Question about Kitchen Ranges
Baxter rotating oven will turn on. It will not heat, don't know where the pilot light is to see of it is ignited....
    Top Expert:
  • Kitchen Ranges Master
  • 44,341 Answers
Call a repairman I suggest nothing when it comes to GAS
Posted on Apr 17, 2015
MNfisherman
  • 11896 Answers
SOURCE: GE Spectra TrueTemp Oven Pilot is Out
REmove bottom panel from stove. shut gas off for at LEAST 5 min. Longer is better. Then placel open flame above gas nozzle, slowly turn to ignite posiiton. After it is lit, wait 30 seconds and turn to on positon.
If by chance this model doens't have a knob for this, then turn gas valve off for 5 min, let fumes evaporate, light flame, place over nozzle, turn gas on.replace bottom oven panel slowly.
Posted on Jan 20, 2009
jsrock516
  • 5911 Answers
SOURCE: oven will not ignite, but broiler and stovetop
Most modern stoves no longer have a pilot. The problem is more than likely caused by a bad igniter on the bake manifold. The following link explains igniter types and how to replace one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Modern stoves are equipped with either a glow-bar or spark type igniter. These igniters do become weak with age and fail. This tends to be more common with the bake feature because it gets used more often. If the igniter is worn to the point that it longer produces the correct current potential or spark, the gas valve will not open and you will not have ignition. This is actually a designed safety feature that prevents free flowing gas from entering the oven cavity without ignition. Such a condition would be dangerous and could cause a flash ignition or explosion.
If the model number you have this listed under is correct, you can see an illustration of your stove at appliancepartspros.com. Just type in the model number and look under the "Gas Burner Parts" section for item number 28 (part #AP2014008).
If you have questions, or require additional assistance, please post back and let me know. I hope this is helpful to you.
Posted on Mar 03, 2009
Maytag317
  • 1136 Answers
SOURCE: how do i adjust oven pilot light on vulcan range
hi, there is an orfice for the oven located on the gas valve. If you are using LP gas, the orfice should be turn down all the way (counter clockwise). If you are using natural gas, the orfice should be turned out about 2-1/2 turns. Was this oven set up to be used with one gas and noe is being used with another? If so, you will need to do more then adjust orfices. Please let me know if I can assist you further.
Thaks
Vic
Posted on May 13, 2009
Maytag317
  • 1136 Answers
SOURCE: Magic chef oven pilot light out
Hi, If the oven has a standing pilot too, Open the bottom door and locate the main burner. Follow the burner toward the rear of the oven and there will be a flame switch attatched to the burner. Hold the flame near the flame switch and the gas should ignite.
Some model do not have a standing pilot in the oven. Please get me your model number off the label located around the opening of the lower door so I can look this up and instruct you better.
Vic
Posted on Jul 15, 2009
  • 23 Answers
SOURCE: Viking 30" Range - Igniter works - but NO FLAME in oven or ranges
No pilot light need to be ignited. You may need a new ignitor. It might not be catching. If you pull the bottom oven plate off you can see the ignitor on the side of the burner and see if it is in its place or broken or just plain old. It is a simple fix. You can buy a universal ignitor or contact Viking and they will sell it to you. Its only two wires and can do it yourself if you are somewhat technical. Good luck.
Posted on Sep 18, 2009
Pilot light either won't light or won't stay on
Check for a draft first that is randomly blowing this thing out and second check the gas regulator.
Mar 12, 2014 | Baxter Ovens
I have a Frigidaire model FCG30B6Q0JWI-5A gas stove (Made in Costa Rica) and can't get the oven to stay lit. There is no electronic ignition, no pilot, it's just a regular run-of-the-mill light a...
While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
Jul 28, 2011 | Ovens
I have a Maytag gas over/stove, Model number MGR5755QDW. The broiler heats, but the oven does not. What are the possible causes and how do I troubleshoot?
If you are having problems with the oven, the first thing to do is figure out if you have a pilot light system or a glow bar system.
Problems with the pilot light system.....The flame has gone out, re-light the pilot. The pilot flame will not light - possible oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's a internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Problems with the glow bar system.....You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works -click here.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Jan 26, 2010 | Kitchen Ranges
Gas oven turns on but no heat. Think pilot light is out but can't find it. Kenmore model 91130469893
Not sure how old your range is but most haven't had pilot lights for some years. The ovens use either a kind of hot-wire igniter or a spark gap for ignition. Check the Sears parts site for your model number and I think you'll find an illustrated parts breakdown that can be very helpful in diagnosing problems.
Dec 17, 2009 | Computers & Internet
Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
Hi
If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Ovens
Stove works just fine/oven does not warm up - pilot light is on, but turning on oven does nothing but make the pilot light glow a little bigger. Oven will not ignite.
Hi, The ignitor is getting weak and will not open the gas valve. Replace the ignitor and you will be back in business. This is a very common problem with the gas ovens.
Vic
May 29, 2009 | Ovens
Oven will not light
Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system
Nov 20, 2008 | Frigidaire Ovens
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
