Question about Acer Aspire Z3801 All-In-One Desktop Pc Intel Core I3-2100 Processor, 3 Gb Ram, 1 Tb Hdd, Digital Tv Tuner, Windows 7 Home Premium With 22 Inch Multi Touch Screen Monitor
How to open and clean aspire z3801 - Acer Aspire Z3801 All-In-One Desktop Pc Intel Core I3-2100 Processor, 3 Gb Ram, 1 Tb Hdd, Digital Tv Tuner, Windows 7 Home Premium With 22 Inch Multi Touch Screen Monitor
    Brigadier General:
  • Acer Master
  • 3,400 Answers
  • 1,511 Answers
The idea of disassembling the unit is not practicable.
Use Canned Air in the open spaces to blow the dust out or a vacuum cleaner hose attached to the Air Out port.
If you disturb the integral electronics when opening the case you could render the unit useless. Why venture there?
Posted on Apr 17, 2015
    Top Expert:
  • Acer Master
  • 5,081 Answers
Touch screen
You can search and probably find one online but best to take to a repair shop
Jan 26, 2014 | Acer Aspire Z3801 All-In-One Desktop Pc...
Dvd rom not work
most of this slik dvd roms fail with time ,get yourself an external dvd/rw
Sep 17, 2013 | Acer Aspire Z3801 All-In-One Desktop Pc...
Acer aspire z3801 desk top pc . The dvd blue-ray stopped working. It is stuck. I have opened with paper clip from side hole but it is not responding. It appears dead
This is a problem caused by a broken gear jamming the Motor. or a burnt out MB.. (main board) more than likely the gear. These things are a bit complicated to repair and hence considered disposable.. The propper fix will be to buy a new drive and replace it.
if you wish to try repairing it. Remove it from the system and you will notice the motor that spins the disc. Its not spinning. See if its jammed or the wires broken and solderer it.. Ps by wires i am referring to the ribbon Its a bit difficult to re solder together use a low wattage iron.
Dec 27, 2012 | Acer Aspire Z3801 All-In-One Desktop Pc...
Acer Aspire Z3801 dvd-blue-ray player stopped working. Is now in locked position and does not open or close automatically or mnually
Send it back under warranty for dvd replacement, or
send to repair shop for dvd replacement, or
buy and use an external dvd player
White screen on Acer Aspire Z3801
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
Sep 26, 2012 | Acer Aspire Z3801 All-In-One Desktop Pc...
The disc drive on my acer Aspire 5742G will not read any music cd's or dvds. I makes plenty of noise as though it is trying to open it but nothing!
The CD/DVD drive may need reseating to make proper electrical connection. Remove this drive and insert it back into the laptop.
Next try cleanibg the drive.
The laser lens maybe dirty, use a CD/DVD lens cleaning kit to clean the lens int the drive.
If this does not fix your problem then the CD/DVD drive is faulty and needs to be replaced.
Apr 01, 2012 | Acer Aspire 5742G
Monitor wont recieve signal from computer aspire m3641
Your Acer Aspire computer system is not POSTing, or passing the Power On Self Test.
Claim warranty support before trying the following as opening the chassis in some cases voids current warranty.
Open the side panel of the computer chassis and remove the RAM modules. Clean the gold fingered connectors of the RAM modules with tissue paper. Once completed clean the actual RAM slots/dimms on the mainboard. Carefully use a vacuum cleaner.
Reinstall the RAM modules in the correct orientation. Power on the computer system.
Also see my published guides for more detail and further solutions as posted below:
My Computer is not turning on!!! Is it dead!!! No POST!!!
Take care!
damnor01
Jul 25, 2011 | Acer Aspire M3641 Dual Core E2200 PC...
My acer aspire M5100 getting into shudown mode
Check the temperature of the CPU in Bios. It is probably higher than the Safe temperature and it gets into shut down mode to protect itself.
Open it, detach the cooler from the CPU and clean it, detach the CPU from the socket, clean the paste from the top, put a new one, clean the socket and put everything back. It should work perfectly.
If you need further assistance, just leave a comment. Cheers
May 23, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
Acer aspire 9300 black screen (display adapter)
I have been fixing computers that has long beeps and short ones. It is usually attributed to memory problem connection. Open the memory compartment at the back of the PC then detach the memory card. Clean with cloth softly enough not to destroy the circuit board or a pencil eraser to clean-up dust that caused the connection blockade. Reconnect after cleaning.
Jun 21, 2009 | Acer Aspire 9300 Notebook
Acer Aspire Z3801 All-In-One Desktop Pc Intel Core I3-2100 Processor, 3 Gb Ram, 1 Tb Hdd, Digital Tv Tuner, Windows 7 Home Premium With 22 Inch Multi Touch Screen Monitor Logo
314 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
