Question about Frigidaire Refrigerators
My refrigerator freezer wont stay running longer than 4-6 hours. Stops calling for compressor to kick on. any ideas?
Freezer wont stay running longer than 4-6 hours. Stops calling for compressor to kick on. I placed the thermostat to max cold runs 4-6 hours then shuts off. I turn the thermostat just a little it kicks back on runs then stops after a few hours. I am assuming its the temperature control switch but could it be just a bad sensor. Its a side by side model. The compressor sounds fine the exhaust and blower fans run normally when it calls for cold
  • Frigidaire Master
  • 5,323 Answers
I suspect a defrost timer issue but u may want to check the temperature control switch and ur thermistors as well
Posted on Apr 17, 2015
Testimonial: "Those are the 2 I suspect as well. However decided after a few days worrying about my food going bad just to buy a new fridge. The parts are $63 for 1 part $45 for the other. The unit 7 years old so out the door its going."
tborn6
  • 700 Answers
SOURCE: Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Posted on Mar 28, 2009
  • 105 Answers
SOURCE: subzero 361rfd fridge compressor wont stay runnig
It sounds like you have either a bad relay or a bad compressor. The fact that you hear the compressor try to start indicates that the control is good and there is voltage to the compressor. I would suspect the strat winding of the compressor but a meter would need to be used to determine is this is true.
Posted on Apr 07, 2009
  • 146 Answers
SOURCE: Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Posted on Aug 22, 2009
Testimonial: "Thanks for your help. The control board was faulty. This is what I suspected but I wanted a second opinion before buying the board. "
Sea Breeze
  • 4654 Answers
SOURCE: Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Posted on Aug 25, 2009
Testimonial: "You were right, thanks for your help. The control board was bad. That is what I suspected, but I wanted a second opinion."
heatman101
  • 43501 Answers
SOURCE: My Samsung RS2630SH fridge and
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jul 09, 2011
My Samsung RS2630SH fridge and freezer are not staying cold. The condenser fan is running, I blew and vacuumed all dust off of the coils. If I unplug it for a few minutes then plug it back in the...
heatman101
Jul 09, 2011 | Refrigerators
My hoover hfa29k fridge freezer originally started to freeze the contents of the fridge and appeared to be running continuously.I unplugged it and left it for about an hour and then switched it back on...
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
Try this and let me know.
Feb 22, 2011 | Hoover HFA290K Bottom Freezer Refrigerator
I have a Maytag top-freezer refrigerator model RTT1900DAE. The fridge works great. I've placed a memory thermometer in there and the low/high temps are normal. The freezer on the other hand doesn't stay...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 15, 2011 | Refrigerators
My fridge/freezer occasionally stops working( gets warm/wont cool) for a few hours and starts working again after without doing a thing? any ideas
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 11, 2010 | GE Adora (DSF25KGTBG) Side by Side...
Amana refrigerators is not staying cold and freezer is not freezing. Makes a "humming" sound, on and off, like a low "grind" noise, or like the noise an airconditioner makes prior to kicking on.
Mine had the same problem, and I had a tech out today who determined it's the motor inside the freezer. It's (the fan) not running. It's a $100 part, but if your refrigerator is new enough, it's probably worth the investment to go ahead and have it fixed.
Jul 29, 2009 | Amana ABB1927DE Bottom Freezer...
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
Hums and won't kick on
  1. sounds like a bad cvompressor as long as u bought it before 2006 the compressor should be covered call your loical maytag repair man
Mar 18, 2009 | Amana ABB1927DE Bottom Freezer...
GE Profile Fridge/Freezer defrosting
You will need to replace the electronic mother board which is located in the back of the refrigerator,Inside rectangular cover near the bottom left.
Feb 28, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
Kitchenaid freezer will not stay frozen 5 years old
it might be your thermostat stucking up...the one your adjusting one notch higher...
Mar 28, 2008 | Refrigerators
My Amana AFD2535DEW freezer problem
Sound like the compressor is having trouble starting. You can purchase a RCO810 to assist the compressor's start winding. If the unit is under 5yrs there should be some warranty (no electrical parts) left in the compressor. It will need to be replaced.
Oct 16, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
218 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
