Question about Panasonic Sa-bt230 Blu-ray Disc Receiver
I only have two speakers. Which speaker outs do I use to receive true stereo
  • Gary Melton Apr 17, 2015
    What kind of receiver or amp are you trying to hook them to automobile or house
  • 696 Answers
Harrie is close.
Use Left and Right of course, BUT if your speakers are located front or rear, you'll have to adjust your fader completely to where the speakers are. Failure to fade will result in the amplifier being forced to dissipate the heat generated instead of the speakers doing that job. If the volume is turned up, the heat sinks on your amp will be overwhelmed, resulting in thermal runaway. (i.e. more heat... more current flow... even more heat) This will result in letting the smoke out of your amp destroying it.
Good luck
-Steve
Posted on Apr 17, 2015
  • Anonymous Apr 17, 2015
    The speakers are powered so I shouldn't have a problem. Thanks
    Top Expert:
  • Panasonic Master
  • 6,702 Answers
The ones marked with L and R from left and right. and if it says front, use the, because the back and middle channels won't give enough power.
    Thank you Harrie.
Sound
Your TV has a pair of analog RCA Audio Outputs on the back of the set. They are the red and white, female, round outputs and should be labelled as Audio Out. If you have a surround receiver or stereo that accepts this type of input (most do), then you would purchase a stereo RCA audio cable that has the red and white male ends on both ends of the cable and plug them in to the appropriate stereo RCA left and right channel audio inputs on your receiver and the aforementioned outputs on your TV. The same is true if you have a pair of self-powered computer speakers (or similar). If your external speakers or audio systems don't have the RCA inputs, you may need to get an adapter to convert the RCA output to stereo mini-jack (or similar) to match the appropriate input on your external speakers. Does that make sense?
Apr 14, 2014 | Sceptre X322BV HD 32 inch Class Television...
It can be possible to bi-amp a pair of Klipsch RB-81 with this receiver for stereo listening, and if yes, how...
Bi-amping indicated that you have two amps, one for the tweeters, adn another for the woofer, in a two way system. If you don't have two seperate amps, you can use the speaker A & B outputs to run seperate speaker llines to each set of speaker inputs, but that will not be true bi-amping. Another alternative is to use jumpers to connect the speaker inputs together, this not needing seperate amps. Here's a link to the owner's manual:
http://www.manualslib.com/manual/359882/Klipsch-Reference-Series-Rb-41-Ii.html#product-Reference%20Series%20RB-81%20II
Oct 14, 2013 | Sony STR-DH510 5.1 Channels Receiver
List of recommended receivers for the 901 speakers
Hello,first off they are great,natural sounding speakers.They can handle quite a bit of power and if you like it loud you will need it,because they arent going to put out serious db until they get to approx 50 watt rms.I would look into recievers that put out a true 20-20khz 150 watts per channel.At that level you will have the power and headroom needed for almost any demand.Models and features vary ,but brand quality and durability rarely do. My favorite brands are,yamaha ,denon,marantz,onkyo and integra ..What they offer at about there 1200 dollar price point will be more than enough.
Feb 21, 2011 | Bose 901 VI Main / Stereo Speaker
I have a fisher ca-9335 integrated stereo amplifier thats hooked up to sanyo tp 1010 turn table and plays out of yamaha ns-70t speakers. a simple jvc cd player is also hooked up to the speakers but not to...
Something doesn't add up. You mention two connections to the speakers - CA-9335 and a "simple jvc cd player". Is that true? If so, you might want to UNconnect the CD from the speakers and run it into the receiver where it belongs. An amp isn't designed to share the load with another live device; or even have electrical contact with anything BUT speakers.
Did you actually find documentation that supports this hook-up? Or just winging it?
Feb 20, 2011 | Audio Players & Recorders
I have my HTR 6030 receiver hooked up with a blu ray and am trying to get true 5.1 sound. Have a blu ray disc playing and have put the setting on "straight" on receiver as instructed by future...
