Question about Maytag Refrigerators
The ice dispenser is going really slow. It hasn't filled up in two days. The water is still working though. Model number MSD25242VEW00
    Top Expert:
  • Maytag Master
  • 44,260 Answers
Read your manual it tells how to turn it on and off there .Possibly stuck in the off position
Posted on Apr 17, 2015
My whirlpool ed20db ice maker isn't making ice. Inlet tube is frozen solid
Thanks for the model number. The water control valve=> W10245167 Water Inlet Valve will need replaced when this happens. Problem allows water to leak slowly into the ice maker and fill tube can become solid very quickly, or very messy ice formations coming down from ice maker, Thanks John Tripp Appliance 911
Jan 28, 2014 | Whirlpool Refrigerators
Water dispenser and ice maker not working properly.
If the water flowed normally for a few years and now will not fill the ice maker with enough water to make full size cubes or dispenser fill too slow the problem may be a defective=> 67005154 Water Inlet Valve In the tutorial above I want you to listen carefully of all the possible items that can cause slow waterflow. I am here should you have questions Thanks Sea Breeze
May 25, 2013 | Maytag 26 cu. ft. Wide-By-Side...
We have a Kenmore Model 57577791 refrigerator. It's almost 13 years old. For about 6 months, it hasn't been dispensing water. It makes ice, but constantly freezes up right where the ice goes out...
Water is only in the line, theres no tank so one cycle will get rid of any old water, then you can just throw those ice cubes away. The way to fix the problem is to replace the solenoid fill valve on the back bottom corner of the refrigerator, Thats the thing the water hose connects to. It has a slow leak that is causing the ice to build up in the tube. Good luck.
May 29, 2011 | Refrigerators
Not making any ice.
Hello there:
here is a couple of things to check ok
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Dec 23, 2009 | Refrigerators
Ice & Water Dispenser Suddenly Dysfunctional; LED lights, too!
Cory, you sound like you have a bad water valve as well as a bad control board for your dispensor. If you've had any storms in your area in the past 4 - 6 weeks, it's very possible that the storm took both parts out.
We have parts for GE as well as mots other major brands, so please give us a call with your complete model number and we will get your parts out to you right away!
We hope this solves your problem and we look forward to being able to assist you with future issues.
Have a great evening.
Nov 05, 2009 | GE GSS22JF Side by Side Refrigerator
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sep 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE side by side; model # TFX25JRYD Serial #
So the dispenser is getting water. Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If the valves clicks but water doesn't get to ice maker the fill tube can be stopped up with ice.The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Jul 12, 2009 | GE GSS25JEM Side by Side Refrigerator
Freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Mar 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Refrigerators Logo
54 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
