The sound on my TV does not work. I cannot manually turn off the receiver on or turn it off with the remote control. the TV was on with the sound and suddenly there was no sound.
    Top Expert:
  • Televison & ... Master
  • 74,887 Answers
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Apr 17, 2015
TotalControl
  • 23 Answers
SOURCE: remote lost program function
Hello, this is Vincent from Total Control Remotes - www.totalcontrolremotes.com. We program a lot of Marantz remotes as well as others and the problem could be a result of many different factors. It could be the programming or a physical reason. My suggestion is to send us the configuration file, we will take a look and confirm that the remote programming is not a problem. We can walk you through a variety of troubleshooting steps with the equipment once we have determined that. There is no real answer however until we do our homework.
Regards,
Vincent
www.totalcontrolremiotes.com
Posted on Sep 16, 2009
raycalo
  • 358 Answers
SOURCE: I have 2 dish remotes #103602. One works fine the
bdmills04
Have you replaced the batteries in the remote that is not working. If batteries are low, the lights will still light up but will not operate the functions for the remote. When you press and release the SAT button, what happens? If you try to press the SELECT button, does the TV button light or the SAT button? If you have already tried these steps, you may need to readdress the remote to the receiver. I have provided a link with the instructions on readdressing the remote. I hope this helps.
Readdressing the remote, step 5:
http://www.dishnetwork.com/SupportSection/remote-setup
Ray Calo
DISH Network
Posted on Feb 01, 2011
danbusa
  • 185 Answers
SOURCE: I have a Sony Bravia TV, only a year old, had
If neither the DISH Network remote or the TV remote is working for you most likely your remote sensor is going bad. If you'd like to try readdressing the remote follow the steps and procedures below. Codes: 500, 837, 125, 808, 798, 640, 796, 783, 795, 797, 865, 846, 842, 563, 501, 810, 841, 781, 807, 838, 690, 758, 843, 845, 591, 839, 806, 840, 844
To program the remote:
1.) Hold the clear "TV" mode button for four seconds or until all four buttons at the top of the remote are lit.
2.) Press one of the three digit codes listed above followed by pound (#)
3.) Check for functionality by trying the volume power and mute.
Be sure to press the "SAT" button to return to satellite mode if the code works.
Daniel Busa
DISH Network
Customer Service
Posted on Jun 09, 2011
gopakumarg43
  • 74887 Answers
SOURCE: Samsung LE32C450E1W TV remote control stopped working.
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside its battery compartment. If these do not help you, you remote control need cleaning. If you wish to know more about how to clean and repair a remote control check this site. Pull up older posts. One among it has details.
Posted on Mar 24, 2013
My remote will not turn the tv on or adjust the sound, it will change channels
First, try pressing TV on the remote, check if that solves the problem. Then press Sat and try the TV power button again. If the remote previously controlled the TV, you lost the code for the TV. If you have your Dish Network manual, check if you wrote down the code when it was originally programmed. Which specific remote/receiver do you have? The programming directions and code lists are available here: http://www.dishnetwork.com/supportsection/remote-setup . You can also scan all of the codes to find the correct one: see http://www.dishnetwork.com/SupportSection/power-scan-instructions . Additional remote/receiver manuals are here: http://www.dishnetwork.com/SupportSection/manuals .
The direct coding procedure for the Dish remote that I have is: while facing the TV to be controlled (after adjusting the key for TV1/TV2 in a multiple TV system), press and hold TV until all four indicators light up. Then enter the 3 digit code. Press and release the # key. Then see if the code TV powers off when you press Power. Then press Sat and check if the TV power button works. Try additional codes if the TV doesn't respond.
If you recently got a new TV and you tried to program the remote for your TV, your dish remote may not have the code you need. (Most universal remotes are limited to codes for devices released 6 months or more before the remote was programmed.) In that case, you should use the TV remote (and see if it has an option to control the satellite receiver). Alternatively, get a new universal remote that will control all of your devices. (The remotes that can be programmed by USB are the easiest to set up.)
I hope this helps.
Jul 09, 2011 | DISH Network IR Remote Control
Tip
DISH Solo DVR VIP612 Program TV VCR Remote Code
DISH Solo DVR VIP612 Program TV or VCR Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR 612 to control your primary TV or a VCR? (Instructions to setup a receiver, tuner, stereo, second TV or second VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a primary TV or a VCR:
  1. Turn the device you would like to control on.
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR 612 User Manual.
  3. Press and hold the mode button (TV or VCR) until all the other buttons light up, and then let go. The mode button will flash.
  4. Enter one of the three-digit codes from the tables in the manual.
  5. If you want to program Limited Mode, press 1. If not, skip to the next step. (You can add or remove Limited Mode later.)
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 8 with the next device code from the tables in the manual.
Your device control codes for your TV or VCR are now programmed into your DISH Solo DVR VIP 612.
Help for programing a tuner, receiver, 2nd VCR, or 2nd TV using the AUX mode button can be found here.
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | DISH Network ViP 612
My dvd remote does not work when i try to start movies
Greetings! Does your TV front panel works? If so, the problem lies surely on the remote control portion. But make sure first that the RC unit batteries are new ones. Turn on any portable FM radio receiver and point the RC unit near its antenna. Turning the dial knob very slowly, press any remote control keypads permanently. The moment you hear an oscillating sound from the receiver speaker, stop turning the dial and start to play with the RC unit keypads to find out if there is any sound changes, that means your remote control unit is emitting an infrared signal and its a healthy sign.! Then the defect is on your TV's remote receiver section, mechanically i. e. cold solder or electrically (defective components). Good luck!
Jul 04, 2011 | Televison & Video
Bought new Vizio 55"
Had same problem - turned off Adaptive Lumina, Backlight control, and Ambient light sensors on the Vizio advanced picture settings and the Dish remote now works. Vizio was emitting an infared signal that interfered with the Dish remote signals with these settings on. TV still works and looks just fine... But best of all Dish remote works too.
Nov 08, 2010 | DISH Network IR Remote Control
Cannot turn on or off the tv with remote,can't turn up or down vo
It sounds like either the remote is no good or the ir receiver in the TV has gone bad. try new batteries, or even a universal remote. this will help tell you if it's the TV or remote, good luck
May 31, 2010 | LG 42LG50 42 in. LCD HDTV
Volume control works in DVD mode but not in TV
Where is your TV sound coming from? Is there a volume control at the source?
May 05, 2010 | Denon AVR-485 Receiver
While wathching TV, the typical volume level
Cleared all AV settings and reprogrammed.
Jan 30, 2010 | Onkyo TX-SR703 Receiver
The remote control works sporadically and when the TV is turned on or is bumped, the menu and volume displays flash on and off on the screen. What can I do to fix it?
NO, your remote control sounds like it is sending the signals to the TV. Take the batteries out or put it in a drawer to test. If it's the TV doing it itself, then it's a bad remote receiver circuit.
Jun 30, 2009 | Philips 32PFL6704D 32 in. LCD TV
Program remote for sony ht-5100-d
Use your Directv remote. Use code 10812, remember to program it to change tv inputs also. then program the same remote to control volume on your Sony receiver. Go to the menu on the directv box and follow the onscreen instructions.
Apr 24, 2009 | Sony HT-5100D System
Controler will not turn channels
If you still have the manual that came with remote, reprogram the remote for your receiver. The RC32 is has had some issues because of all the new Directv components available
Jan 05, 2009 | Directv RC32RFK Remote Control
Televison & Video Logo
Top Televison & Video Experts
