Question about Exercise & Fitness
Gold's Gym Trainer 315 has an oily substance when it's moved. It looks dark almost like car oil.
nenalex2002
  • 134 Answers
SOURCE: oily coolant
yes, it is a definite sign of blown head gasket.
I did have only once a problem similar where the engine block was cracked but other than that,bet on the head gasket.
Take a coolant system pressure measurement, (if your head gasket is blown, the pressure in your coolant system would go down slowly)
Posted on Mar 23, 2009
SOURCE: pulley system on orion cross trainer (multi gym)
hi i can help u i have delta orion multi gym if u email me on saleem78618@hotmail.com will forward u pitures of pulley system .sal
Posted on May 16, 2009
monkeybear45
  • 94 Answers
SOURCE: Oil clean, oily antifreeze, blue smoke
Bet it's either a bad head gasket or intake gasket.
Is there any wetness around the area where the engine
head meets the block? Pooling around or near the intake plenum/manifold?
Posted on Nov 27, 2009
Testimonial: "thanks for the quick reply. What puzzles is me coolant is/looks mixed with oil, but oil looks clean. I will keep you posted if anything new arises."
  • 538 Answers
SOURCE: it is leaking muliple substances. one is red
The "Red" is transmission fluid, the "Clear" is most likely power steering fluid, or it could be "refrigerent oil" from the A/C. I don't know what could be leaking in the rear of the car maybe oil from one of the rear struts or maybe brake fluid. Do the brakes seem to work OK yet? If so it's probably not brake fluid. It could be condensation coming out of the muffler, there a weap hole in the muffler to allow excess water to run out. It might be picking up some color from the muffler. The transmission and the power steering are the biggest concerns you don't want to let the fluid level get low on either of those. If the transmission is leaking on the right side it's most likely the axel seal or maybe the pan gasket. Neither of these should be an expensive fix. But, you should get it to a shop and have it checked out. Try to find an independent shop instead of the dealer the independents are usually cheaper and do just as good of work. Get an estimate!!
Posted on Feb 09, 2010
maxtreadmill
  • 832 Answers
SOURCE: how to assemble a gold gym millennia series highr...
Call Icon Fitness @1-800-999-3756 they be able to locate a manual for good luck!!
Posted on May 23, 2010
I have a 2005 ford territory and there seems to be oil in the water.I run it for about 1 min and a oily dark pinkish substance oozes out from the cap in the water resiviour?
That is transmission fluid . Transmission cooler line's go into radiator .Oil in water would have a white or brownish color .
Feb 22, 2017 | Ford Cars & Trucks
The buttons on my tredmill only work when they want too why.. its a trainer 480 from gold gym
Chances are the oil and sweat from your fingers have gotten under the buttons, the oil film insulates the contacts and they stop working. or work intermittently. Open it up, clean all the contacts on the circuit board (q-tip & rubbing alcohol), as swell as the bottom of each button, then reassemble.
Feb 18, 2015 | Exercise & Fitness
Noticed an oily substance on the left front came out but cannot see where coming from -checked the oil and that is fine
More than likely it is leaking a few drops of engine oil either trough the valve cover gasket or from one of the valve cover bolts. more like the valve cover. Could be just loose. Check the bolts for torque.
Apr 12, 2014 | 1996 Honda GL 1500 SE Gold Wing
I have a gold gym trainer 410 treadmill that by a power out stop working I notice the motor card was burned out so I bought a used one in ebay but still wont turned on what could be wrong with it
you may have a faulty board.Does it have a light on it when you turn it on. If not it is faulty or the power lead is faulty or safety switch is faulty.
If all else fails call a tech to come out and look at it for you.
Sep 25, 2013 | Golds Gym Trainer 410 Treadmill
Gym, cross training and Personal trainer...Please help me to choose
Hi
A personal trainer will motivate you to work hard, train hard and gain the the look you want. If you are serious about hitting the gym and training hard to lose weight then you don't need a personal trainer. You just motivate your self into working hard. Personal trainers are mainly for advice and help for those people who find them selves to be lazy.
I recon you should go gym for about 2 month and work hard. If you don't feel satisfied then the second option is still there.
Thank you
Jun 10, 2013 | Health & Beauty
My Golds Gym trainer 480 treadmill wont start and none of the buttons work except for the up and down arrows for the incline.
my gold,s gym trainer 480 will ot run,everthing light up on console. could it be a fuse?
Oct 20, 2012 | Exercise & Fitness
How to battle the gym leader in eterna city
The Gym leader for Eterna City is Gardenia, a Grass-Type user. In her Gym is a big clock, which is used to get to each trainer. You have to defeat all the trainers before you face Gardenia, mainly because the clock's hands will move after each win, moving you to the next trainer. Grass types are weak against Fire, Ice, Flying, Bug, and Poison.
May 05, 2010 | Nintendo Pokemon Pearl Version for DS
How do i get thru to the fourth gym
How to get through the fourth game is easy; you move your character in different ways until you make it to the next person, if you mess up, you have to keep going the same ways each time until you get to the gym leader! Good luck!
Nov 04, 2008 | Nintendo Pokemon Gold
PAC L90 leaking oily substance
it leaked all the freon and oil out .
it needs to be vacuumed and oil replenished.
filled with freon.
should only cost you bout 50.give or take
as they use very little freon.
a shrader valve port has to be added to introduce the freon. takes just a few seconds.
May 23, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Exercise & Fitness Logo
186 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
