Fast forward and rewind seem to be working
SOURCE: My Teac R-H500 tape deck will not play tapes
The belts will have failed. You will need to replace them for the deck to be reliable. If you are mechanically minded I can talk you through it... You giving me a FixYa rating will help my profile and loosen my lips on how to overhaul your deck. :)
SOURCE: Denon DRM 740 tape does not play
I had a similar problem with A Mitsubishi cassette deck, several years ago.
The actual problem, is a sticking switch/relay/solenoid whichevers applicable in your case.
Without even opening up the casing or tampering with the Unit.
Try constant Stop/fast forward. Stop/rewind. power Off/On. You,ll find after several attempts, the deck will find it,s own stability level. and unstick whatever it is, thats jammed or seized.
As you have,nt used for a long period of time. You,ve gotta Coax it back to full functionality.
If you,ve got lots of patience, you,ll find that this will work.
Mike @ compurepair.
SOURCE: Nakamichi BX-125 Cassette DEck
Unit probably needs belts. Over time, belts may become slack or decompose into tar-like compound. In this case, the deck will need to be cleaned and belts replaced. Take to pro/tech
SOURCE: Error F03
I suspect that only one capstan works, The belt driving it might be broken or something else on the drive.
SOURCE: tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
