Smelled like it was overheating, then shut off. Won't restart. Tried unplugging & pushing reset button, still doesn't seem to be getting any power. Is there an internal reset or fuse I am missing?
    Master:
  • 680 Answers
I would first try replacing the power supply or you can take it in and have it bench tested I think best buy does it for 35.00 unless you have it fixed there then they forget the fee.
Terry
Posted on Apr 17, 2015
Maytag epic Z He washer ecu reset
Unplug it from the wall for 5 min's to reset.
May 05, 2017 | Washing Machines
Dryer won't start
Either one or 2 things happened. The move cause the lint to shift around inside the dryer and it overheated blowing the fuse. OR the new apartment's vent is blocked and caused the dryer to overheat. All maytag dryers are not the same but they all have a non resetable fuse mounted on the blower housing. When the temp exceeds 350f it melts and kills power to the motor. If the motor is not running the heat does not get power. The motor must be turning to make the cent switch power up the heater. Dryer manuals
Dryer videos
Sep 03, 2012 | Maytag Dryers
After a power outage, the lid is locked and won't open. I tried running a new cycle but won't run either. Any suggestions. Thanks, Jan
This is a common problem, often associated with a momentary power failure when the controller doesn't get time to reset and return to an idle state before the machine gets power back and it gets "confused". Regardless of the cause, you will almost certainly find that unplugging from the mains (Not just powering off on the button, as some door locks have a sneak circuit, even when the power is turned off at the button) and leaving the machine undisturbed for a full 20 minutes will allow a reset, the door lock will disengage and all will be well when you power back up.
Additionally, on older machines with analog program selectors, turn the selector to an end of program setting before you power it off.
Jul 11, 2011 | Washing Machines
After shutting down my HP LAPTOP, it won't restart. If you push the "on" button, there's no response. I noticed that about 3 days before this happened, the system cannot...
- try to remove the battery of the laptop and unplug the power cord
- hold the power button for 20 seconds to drain the remaining power
- turn on the system
Jul 09, 2011 | Computers & Internet
Acerpower SV PC will Not turn off
More information would help to resolve this issue.
Are you shutting down by selecting Start and shutdown or have you tried pushing the power button on push (not holding the power button)?
Try this:
Press and hold the power button in solidly for about 10 seconds. If it shuts down before you get to 10 just let off the power button. This should work, but may not solve the problem.
If you reboot it and still can not shut down from Windows, hold power button until it shuts down, unplug the power cord and disconnect everything from the computer other than the keyboard, mouse and monitor. With the power plug still unplugged, hold the power button in for about 15 seconds (this resets the power supply and can clear a corrupt BIOS).
Reconnect power and after booting, see if you can shut down from Windows.
If still no go, click Start, Programs, Accessories, System tools and select System Restore.
Follow the prompts and select a bold date back to a time before you had problems shutting down. That should do the trick.
Let me know if you get it fixed or if you need more advice.
Honest1abe
Jan 02, 2009 | AcerPower SV PC Desktop
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on).
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Oct 11, 2008 | Dell XPS 200 PC Desktop
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