If you only have sound from the front left and right speakers when it's set to STRAIGHT, it means the audio source is only 2 channel stereo. As the audio source is from Blu-Ray, the audio should be HD if you are using the correct type of audio cable.
I really need more information from you to give a definitive answer. If you are only using a RCA type audio cable (red/white plugs) from the Blu-Ray to the Yamaha receiver then you will only get left and right front channels on the STRAIGHT setting. This receiver does not have HDMI, so you really need to be using a digital optical audio cable to get true 5.1.
Please can you let me know how the BD player is connected to the Yamaha receiver if you need further assistance.
Thanks,
BElectric
Feb 05, 2011 | Yamaha HTR-6030 Receiver
I cannot connect my bose 901 series v1 active equalizer to my denon av surround receiver avr-891
Short answer from personal experience.
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers.
The reason: You can't use the Active EQ (or ANY processor) in a tape Monitor loop with anything but 2-channel stereo material. As soon as you activate the loop you lose digital sources.
Adding to YOUR particular problem is that the Denon doesn't have a volume-controlled pre-out to feed that amp. If you want to deal with controlling the separate amp volume manually you COULD connect the Active EQ between DVR Out and the 901 amp IN but you would have a stereo mixdown instead of true front channel from the speakers.
Bummer.
Dec 26, 2010 | Bose 901 VI Main / Stereo Speaker
Unable to connect surround sound with a stero player
There is a obvious difficulty here. If you have a stereo receiver then it can't produce surround sound. You must have a surround sound receiver to present true surround sound. If you already do have that then on the back of your Phillips set there are audio outputs. The left and right audio out will be decoded in your surround sound receiver and they will automatically play from your speakers. You should have seven speakers, center channel, left and right front speakers, left and right rear speakers and left and right mid or side speakers. A sub-woofer would be nice too. Best bet is to speak with the store you purchased the set from. They will have that information.
Zashiban
Jun 23, 2010 | Philips Televison & Video
I have an onkyo 304 receiver and would like to run some bose 901 off of it. I can get my ipod to work but not the receiver
For stereo only go to the Bose site and look up the 901. For multichannel, you would need to be able to extract the Line Level Front L and R to a new amplifier and hook the 901's to that amp. I don't see that ability on this receiver. I have posted dozens of solutions for receivers that CAN draw out Front L & R to use 901's in multichannel rigs. I do it.
The closest you could come with this receiver is to draw out the Stereo L and R Line Level from the Tape Out jacks, but that would not be like having the discrete Front channels. You need true pre-amp outputs for the Front L and R.
Jan 25, 2010 | Bose 901 VI Main / Stereo Speaker
How do i connect to laptop? i can only hear 2 of 4!
If your laptop hasn't a 5.1 surround card you can't connect them in a true 5.1 surround system way. But if you have a stereo sound card and if you don't care about true multichannel and want just to hear sound from all the speakers you neet to connect the adapter that came along with your speaker set-just plug and match the colors from the speaker plugs with the adapter and buy a jack stereo to 2 rca cable and plug the rca connectors to the adapter and plug the stereo jack to you laptop.
Oct 17, 2009 | Logitech X-530 Computer Speakers
I bought a Denon AVR 3808 receiver. Bose says my speakers EQ is not compatable for this AVR. Is there a list of compatable receivers for these speakers...seems confusing...should I return the speakers or...
You might be faced with the age-old Bose issue of a 4-ohm speaker set. The ohm rating must be compatible. Most receivers drive 8-ohm speakers. If indeed they are incompatible, then it's up to you which component you want to replace (I don't recommend trying to find a converter to use the Bose speakers). The receiver sounds like it is new, so perhaps the speakers... or return the receiver and get one that can drive the Bose.
Dec 24, 2008 | Bose 901 VI Main / Stereo Speaker
Panasonic Sa-bt230 Blu-ray Disc Receiver Logo
154 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
