Question about Maytag Dryers
When I push the start button my dryer only clicks.
  • Maytag Master
  • 5,323 Answers
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Posted on Apr 26, 2015
SOURCE: dryer will not start.. Here clicking sound when i push start button but nothing happens
Did you clean the lint screen and replace? Also - all lint should be cleaned from back of dryer and the duct...many dryer manufacturer have safety sensors that will not light dryer due to there being too much lint, not enough air flow...(safety feature) ...
Posted on Oct 09, 2008
  • 35 Answers
SOURCE: Push start button and motor hums.
thermal overload on motor tripping
Posted on Jan 26, 2010
Jahn27
  • 1554 Answers
SOURCE: dryer makes click when push
The problem is likely a blown thermal fuse. This thermal fuse is wired in series with the motor and if it blows, power to the motor is terminated and the motor cannot run. No dryer function works when the motor cannot run.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Let us know if the problem is not addressed above but indicate the exact model number of the machine for further advice.
Posted on Feb 01, 2011
Jahn27
  • 1554 Answers
SOURCE: dryer will not start when pushing start button it
This sounds like a problem with the thermal fuse blown which is wired in series with the motor. Power to the motor is terminated when the thermal fuse blows and the motor cannot run. No dryer function works when the motor cannot run. Click on the link below for the detailed instructions in troubleshooting this kind of Whirlpool Duet or Kenmore Elite dryer problem.
Troubleshooting Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Posted on Mar 23, 2011
heatman101
  • 43501 Answers
SOURCE: i have a power but
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 23, 2011
Kenmore 460 g I push the on button the timer clicks but dryer won't start
The start capacitor or the centrifugal switch inside the motor is bad.
Dec 27, 2014 | Kenmore Dryers
Dryer wont start just clicks what can be wrong
may be a bad thermal shut off , any error codes like F1 may also want to check ur push start button or dial with a multimeter, if its bad can get a buzzing and maybe a clicking
Sep 15, 2014 | Dryers
Won't start just clicks when i push the start button. When I push the start button I do hear a faint click in the selection ( color, white.etc.) button
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Mar 05, 2011 | Kenmore Dryers
Dryer will not start. when push button is
Most likely the start switch or door switch has failed. Other failures can also cause this symptom: bad timer, broken belt, bad centrifugal switch, bad motor, etc.
Apr 02, 2010 | Kenmore 64742 Electric Dryer
Dryer wont start.
Some start buttons do not click. But it sounds like maybe the door switch.
Sep 25, 2009 | Kenmore 659 Electric Dryer
Our Kenmore Elite electric dryer does not start. Start button is pushed but only clicks. Thanks in advance.
MY KENMORE DRYER WOULD NOT START IT JUST CLICKED WHEN I PUSHED START. GOT ONLINE & SOMEONE WITH THE NAME JAKE SAID TO CHECK THE THERMAL FUSE. I DID WHAT HE SAID & IT WORKED SO MY HAND GOES OUT TO HIM THANK YOU VERY MUCH JAKE.
SINCERELLY. DANIEL STEED
Jul 12, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer will not start.. Here clicking sound when i push start button but nothing happens
Oct 09, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
89 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
