Question about Sewing Machines
How much oil does it need. Think have over oiled and have drained but need to know how much to put back in. Thanks
  • 948 Answers
You should check your owner's manual under routine maintenance. If you don't know, measure what you took out and put that much back in, and then slowly add about half a pint at a time, checking and rechecking the oil level on the dip stick. The level should fall between the two points marked on your dip stick.
Posted on Apr 17, 2015
Testimonial: "Hi No good measuring what I took out as I orginally flooded the machine. Now just want to know how much in mls to put back in. Manual does not say. Just says to change oil"
  • Rhonda Webster
    Rhonda Webster Apr 17, 2015
    Okay, well I would start with about three and a half quarts of oil or slightly less. It is hard for me to tell your because I don't know what kind of car you have and how big the engine is. There are about 950 ml in a quart. After you put that much in, it is time to slow way up. Check the dipstick and then add about a fourth of a quart (no more) then check the dipstick again. Keep repeating this process until you get the oil level to go between the two lines on your dipstick. The reason you must go slow is because if you overfill it (which sounds like that happened to you before) two things can happen. Oil can leak out of the dipstick, drip all over the hot engine and burn and stink. Or, worse yet, too much oil can damage the seals in your engine. I hope that helps! :)
Bought an old Singer 507. Worked for about half an hour and then the spinning piece under the bobbin stopped spinning. So it does not make a stitch. I am hoping that it is something simple. HELP.
I think your talking about the hook race? Take the bobbin out and put one drop of oil in it. The oil is household oil for sewing machines and some things which i can't think of any of them. Singer has an oil that's really for any sewing machine. I'm not sure what to do if that doesn't work. I would take it out, only if you are comfortable with that, because you will have to put it back in correctly. I hope the oil helps.
Jun 14, 2017 | Singer Sewing Machines
I don't know where to put oil in my janome j3-24. Please help!
This video goes over everything on your machine. I don't think you are supposed to oil a Janome. I have one, and it never needs oiling. If your manual doesn't tell you where to oil it, don't. BUT, you do need to clean out lint and thread particles quite often.
https://www.youtube.com/watch?v=beiVR_-hHdE
Feb 02, 2015 | Janome Sewing Machines
NEED INSTRUCTIONS FOR OILING INNER WORKINGS
Oiling after something overheated isn't the solution. It may be needed due to the age of the machine, but not until you locate what exactly is making the smell, which may be the plastic near the bulb. I would take the cover off and sniff around to locate where the smell is coming from before oiling.
Apr 17, 2014 | Singer 5050 Mechanical Sewing Machine
I don't know where to put the oil in my sewing machine
try go to the elna website and go to contact us, and contact elna
customer service and ask them about oiling the machine , it may
be a self oiling sewing machine.
Mar 30, 2013 | Elna 3210 Mechanical Sewing Machine
My New Home sewing machine has been in storage for 2 years. When I press the pressure foot, the motor just hums. Can you help me?
try oiling the machine, since you took the machine apart oil it, use only sewing machine oil, usually you can get it at a fabric store or I think wal mart sells some too.
oil the machine,, let it set for a couple of hours,, put paper towel or old towels under neath the machine because of the oil dripping
then try to turn the handwheel back & forth,, putting slight pressure but not heavy,, DO NOT FORCE IT
if it doesn't break loose oil it again & let it set another couple of hours
then try to turn the handwheel again like before
if that doesn't work then get a can of penetrating oil, & use that,, then wait a couple of minutes & try the hand wheel again & after it breaks loose then be sure to oil it again.
let me know if it helps you
Mar 30, 2012 | Sewing Machines
I WANTED TO KNOW HOW DO I OIL AN JANOME MACHINE, I HAVE AN MEMORY CRAFT MACHINE, SO I WANTED TO KNOW HOW TO OIL IT, I SERVICED IT THIS YEAR IN MARCH 2010, SO WHEN DO I NEED TO OIL IT? DO I NEED TO OIL IT...
I don't think you do! There are no instructions in the manual. A while ago my machine sounded funny so I took it in for a service that cost $100! I think Janome have deliberately omitted this information to force sewers into taking machines to recognised mechanics. My machine sounds rough again.
Dec 20, 2010 | Janome Memory Craft 4900QC Mechanical...
How do I oil my Janome My Excel 18 w ? My machine has started to make a squeeking sound when sewing .I think it might need oiling but dont know where to put the oil?Can you please help me with this .
Take off all the outside covers you can, then basically put a drop of oil on anything that moves when you turn the machine over by hand. After this run the machine for a couple of minutes with no thread or fabric, you then need to wipe up any excess oil and refit all the covers.
Oct 10, 2009 | Sewing Machines
Euro Pro 9110-How to oil-Where to put oil
Usually, newer sewing machines will never require oiling. In fact, for most, if not all, it's BAD to oil them.
Is it making a weird sound when you sew? Or are you just being proactive and trying to take good care of your new baby?
Apr 29, 2009 | Euro-Pro 7500XH Mechanical Sewing Machine
Where does the oil go?
To oil machine.....Remove the bobbin case.Snap the two retaining arms outwards.Remove the hook race cover (circular ring ) and the hook ( half semi circular) and clean with a soft cloth.Lubricate right hand side wall ( 1-2 drops of oil) turn hand wheel a few times until the hook race is in the left position...replace hook..replace hook race cover ( smooth end to the bottom) and snap back the two hook retaining arms and insert bobbin case and bobbin.
Jan 06, 2008 | Singer 1116 Mechanical Sewing Machine
Sewing Machines Logo
149 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
