Crosley CR245 Turntable Logo
Timothy Bennett Posted on Apr 17, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW I CAN TO GET IT COME BACK ON AND PLAY MY VINYLS AND MY CD'S AND RADIO?
Grubhead
Level 3:
  • Crosley Master 5,755 Answers
  • Posted on Apr 22, 2015
 Grubhead
Crosley Master
Level 3:
Answers
5755
Questions
Helped
1662270
Points
11417
It sounds like you have lost power to it. So the obvious thing to do is check the fuse in the plug and if that is good to look inside for the fuse there. If you can't solve the problem yourself, then you need to take it to a service centre. Don't go inside it if it is still under warranty.
MY TURNTABLE START PLAYING ON THE SECOND SONG OF THE 33" VINYL, WHAT IS THE PROBLEM
Do you have a switch to select the size of the record as well? We had a record player that could play 7" singles at 33rpm (floppy vinyls given away by Sunday papers). We had to select 33rpm and also 7" on a separate lever for this to work.
1helpful
Car radio/cd player cuts off radio will not play cd will not play ,hit the power button and will come back on some times it wil not. its seems like there is static sound when the music does not play on the...
Hello pinkperry,
It sounds like the wiring between the cdplayer and the dash has come loose. When the wires are not making proper connections some of the speakers or functions of the radio cut on and off.
This is just my first thought and the easiest thing to fix. You will have to remove the cd player from the dash. After which you will want to check the wiring. Chances are your cd player has a harness if it's an aftermarket cd player installed in your car. If it does there will be two sets of wires to double check.
Just make sure all the wires are securely twisted together (the sets of wires) and taped up with electrical tape.
Try that and post back if you have any further questions. Thank you for choosing Fixya!
I own a Bush RP A3 turntable and radio with CD=need instructions
FIRST READ ALL, then check cables u need, then proceed!
u want to connect turntable to pc - don't need usb
or connect turntable audio-out to radio/cd.player and this combination to pc?
recording on mp3 player is an option, but quality else is much better!
u will need for case 1:
a pc-program called audio-grabber 1.83, downloadable on the inet
a pc with soundcard that has audio-in (3.5mmplug, also used for small microphones
and earphones)
and at least win 2000 on it
the cable connecting turntable and pc(see following)
if turntable has audio-out like
- two red and black-cinch ports (to connect to amplifier/radio)
you need adaptor cable from 2-plug (red/black, male) to 3.5mm audio-in (similiar tor headphones,
male version)
- turn-table has small(3.5mm) or big (6.3mm) earphone-in,
use signal from here, connect tt with pc using adaptor cable
(3.5mm, male + 6.3 to 3.5mm separate adappor (small earphone to fit in big) at one end and
3.5mm, male to plug into pc-soundcard's audio in)
do all the pluggin', then turn on PC, start up audiograbber, turn on tt let play, press record button
in audio grabber, make an test recording, half a minute will do.
now let audiograbber sample theresulting .ogg file to test.mp3 and test-play it with windows media player on your pc
voila une mp3 !
to have every song from vinyl sepatetly as mp3,
record and name it serately in audiograbber, let it sample down to mp3 and enjoy!
u may have to fiddle through audio-grabber's menus and adjust volume, sample rate(quality of mp3)
to your comfort, but now u own legal copies of your vinyls, with still the analog vinyl tickle
and know how to use audio grabber as an recording tool for any music that is played on or put into a pc, incl. webradio other webcasts
please don't stop the music
The cd player will not play cd or eject cd
You need to get a engine diagnostics check sounds like you had a blip somewhere on the system that has caused your radio to do this
How to use dazzler to copy records to cd
You will need a device that can read vinyls and transfer them to your computer. Thinkgeek.com sells a good one called ION USB for $99.
1helpful
3answers
Kenwood KDC-119 car stereo problem
There is a small hole at the bottom of the stereo face that will reset the system. I pushed a pen tip into the hole and it turned the stereo off. When I removed the pen, the system turned on and the CD ejected. Problem solved.
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
