Question about Frigidaire Ovens
Frigidaire FEF365BGWC bake element went out when pulling out I forgot to unplug from wall. Sparks flew . Now nothing is working. It's getting power from wall.
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 123 Answers
Most likely main control board got burned. Need to change it. Expensive.... Sorry
Posted on Apr 25, 2015
  • Frigidaire Master
  • 5,323 Answers
You probably blew a thermal fuse usually located along the back wall covered by a metal plate
Posted on Apr 17, 2015
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
Check all of your high limit safety switches. Possibility you may have fried the transformer on the main control board
  • Joseph McCormick Apr 17, 2015
    Is there anyway to check to see if voltage coming of the transformer
  • Luke Thomas Apr 21, 2015
    Yes, should be 24 volts leaving transformer I think
dgjtex
  • 405 Answers
SOURCE: Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Posted on Dec 27, 2008
  • 135 Answers
SOURCE: frigidaire wall oven will not heat up very fast
The clock control has a relay that turns on the element. It could be failed and would require a new clock control.
Posted on Aug 27, 2009
  • 1796 Answers
SOURCE: The Oven is a Frigidaire
Hi!!
It wont hurt to try to reset the Electronic Clock Control by disconnecting power to the unit for a couple of minutes, connect it back up and check operation. If problem still present, Check the latch/lock motor, door latch, oven temp. probe and all wiring specially at the terminal block (see diagram for component picture and location) if it OK, most likely the problem is on the electronic clock control (aka EOC). Replace it
The part number for the EOC is AP2125564, this board costs about $200, you may want to try the following link to have your board re manufactured for a fraction of the cost. http://www.appliance411.com/links/jump.cgi?ID=769
Here are the break down diagrams for the Frigidaire range Model FEF365BGWC
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=110576&diagram_id=242946#d242946
Good Luck!!
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Nov 04, 2010
  • 1531 Answers
SOURCE: I have a frigidaire 30" wall oven GLEB30T8CBA.
The control on the upper bake element has failed.and needs to be replaced
Posted on Nov 28, 2010
SOURCE: Frigidaire wall over model number
I had this problem a year ago (both elements worked in top oven but only broil element worked in the lower of the dual ovens). I swapped elements around but the problem was still the bottom element bottom oven.
So I called the repairman. He replaced the relay board (Part #AP2127301) for the lower oven, and it worked again. Yippee.
But now a year later, I have the exact same problem. Lower element on lower oven is not working (Frigidaire you have got to be kidding)!
However this time I decided to take a look at the relay board myself, to at least save the expense of the repairman. I looked closely at the board and thought I saw a cold solder joint on relay K4. But just to be safe I touched up all the connections on all the relays with flux and a soldering iron.
Works perfectly again !!
Please if you try this, disconnect the power first. In fact if I had to tell you that, then just call somebody.
Posted on Feb 13, 2011
How do i test a control panel of a frigidaire wall oven
Good Morning Friend,
I understand that you want to know how to test the control panel on your Frigidaire wall oven, model# FEB386WECH, due to the bake element not working. I also see that you have changed the bake element and only the broil works. Typically, this is not a do it yourself job, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why the bake element is not working. Hope this is helpful.
-Best Regards-
WP
Jul 07, 2014 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire DGES388DS2 electric single oven
Did you reset the house circuit breaker that supplies power to the oven?
Apr 24, 2012 | Frigidaire Ovens
How do I replace my oven element
Hello.
Theoven is a particularly sturdy piece of kitchen equipment. It can handle dailyuse and still perform as needed. But of course, as with everything over time,the oven can eventually have some things go wrong with it. The first signs maybe subtle, like your cake not being cooked through, or you may notice the oventaking much longer than usual to come to temperature. When looking inside theoven as it is heating, you may notice tiny sparks along the bake element. Anyof these symptoms may mean it's time to replace the bake element.Instructionsand tools below Screwdriver, Newbake element, Electrical tape, Fiberglass tape, Flashlight1 The first step when it comes to working on yourelectric oven is to turn the breaker off at your home's service panel, orbreaker box. This is extremely important, because most electric ovens require220-volt electricity to operate, and that voltage won't only hit you hard, itcan kill you. Place a sign on your breaker panel stating that you are workingon the electrical. As an added precaution, unplug the oven from the walloutlet. Remove the drawer below the oven chamber to see if the plug isaccessible from there. Otherwise, you may have to pull out the oven a bit tounplug it.2 Be sure that the oven has not been used in a whileand that the elements are completely cool. Remove all of the racks from insidethe oven. If it makes it more comfortable, you can even remove the oven door byopening it and sliding it off of the "arms" that hold it in place.3 Locate the bake element. It resembles a metal tubethat's been bent into a square shape and it is located on the bottom of theoven's interior. It can be quite dark inside the oven, so grab your flashlightand shine it to the rear of the oven's interior to locate where the bakeelement is connected to the oven wall.4 There will be two screws holding the bake element inplace. Remove the two screws and place them somewhere where you will not losethem. Now, pull the bake element out of the oven wall. There will be wiresattached to each "leg" of the bake element. Note: There is usuallynot much wire to work with, so do not pull too hard. Once you have about 4 or 5inches of wire exposed, place a piece of black electrical tape over the wire atthe point where it enters the oven. This will help keep the wire from fallingback inside the hole.5 At the point where the wires are connected to thebake element, you should see a screw. Remove the screws and separate the wiresfrom the bake element. Keep the old element for reference when shopping for anew element that matches the old one exactly.6 Install the new element by connecting one wire toeach leg of the element with the screws, just as they were with the oldelement. Wrap a layer of white fiberglass tape around the terminals. Push thewires back through the holes in the rear of the oven until the bake element isback in position. Use the screws to secure the new element to the oven wall, asbefore.7 Replace the oven door if you removed itearlier. Plug in the oven, then turn the breaker back on. Turn on the oven andtest the new element. You may notice some smoke coming off of the element as itheats up for the first time. This is ok, as these are just oils burning off ofit. The smoke will stop in a few seconds.Thanks.
Sep 28, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Have a frigidaire oven, model# PLES389ECE. Broiler heating heats up but lower (bake) element does not. Element need replacing?
mos likely yes... but to confirm is very easy... unplug unit or turn circuit breaker off... in the oven with door open you will see the back of bake element where it goes into oven wall a couple of screws remove them and you should be able to gently pull element out...there are 2 terminals connected to element with a wire attached to each of them... first we are making sure the wire hasn't burnt off or cam edisconnected and second we can remove wires and use a volt meter and test power... set it up so you don't get electricuted and tuen oven on bake 350 do you have power coming to the wires with element diconnected from wires...if so then you have a bad element if not then a bad thermal cutooff usually located in back of unit ... good luck to you...
Jan 11, 2011 | Frigidaire Ovens
Nov 28, 2010 | Frigidaire 30" Built-In Double Electric...
Bake not working
Well, to ensure the element isn't bad, you can take an ohm meter to the contacts of it and measure the resistance. It should be around 20 ohms. If it is much greater or infinite, the element is bad. To get to the contacts you will need to unplug the oven, pull it away from the wall and remove the rear panel. Then disconnect the element wiring and touch the probes from the meter to the contacts on the element. Otherwise, usually, the temp sensor is bad if the broiler still works, this is a small pencil shaped rod on the inside top of the oven. You can test it the same way and it again should be around 20 ohms. You can order a new parts locally or from repairclinic.com. Let me know what you find.
Benjamin
Nov 13, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
248 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
