Panasonic Dmr-ez48v Vhs/dvd Recorder Player Digital Tuner Combo Logo
A
Anonymous Posted on Apr 17, 2015
What does code T1 mean - Panasonic Dmr-ez48v Vhs/dvd Recorder Player Digital Tuner Combo
2answers
Which is the right partner of T1? IS THE T7? OR THE T4/ OTHER T2.IS THE T8 OR THE T5?
One needs to know what the voltage and phase(1 or 3) the unit is and what the power supply is.
I need ang diagram for hobart mixer 9 out wire T1/T2/T3 AND T4/T5/T6, T7/T8/T9 which is the right partner of t1/t2/t3???
Having 9 wires means it is a 3 phase motor.
For 220 to 240 Volts - L1, T1 and T7 go together. L2, T2 and T8 go together. L3, T3 and T9 go together. T4, T5 and T6 go together.
For 440 to 480 Volts - L1 and T1 go together. L2 and T2 go together. L3 and T3 go together. T4 and T7 go together. T5 and T8 go together. T6 and T9 go together.
2answers
When you take a picture with the dcs-t1 camera it is black and grainy...i changed the memory card and the screen shows the pictures on the other card just fine...so the screen works fine..
It si problem of ccd imager chip that is defective in your camera and need to be replaced by camera technician because camera will take apart.
Hope this will help.
1helpful
Sony DSC-T1 when turned on screen has vertical lines, cannot see subject.
if this problum is at both mode mean camera & play back then your lcd is defective & if only at camera mode then ccd imager ic is defective
1helpful
Error code E0540-8002 on canon ir5570
hello sir; The error code you display, it means the finisher top tray lift motor, sensor problem, check the sensor see is on right place.
How to create owr own calculater
for all os ? you must use java language! this is the code:
//<applet code="calmayank"height=300 width=300></applet>
import java.awt.*;
import javax.swing.*;
import java.awt.event.*;
public class calmayank extends JApplet
implements ActionListener
JTextField t1;
JButton b1,b2,b3,b4,b5,b6,b7,b8,b9,b10,
b11,b12,b13,b14,b15,b16,b17,b18,b19,b20;
GridLayout gl;
JPanel p1,p2,p3;
public void init()
gl=new GridLayout(5,4);
p1=new JPanel();
p2=new JPanel();
p3=new JPanel();
p1.setLayout(gl);
t1=new JTextField(17);
b1=new JButton("1");
b2=new JButton("2");
b3=new JButton("3");
b4=new JButton("4");
b5=new JButton("5");
b6=new JButton("6");
b7=new JButton("7");
b8=new JButton("8");
b9=new JButton("9");
b10=new JButton("0");
b11=new JButton("+");
b12=new JButton("-");
b13=new JButton("*");
b14=new JButton("/");
b15=new JButton("@");
b16=new JButton("$");
b17=new JButton("%");
b18=new JButton(".");
b19=new JButton("?");
b20=new JButton("=");
p2.add(t1);
p1.add(b1);
p1.add(b2);
p1.add(b3);
p1.add(b4);
p1.add(b5);
p1.add(b6);
p1.add(b7);
p1.add(b8);
p1.add(b9);
p1.add(b10);
p1.add(b11);
p1.add(b12);
p1.add(b13);
p1.add(b14);
p1.add(b15);
p1.add(b16);
p1.add(b17);
p1.add(b18);
p1.add(b19);
p1.add(b20);
p3.add(p2);
p3.add(p1);
getContentPane().add(p3);
b1.addActionListener(this);
b2.addActionListener(this);
b3.addActionListener(this);
b4.addActionListener(this);
b5.addActionListener(this);
b6.addActionListener(this);
b7.addActionListener(this);
b8.addActionListener(this);
b9.addActionListener(this);
public void actionPerformed(ActionEvent e)
if(e.getSource()==b1)
t1.setText("1");
else if(e.getSource()==b2)
t1.setText("2");
else if(e.getSource()==b3)
t1.setText("3");
else if(e.getSource()==b4)
t1.setText("4");
else if(e.getSource()==b5)
t1.setText("5");
else if(e.getSource()==b6)
t1.setText("6");
else if(e.getSource()==b7)
t1.setText("7");
else if(e.getSource()==b8)
t1.setText("8");
else if(e.getSource()==b9)
t1.setText("9");
1helpful
Point to Point T1 Using Cisco 2800 Routers?
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
