Question about Power Acoustik PD-931NB
This new unit just wired up, everything works EXCEPT IT WON'T ACCEPT ANY DVD's
Not motoring them, if pushed manually to far I won't be able to retrieve and probably won't play anyway is player defective product or a wire missed
My remote won't work for my DMP-BD75
If both the remote (which can be tested by a shop for free) AND the front buttons do not work I suspect the unit may have a lock out that disables everything on both except for on off..........
Oct 30, 2012 | Panasonic DMP-BD60K Blu-ray/DVD Player
CLarke 130 en everything works Great except when I select # 4 on the heat then it won't feed when the trigger is pulled?
i put a new motor on the welder an i have 9 to 12 vote coming to the motor but the motor wont run all works but the motor
Mar 14, 2012 | Clarke Power Products Clarke 130EN...
Memorex 3202-3223 dvd burner disc tray won't open
Try reseating the DVD drive so it makes proper connection.
Mar 05, 2012 | Computers & Internet
How do you unlock an Audiovox D1788?
Hello
Enter the Menu screen, select, preference, select default, and OK.
If the problem is with password forgot, the default passord of this unit is [ 3308]. Enter this password on the first screen. Sometimes the unit won't accept this passord for the first time to cheat you, enter this pasword again. After that, you can enter your own passord. OK.
Nov 17, 2011 | Audiovox D1788 Portable DVD Player
Dvd tray won't open
The tray needs a new motor with a new pulley that does not slip on its shaft and get a new belt too.
It is easy to pull the dvd tray unit out of a GO VIDEO DVD+VCR machine to replace the motor with new pulley on it and the belt should be renewed too.The motor NOW may run only to push out the tray but it will not pull it in to LOAD the DVD or CD.
This is what I found after troble-shooting the function.
From Jim, and I need the same things. Can anyone tell me where I might buy those idems? lemsojim@gmail.com
Oct 07, 2011 | GoVideo Go Video DVD/VCR Combo
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
My external mounted pad lights up, but won't accept the new code after erasing all existing codes. the drive unit lights, the light bulb works, the led turns on and flashes, but the new code will not...
Make sure you are doing it like this.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
nm0hapqiutzxjjkaaaaaaelftksuqmcc
Aug 30, 2011 | Sears Craftsman LiftMaster Chamberlain...
Sony RDR-GX360 won't respond to any buttons on unit or remote. Only function that works is power button. Disk tray won't even open.
Try unplug,replug the unit back like about an hour later for the unit for resetting itself back to factory setting.If getting the same result the unit might have a shorted motor drive for the disc tray.Or shorted control panel on the unit itself.Well,this thing a basic DVD player only wright?If u can tries take it aparts and check out tries to repair it ur self that great.If u tries the shops,not worth it.Trash it.These basic DVD player only are very cheap now.U can get one brand new like $40 dollars.
Aug 11, 2011 | Sony DVP-S360D DVD Player
My dvd won't play. every dvd i put in, it says bad disc. the vcr works fine. is it time for a new system. i tried a head cleaner and it says bad disc
Not necessarily time for a new one. I would give the DVD player a good cleaning before you consider a new unit. A good cleaning disk with some little bristles on it. Run it through three full times. DVD players are far more sensitive than VCRs and have to be cleaned even two weeks or so. When they get real dirty it can take some fooling with to get the DVD player to even accept the cleaning disk. But if it just won't accept the cleaning disk and you can't watch a DVD in it then it's time for a new one. I had a DVD player one time that took an hour of fooling around with before it got cleaned good enough to play DVDs. Worked for a couple years afterward.
Regards, Tony
Apr 19, 2011 | GoVideo Go Video DVD/VCR Combo
Power Acoustik PD-931NB Logo
49 people viewed this question
Top Power Acoustik Audio Players & Recorders Experts
Ryan Lutton
Ryan Lutton
 Grubhead
Grubhead
richard foulk
Are you a Power Acoustik Audio Player and Recorder Expert? Answer questions, earn points and help others
