When the machine is on it's final spin which is extremely fast it sounds like there is a small stone inside the drum but I've looked and can't find anything inside the drum please help????????
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Probly pump makeing noise
Posted on Apr 17, 2015
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
When in fast spin there is a loud rattling sound as though there are stones in the drum
You could have something fast between the inner and outer drum, or one or more of the drum paddles is loose..
Remove lower rear panel of washer, remove the belt, and from the front spin the drum by hand, this this will show if the drum bearings are o/k.
There should be little or no noise from the drum.
If it is rumbling, or feels rough, then the main bearings have failed.
If ther is something caught, then you will hear it catching or clicking.
Hope this helps.
Dec 10, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
It wont do final spin..makes a clicking noise as it turns the drum during spin
I moved my washining machine in order to check pipes....thought id do a final test spin hoping that it would work changed the temperature setting to higher degress (60) put in on a empty wash for about 5 mins then turned it to fast spin an it slowly started spinning until it finished a complete spin!!!!...dont forget to turn the temperature down again!!!
Aug 23, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
During the final spin cycle, water is leaking inside the machine
You have a problem with the pressure switch cutting in too early before all of the water has drained away from the outer drum
There is either an obstruction in the outlet pipe or pump which is not allowing the water to discharge fast enough.
The machine is then spinning with too much water left in the outer drum added to the water which is being expelled from the clothes equals leaking
Take the hose off the back of the machine and put it in a sink , make sure it is secure and do a rinse cycle
Watch the outlet and make sure it is a strong flow if it is weak then you have probably got an item of clothing stuck in the pipe from the drum to the pump and a strip down is required
One more thing there is a small plastic bottle attached to the back of the outer drum this has tube which leads to the pressure switch
Make sure there is no congealed soap in the Air Bell as it is called
Jul 05, 2009 | Fisher and Paykel WA37T26G Top Load Washer
Hotpoint WF100 Vibrating on final spin or fast spin
Hi Clive, if you look under the drum you will see two damper legs which are secured to the drum and the chasis, you will find that one or even both of these are defective, what happens is that one packs in and puts double pressure on the other resulting in that breaking down. take them off and examin them, they should both have a resistance to a fast pull, and should move quite easily with a steady pull applied.
Good luck hope it works.
Mar 06, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Sounds like rocks in machine on final spin
The rear drum seal has leaked water into the rear bearing. Sorry, but the repair is expensive and difficult. It's time for a new washer. Look into the LG models, which are direct drive. Please don't bother rating this, as anything other than a FixYa drops my rating, and I know you don't want to kill the messenger, right?
Oct 14, 2008 | Hotpoint Aquarius WD63 Front Load...
No longer rinses or fast spins...although drum does go round slowly... My WMA 13 First Edition Hotpoint has stopped fast spin, so although the drum does go round, it does not speed up to a fast spin at...
LETS check the DRAIN MOTOR PUMP it could be clogged , open panel of washer to access inside , look for a small motor with 2 hoses connected to it , take it out , clean it , re install and try it again , hope this helps AJ
Apr 14, 2008 | Hotpoint WMA13 Front Load Washer
Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
Dec 30, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
