Question about Frigidaire Heating & Cooling
Can I use my frigidaire outside of my window?
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 50 Answers
Dear Kayla Katt plz follow this link it will be help you about your query
http://www.frigidaire.com/Air-Conditioning-Dehumidifiers/Air-Conditioners/FRA065AT7/
Posted on Apr 17, 2015
Where is there a drain hole for the water?
Your Frigidaire window unit is the same as any other window unit. Typically window unit air conditioners don't have a drain. This is why you have to make sure the back of the unit (the end that goes outside) is slightly lower than the front when you put it in a window. When it gets so high with water it drains out the back onto the ground.
Sep 18, 2014 | Frigidaire Heating & Cooling
Frigidaire LRA074AT7
Do you have it pulling air from the outside of the house, or do you have it circulating air from the inside of the room only?
Aug 02, 2012 | Frigidaire Heating & Cooling
My frigidaire a/c is set 73fhrenheit after running for a time the temp. on the unite drops to 60 degrees by it self what is the problem ?
AC units, no matter if they are big/small, window or big central units. They will only cool the air in the room, or home, to about 15 degrees cooler than the outside air temperature. If you live in Georgia and it is 100?F+ outside, you will be lucky if the unit will reach 80?F even running all day.
Jul 22, 2012 | Frigidaire FRA186MT2 Window Air...
Window ac is blowing water
There is a drainage hole on the outside of the window unit. It is blocked. Remove power from the window unit. Unclog with a wire coat hanger.
Aug 30, 2011 | Frigidaire FAC124 wall/Window Air...
Does the Frigidaire FAH106S1T Thru-Wall/Window Air Conditioner recycle inside air or pull in air from outside? Also, how do I close the vent on this model?
yes it does recycle the inside air - it 'does not' pull outside air in (in the air conditioning mode).
The 'exhaust/outside air' vent - 'if it has one' (some don't these days) will usually be a manual pull/push lever, although I guess it might be a electrical/electronic switch.
hope this has helped.
Aug 05, 2011 | Frigidaire FAH106S1T Thru-Wall/Window Air...
We have found that our window air conditioner had water inbetween the windows. We had a heat advisories out for today so it was running for a while. It's in a upstairs window where it gets warmer then...
Quite often the window units need to be tilted slightly toward outside to allow drainage to run outside the window. Try pulling bottom inward slightly so rear is tilted downward at outside and see if that doesn't cure it. You should soon see dripping outside at back of unit where it should be. Make sure you check for small hole under back end and check that it is clean and open.
Jul 02, 2011 | Electrolux FRA102BT1 Air Conditioner
THE DRAIN HOLE FOR MY FRIDGIDAIRE AIR CONDITIONER IS IN THE WINDOW SILL, WHAT DO I DO ABOUT THE WATER ?
You will have to remove the unit fro the window,and take it outside and remove the cover,unless the sheel remains in the window,and use a water hose to clean all the debris out and clear the drain,this really needs to be done every year,also,make sure the tilt on the unit is enough for the water to drain outside,not in,if this was at all helpful,please rate thank you.
Jul 18, 2010 | Frigidaire FAC126P1 wall/window Air...
Leaking water from underneath.
Hello my name is Heath it will be my pleasure to assist you. The drain should be in the back of the unit outside . If you lean the air conditoner slightly toward the outside it should drain outside.
Jun 28, 2010 | Frigidaire FAA084P7 Thru-Wall/Window Air...
Does the Frigidaire FAC 126P1A need to be vented?
It must be installed in a window openeing or through the wall.
A load bearing wall is no problem.
Cutout the opening larger than the unit and install a header in the wall cutout.
Mar 12, 2009 | Frigidaire FAC126P1 wall/window Air...
Cleaning the gas stove
Hello Kayerich,
Welcome,
How hot is it?
Can you keep your hand on it?
Yes to that question, the outside window can be hot.
But usually it should not be hot enough to burn you.
Just a little hot!
You said, Last time we cleaned our gas stove the window shattered. We have gotten a new window and are cleaning it again. Is the outside window supposed to get hot?
Waiting your response.
Huuum
Please remember to leave a rating
Oct 19, 2008 | Frigidaire FGB24S5A Gas Single Oven
Heating & Cooling Logo
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
