Question about Frigidaire ATF6000ES Front Load Washer
What does code cd mean??
Wont spin to get water out of clothes when you open the door inside is hot as well as the clothes
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 60 Answers
Not sure about CD code but the inside would be as hot as the clothes as the water gets hot it heats all. Will the machine agitate to wash.? If so look for a rubber or plastic tube from the bottom of the drum to the pressure switch. Check this tube is clear. If not clear it and replace and try again. If this doesn't work check the pressure switch by blowing into it while using a meter across the terminals. Replace if needed.
Posted on Apr 17, 2015
I turned the Bosch Series 4 washing machine knob to the off position too soon after the load had finished washing. How do I now open the door?
Most washers will not unlock the door if it senses any water inside, select drain and spin or rinse and spin to rinse the clothes and drain the water. Once it has completed the cycle the door should unlock. If it does not there is usually an emergency release on the look lock inside the machine by removing the top or front panel.
Dec 03, 2017 | Bosch Washing Machines
Washer won't work and door is locked shut with clothes inside. Can I get the door open manually?
turn off . turn off power point. Wait 3 minutes then turn on power point. Try blowing on drain pipe then turn dial to spin cycle .
See if water pump is engaged during spin cycle.
Don't know if you can manually open the door
Had a similar problem and found the water pump was not pumping the water out and spin cycle was failing to complete.
Check filter of front loader as well .
Mar 19, 2016 | Washing Machines
Smoke, burning smell coming from my machine. Door wont open and clothes and water inside is black
the bad smell you refer to is a smell of the electric motor burned out have the motor replaced the machine should be ok
Nov 23, 2017 | Whirlpool Washing Machines
Won't drain the water anymore
Drain motor is usually located on the bottom of the machine. Hopefully you have an access panel separate from the main door panel. Should be a hose coming in and a hose going out. Put the machine in spin cycle and see if you can feel the pump spinning. If the pump is very hot, chances are something is blocking it. They will usually have an access port that can be opened up just for this reason, be ready to catch the water when you open it up, and please turn the machine off first. If you get no sign of life from your pump it may have died. Also check for any blockages in the drain lines. All of this should be easily accomplished with a couple screwdrivers and towels
Apr 10, 2013 | Baumatic BTWM4 Front Load Washer
My machine has stopped half way through the cycle, hasn't rinsed or had it's final spin and says DOOR on the display. The door is properly closed and now wont go on ant other program or fill up with...
Try a reset of the washers' operating sytem by unplugging it, waiting a few minutes and then plugging it back in. It may restart the cycle all over or it may do nothing and allow you toopen the door. If you do finish the cycle and/or get the door open, check the seal thouroughly to make sure there is no debris and/or coins in the seal. It would be a good time to clean the seal as well with hot water and a soft cloth if you have not done so recently.
Let me know if this works. If it does not , please let us know the make and model of your machine.
Dec 19, 2010 | Washing Machines
How to operate the washing machines front load washer brandt bf850
  • Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
  • Fill the detergent receptacle on the front of the washing machine, making sure not to fill it past the indicated line. Always use a liquid detergent that is designed for front-loading washing machines.
  • Add bleach or fabric softener, if needed. Most front-loading washing machines have a section for fabric softener inside the detergent receptacle. Check the instructions on the bleach to find out when it should be added to the washing machine.
  • Close the front door of the washing machine and make sure it locks into place. The machine usually will not turn on unless the door is securely locked.
  • Check the owner's manual to find out how to select the different options and wash cycles. As a general rule, use warm or cold water for most types of colored clothing. Hot water should only be used when washing white cotton items.
  • Start the front-loading washing machine and let it run through the entire wash, rinse and spin cycles before opening the door to unload the clothing.
  • Please rate this solution. Regards.
    Nov 04, 2010 | Brandt WFH1176 Front Load Washer
    I have a GE dryer that won't dry our clothes. It heats up, but water is all over the inside door and the lint that comes out of the hose in the back is wet! The outside of the dryer (the top in...
    It really sounds like your washing machine is not spinning the clothes out enough. Have they been wetter than usual lately? The dryer could just be struggling to keep up with the heavier / wetter load as there is no reason for it to create moisture on it's own.
    Oct 06, 2010 | GE Dryers
    FTF530FS Front Load washing machine. Clothes smell.
    all front load washers have the problem. Mold and a build up or dirt and soap and fabric softner cause s old musty smell. The low water use makes the machine dirty and build up inside. Run a few Hot water washes with out clothing, Run it empty ,(run your hot water neer your washer to get the cold water out of the house pipes) hot water and pour bleach in side, 2 or more cups. Keep doing it. When your not using washer leave the door open so air can get inside. Hot wash,es with bleach will keep it clean, also dont use fab softner.
    Nov 11, 2009 | Frigidaire FTF530FS Front Load Washer
    ELectrolux frontloader EWF1090 door wont open
    Make sure you drain the machine first by setting a spin cycle manually and see if it releases the door after a few minutes. If that fails then switch off the machine and leave for 5 mins, door should release but you could end up with water on the floor. After this clean your filter and check you water pump, then try a short cycle without clothes.
    Apr 11, 2009 | Electrolux Washing Machines
    Not drying
    I know you cleaned the lint vent but your vent hose is clogged or damaged and there is no air exchange thru the dryer Air can only hold 100% humidity. You could dry your clothes for 10 hours but the air in the dryer is saturated with water and can not hold anymore so your clothes wont dry. Check behind your dryer and Ill bet the vent line is damaged. The problem is the air is not getting out of the dryer. Check the flapper at the end of the vent line. With the dryer running go to the end of the vent hose and there will be no air coming thru.
    Oct 15, 2008 | Roper REX4634KQ Electric Dryer
    Frigidaire ATF6000ES Front Load Washer Logo
    76 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
