My printer says invalid tray - Office Equipment & Supplies
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
What's a 016-799 error code mean?
016-799 Wrong combination of print parameters, like selecting to print on custom size paper and setting [Auto] for [Paper Source] on the printer driver and [Auto] for [Paper Size] in trays 1 to 4 on the control panel.
Check the print parameters.What we did is match the documents page size and paper type to the printers (A4) then we could print.
Oct 04, 2010 | Xerox WorkCentre 7328 Multifunction laser...
Invalid New Toner
You may need to get a new chip on the toner tray. If you go to the place that sold you the toner, they likely have the chip that you need.
May 20, 2010 | Samsung CLP-510N Laser Printer
Printer says it out of paper when paper is in photo tray
If you have more than one tray, or the printer thinks that you have more than one tray, you have to tell the print which tray to use. That may not be the problem, but it should be worth going through your print procedure to check.
Hope this is helpful.
Oct 08, 2009 | Office Equipment & Supplies
Tray error invalid config
Message:
TRAY ERROR INVALID CONFIG
What this message means:
The printer detects an incorrect configuration of the trays.
What you can do:
Turn off the printer. Set the trays in the proper configuration again.
See "Installing the Optional Tray Module" in the manual book.
Please find below a link to give you a brief idea on the process. Exact details can be viwewed from the manual only:
http://www.csudh.edu/CLASS/voffice/dell3100printer/Contents/section08.html#513263
Sep 10, 2009 | Office Equipment & Supplies
Error 49.420c
first try to upgrade the firmware
second try a cold reset
if this dont work change the formatter
Aug 06, 2008 | HP LaserJet P3005 Printer
49.2F80
Normally it is fro corrupt data or bad cables.
49.xxxx error explain.
A critical firmware error has occurred that
caused the processor on the formatter to
abort the operation.
This type of error can be caused by invalid
print commands, corrupt data, or invalid
operations.
In some instances, electrical noise in the
cable can corrupt data during transmission
to the printer. Other causes include poorquality
parallel cables, poor connections, or
specific software programs.
Sometimes, the formatter itself is at fault,
which is usually indicated by a 79 Service error
Dec 19, 2007 | HP LaserJet 4350 Printer
Tray Error, Invalid Config
You can restore the original factory default menu settings by initializing NVRAM. Try this and see what happens. from there I would need an exact message off the printer to help further.
Turn on the printer while holding down u_botton.gif and d_botton.gif .
The Customer Mode menu appears.
Press Menu.
Press d_bottonb.gif until Configure appears, and then press r_bottona.gif or arrowbutton_sa.gif .
Press d_bottonb.gif until Maintenance appears, and then press r_bottona.gif or arrowbutton_sa.gif .Press d_bottonb.gif until Init NVRAM appears, and then press r_bottona.gif or arrowbutton_sa.gif .
The Init NVRAM Are you sure? message appears on the operator panel. Press arrowbutton_sa.gif .
Turn off the printer, and then on again.
Oct 19, 2007 | Dell 3100cn Laser Printer
Dell 3100cn
check the tray for a special piece of plastic that, when rotated or adjusted some other way, confirms the tray is holding what paper size and orientation. I know HP used this on older lasers.
Jun 04, 2007 | Dell 3100cn Laser Printer
Tray Error - Invalid Config
Unplug the power cord well the printer is on. and it should reset it worked for me. Hope that helps.
Apr 25, 2007 | Dell 3100cn Laser Printer
k24674
jasbo
jasbo
