Question about Grilling
BBQ does not get hot enough to cook properly. All gas jets are clean as BBQ is almost new
  • 494 Answers
This could simply be a matter of you turning the gas tank on too fast. The hose/regulator that connects to the tank has an excess flow valve built into it. Close the tank valve and disconnect the hose/regulator from the tank, then reconnect it. Now slowly turn the handle on the LP tank. See if that solves your problem.
Posted on Apr 18, 2015
  • 2,160 Answers
Blue flame? if flame is not blue, then air gap needs adjusting. if blue flame and burner control is on high, then could be your regulator. (assuming tank if full)
Posted on Apr 17, 2015
LOOKING FO A NATURAL GAS TO PROPANE CONVERSION KIT.
the change over requires different jets and adjustment of the air shroud around the chamber
there is a process to adjust to get correct flame burn and it is best done by an accredited gas fitter
the jets will be available from any BBQ or out door cooking specialist/ gas shop
Apr 08, 2016 | Grilling
Not hot enough
Check that the gas jet is not partially blocked limiting the amount of gas out. To up size my bbq to a hotter flame I used oxy welding set tip drills and gently opened up a size. worked a treat and cooked quicker. maybe you can get next size jets for your problem. check that the regulator is not restricting the gas flow.
May 28, 2013 | Fire Magic Grilling
Gas bbq
flame running back is an indication of insufficient gas pressure or flow. check and adjust the regulator and ensure that there is no blockage in the jets.
May 14, 2013 | Grilling
Bull bbq doesn't get hot enough?
Try cleaning all the burners they may be block and all the orfices.
Jul 04, 2012 | Bull Texan Grilling
How to char-broil burgers
You want to know how to char broil hamburgers right? Here is what you do! Start your BBQ 5 to 10 minutes before you put your burgers on (for gas BBQ) and let the metal racks heat up. Keep the top closed to let the heat go through the unit.
If your using a charcoal bbq wait until your coils are white hot and the racks are as hot as you can get them.
Don't buy the hamburger meat that has the smaller amount of fat in it. Get the stuff that has 15 to 20% fat in it. The juice in the fat will help cook the meat and taste better in a burger.
Put your rack on the lowest place as close to your fire/coals as possible.
When the bbq is hot Take your patties and plut them on the rack. If its hot enough you should hear a sizzle sound. DO NOT TURN THE MEAT. Let it sit on the grill and every few minutes take your spatula and press the meat flat on the grill to release more juices and get more attention from the flame or coals. This is what makes the black grill lines on the meat.
You only flip a grilled burger one time after putting it on the bbq. It should cook at least ten minutes or more on one side. If you turn the meat and there are no marks on it then you didn't wait long enough.
Sep 29, 2010 | Computers & Internet
Cadac Carri Chef bbq replacement gas valve.
Remove grey plastic cover by removing two screws inside cooking area, then pop handle off valve, undo nuts to release valve body, carefully remove two screws in body, watch out for spring!
Take the small hexagon jet out of other end, find a small straight item that will pass through hole where jet was, tap the internal part out of the main body , clean everything up, probably carbon on it! Apply a tiny bit of oil to the plug you tapped out, avoid the tiny hole in plug! Now reverse the strip down, making sure that the valve goes back together the right way and still turns through right sequence! Normal cause of it sticking is not pushing it in whilst turning off!
Email me at grundy
Oct 08, 2009 | CADAC Safari Chef Portable Grill
I have a Great Outdoor smoker that won't get hot.
I had the same problem with mine. I took the burner assembly at the knob apart and cleaned it and that worked for me. The grease from the meat dripped down on the gas orifice and hardened reduced the amount of gas being jetted to the burner. Hope this helps
May 31, 2009 | Great Outdoors 3600G
Not Hot!
We have had two grills that developed similar problems after sitting for a length of time and found that an insect had built a nest in the tubing leading from the regulator. A piece of pipe cleaner up the tube fixed the problem. Can't say if your's is the same problem but it is worth checking.
Nov 23, 2008 | Thermos Grill2Go Gas Grill 4656110
Gas BBQ - Won't light
hi Be sure the thermostat or heat dial is set properly. If the appliance has a pilot light, be sure it's working. make sure that you connected the pipeline correctly open the faucet of the tank try to fire it up ? working ? good... NO???? close everything(faucets,plugs...) your new tank that you connected is empty.... it happens.... have a good 1
Apr 06, 2006 | Barbeques Galore Turbo Classic 3-Burner...
Grilling Logo
185 people viewed this question
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
