 2009 | Lenovo 3000 N100 0689 Notebook
LCD dim.
If you have replaced the screen and the inverter, about the only thing left is the flexible cable from the monitor to the video card. I take it that the Fn+F8 makes no difference?
May 23, 2009 | Dell Latitude L400 Notebook
LCD starts to display for about 2 seconds then goes dark.
lamp(s) perhaps.... with an LCD monitor (the desktop kind) you can shine a lite behind it. if you can see things on the screen it's the lamps... if you can't it's something else.
Robert
Aug 28, 2008 | Toshiba Satellite 1135-S125 Notebook
Computers & Internet Logo
52 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
