G1022I DRAIN PUMP ALWAYS RUNS WHEN POWER IS APPLIED
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check pressour switch
Posted on Apr 17, 2015
Samsung washer doesn't drain so I removed and tested pump and it runs fine. Is there some reason why I'm not getting power to the pump?
Check the turn nob and the corresponding switches.. if theres power going to the pump the something from the setting to the pump is broke. Id assume the contacts are not connecting thus skipping the drain cycle or youve got a bad switch
Oct 21, 2016 | Samsung Washing Machines
Pump runs as soon a power applied
Possible there is water remaining on the sump , possible the pump is clogged or finally this can be due to failure of the program controller module.
You need to isolate the case- the pump and the controller- to confirm the fault.
Jan 12, 2013 | Washing Machines
Installation manual for Miele g1022i
you can find the manual for Miele g1022i at this website. good luck
Jul 22, 2012 | Miele Dishwashers
Have a Miele G1022i dishwasher (built in). It makes a humming noise when the power supply is turned on. All the indicator lights flash. Have tried cleaning out the drain and removed water from the salt...
A fairly common occurence with Miele dishwashers is the seal on the pump/motor assambly swells up freezeing the motor.Miele makes tool to free it up very easily,if it doesnt reoccur the seal just swelled and it will be ok once freed up.If it does reoccur the seal needs to be replaced. Any Miele authorized service company will have this tool and could free the motor up within 5 minutes and only a couple uses will tell if it will swell again and need to be replaced.
Gene
Aug 05, 2011 | Dishwashers
Dishwasher won't pump out waste water. Pump is good(checked ok, it runs when voltage is applied to it)
Hi mc_ionics,
Firstly, do the following:
- Make sure the attached wires to the Drain Pump is installed firmly, when re-installing the drain pump.
- Inspect the Drainage hose at the back for kinks. - If any, straighten the hose
- Open the unit, and at the bottom sump check the small drain pump area for any foreign object that may be obstructing it.You can remove the filter, as well as the metalish sieve underneath it, check the sump underneath near the drainage holes, make sure nothing is obstructing the flow out of the machine from there.
If still not draining, check power from the PC Board to the Drain Pump, you may have a faulty PC Board
Kind Regards :-)
If you found this solution helpful, please rate it.
Jul 06, 2011 | Dishwashers
Not spinning no draining no 120 volts to the pump no power for pump from machine control board replaced machine control board still have sam\e problem
Do you have the FAV6800A/FAV9800A Service Manual?
Did you measure 120VAC to the Drain Pump at the connector on the Drain Pump with power applied to the drain pump or at the Control Board Conn_P8 Pin 4 for Hot to neutral or cabinet ground?
Did you measure this while in Service Mode with the drain pump turned on in Service Mode?
Do you have the schematic of you FAV6800A? It is a FAV6800A correct?
What is the issue with not spinning? If you run a Spin Only cycle will the Spin cycle complete? Are you failing the Spin Cycle with unbalance errors such as DC or UC?
If you truly want to DIY the fix you need to go to a true DIY appliance forum such as this; http://forum.appliancepartspros.com/washer-repair/ I will continue to help you at that forum. This forum is terrible for posting pics and other info.
Rich
Dec 02, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Lg wm1832 will not pump water out the dran pump is
If the pump does not work when power is applied separately, you may find, upon disassembly, that the impeller has disintegrated.
Mar 08, 2017 | LG WM-1832C Front Load Washer
LG WF T1022TP Drain Problem
The problem has been traced to the water pump that does not turn on every occation that the power is applied. The pump just vibrates. Quess that it is worn out, and needs to be replaced.
Sep 12, 2008 | Washing Machines
Bosch SHX46A02UC-21
float switch is in the flood position and the drain pump is running.. there is water under the dishwasher or that switch is stuck up..
Aug 19, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Washing Machines Logo
Top Washing Machines Experts
