Question about Cycling
How do I fix my chain on my bike?
HELP MEEEEEEEEEEEEEEEEEEEEEEEE
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 50 Answers
A quick post-ride cleaning is the first step to take, but it's not the only way to save yourself time and money as the season wears on. Here are four simple things you can do to keep your bike rolling like it's new.
1. Start with a clean chainThe vast majority of bike mechanics will tell you that the best thing you can do for your bike is to keep it clean. Wipe it down after each ride, especially if you've been riding in bad weather. But the most important piece of gear to keep dirt-free is your chain.
RELATED: 8 Essential Bike Tools for the Home Mechanic
Eric Fostvedt, mechanic for the professional Axeon Cycling Team, suggests using a thick-bristled brush to apply a citrus-based degreaser onto the chain and derailleur pulleys about every 100 miles. Wipe off the residual grime off with a clean rag and reapply chain lube.
You can also head off component wear by replacing your chain before it's too worn. Over time, chains stretch and create additional stress on parts. About once a month, use a chain checker (they're a cheap tool and Park Tool makes a good one). Insert the tool's pins between two chain links and press the swing-arm gauge tight; the gauge will indicate the amount of wear. Expect to replace your chain every 2,500-3,000 miles.
2. Wash the restWhen your bike is dirty, you don't need expensive products to clean it. A sponge, bucket of warm water, and dish soap works wonders, Fostvedt says. Aside from looking like a pro, a clean bike, like your clean chain, can keep all components - from bar tape to wheels - lasting longer.
As you're washing it down, keep an eye out for any scratches or cracks in the frame. If you notice anything suspicious, take it to your local shop for an in-depth inspection to determine if it's a frame crack or harmless paint scratch.
3. Lube your chain and shift cablesYou can use a lubricant specifically formulated for wet or dry conditions, but an all-purpose lube like Tri-Flow typically works just as well. Excess lube attracts extra grime. A drop per chain link is sufficient, but you can be less methodical and remove the extra grease by running the chain through a shop rag.
Shift cables need a touch of lube, but far less often than a newly-clean chain. When Fostvedt notices his shifting isn't as crisp, he drops just a small dab of Teflon-based Finish Line dry lube into the cable housing.
4. Keep an eye on the rubberBefore you ride, check that you have plenty of life left on your brake pads and tires. The grooves in your brake pads and tires are wear indicators. After those are gone, it's time to swap them out for new rubber. On tires, also make sure the sidewall isn't torn and there are no bulges.
Brake pads are simple to replace: Use a hex wrench to unscrew the holder (a brake shoe) from the caliper. Pry the worn rubber pad from the holder with a flat-head screwdriver or pliers. Slide the replacement pad into place. Replace the brake shoe, making sure it lines up with the rim's brake track.
- Robert Annis
Posted on Apr 17, 2015
  • 1,631 Answers
What do need help with?
Testimonial: "Never mind I got it thanks anyways...."
Bike chain broken, how to fix this?
Sometimes all it takes is a master link or "quick link," but you can't count on that. How to fix it depends on several factors. There are different chains for the various number of cogs/gears on the rear of the bike, and an older chain may require a different procedure than a newer one. Further, if the chain is badly worn it may need to be replaced, but then may not mesh well if the gears aren't replaced as well. Finally, just taking out the rest of the link (one full link is one outer and one inner) may make the chain too short, which could damage the bike.
It's best to take the chain and bike into a bike shop, or a bike co-op if there's one available. If you really want to know all the in's and out's see this link: Chain Maintenance
Oct 31, 2016 | Cycling
How do i fix the rear sprocket on my huffy rock it bicycle
on all single speed bikes, it has been my experience, that chain tension is the reason for the chain to come off, try tightening it again, since this seems to keep happening the chain may be stretched out now and replacing the chain and getting it tight should solve the issue.
Apr 30, 2014 | Huffy BMX 20" Boy's Rock It Bike
Kickstart aint working.... how do i fix this?
sounds like u sheared he role pin on the ger ortiming chain has broke and wrapped around the gears had a 500xr that broke the chain like i said
Dec 16, 2012 | Pit Bike 125cc 4 Stroke Dirt Bike
Chain Broke on a Huffy Tundra 18 speed 26" bike. I need to know the size chain to replace or the master link/chain connector to fix the chain.
if the bike has gears it does not have a master link, that is for single speed bikes only.
You will need an 8spd chain for your bike (1/2" x 3/32), these will fit any 6,7 or 8 spd bike. This requires a special tool to install ($8-$25), I would recommend taking into a bike shop and have them do it if you have no experience with this type of chain.
Side note: if you do own the tool, you can repair a broken chain for a temporary fix in the future, so may be worth buying. Check around, many bike shops offer basic repair classes and cover this.
Nov 14, 2010 | Huffy Men Mountain Bike (26")
My grandsons bike chain broke. Went to the store to buy a new chain. On the back of the package it said I needed a chain rivet extractor and of course, the store didn't carry that tool. How can I fix...
You should go to a bike shop, they can sell you a master link, and keep your own chain. Is your grandson's bike a 1 speed or a multi speed bike, if it is multi then you need a chain tool. Bike shops can do the job cheaper than you can buy the tool and it will be done right. Take the chain back to the store that didn't carry the tool.
Sep 18, 2010 | Bell Sports Bell Uni Chain Bicycle Chain...
Hi i have a thumpstar 120cc pitbike and the front coh where the chain goes on it locks up ever 5 meters you push it when its in neutral , then you push it back then it rolls again then when you push it...
Hi it sounds to me that the teeth on the front chain sprket could be worn so the chain locks,best thing to do is to take the side caseing off and check.(if it needs replaceing its always best to replace the back sproket and chain aswell,wish you all the best.
Jan 24, 2018 | Pit Bike 125cc 4 Stroke Dirt Bike
How do I fit a new chain on my mountain bike?
you can always get yourself a master link kit for your chain and cut the chain then lay it around the sprockets until the chain overlaps , count the number of links that overlap and leave just enough so you can cut off the excess chain and have enough links to splice the two ends of the chain back together so it will have enough slack to fit back on the sprockets , or you can also just purchase a shorter chain at any bike shop , bring your old chain with you so you can compare how much shorter your chain has to be , hope i was able to help you sincerely glenn mayer , please leave a nice rating if i was of help to you, thanks again for the question
Mar 06, 2009 | Cycling
Bicycle Chain Problem
Your chain problem is probably because your chain is not tightened and maintained.
You should clean your chain after a ride, and oil it (very little oil).
Good luck
Oct 29, 2008 | kawasaki 73026-9 KDX126FS Dual Suspension...
Cycling Logo
1,031 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
